Nvidia Spadek Wydajności?
MC'
Witam,
Zainstalowałem stery:
# rpm -qa |grep nvidia
xorg-x11-drv-nvidia-libs-169.09-3.lvn8
xorg-x11-drv-nvidia-169.09-3.lvn8
kmod-nvidia-169.09-5.lvn8
kmod-nvidia-2.6.23.14-107.fc8-169.09-5.lvn8
$ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
   GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
   GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
   GLX_EXT_texture_from_pixmap, GLX_ARB_multisample, GLX_NV_float_buffer,
   GLX_ARB_fbconfig_float, GLX_EXT_framebuffer_sRGB
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
   GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
   GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
   GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
   GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float,
   GLX_EXT_fbconfig_packed_float, GLX_EXT_texture_from_pixmap,
GLX version: 1.3
GLX extensions:
   GLX_ARB_fbconfig_float, GLX_EXT_framebuffer_sRGB,
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 8800 GTS/PCI/SSE2
OpenGL version string: 2.1.2 NVIDIA 169.09
OpenGL extensions:
   GL_ARB_color_buffer_float, GL_ARB_depth_texture, GL_ARB_draw_buffers,
   GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
   GL_ARB_fragment_shader, GL_ARB_half_float_pixel, GL_ARB_imaging,
   GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
   GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
   GL_ARB_shadow, GL_ARB_shader_objects, GL_ARB_shading_language_100,
   GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
   GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
   GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_texture_float,
   GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
   GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
   GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
   GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
   GL_ATI_texture_mirror_once, GL_S3_s3tc, GL_EXT_texture_env_add,
   GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
   GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
   GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
   GL_EXT_Cg_shader, GL_EXT_bindable_uniform, GL_EXT_depth_bounds_test,
   GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
   GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
   GL_EXT_framebuffer_object, GL_EXTX_framebuffer_mixed_formats,
   GL_EXT_framebuffer_sRGB, GL_EXT_geometry_shader4,
   GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
   GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
   GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
   GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color,
   GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
   GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture3D,
   GL_EXT_texture_array, GL_EXT_texture_buffer_object,
   GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
   GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
   GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
   GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
   GL_EXT_texture_integer, GL_EXT_texture_lod, GL_EXT_texture_lod_bias,
   GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_sRGB,
   GL_EXT_texture_shared_exponent, GL_EXT_timer_query, GL_EXT_vertex_array,
   GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
   GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_copy_depth_to_color,
   GL_NV_depth_buffer_float, GL_NV_conditional_render, GL_NV_depth_clamp,
   GL_NV_fence, GL_NV_float_buffer, GL_NV_fog_distance,
   GL_NV_fragment_program, GL_NV_fragment_program_option,
   GL_NV_fragment_program2, GL_NV_framebuffer_multisample_coverage,
   GL_NV_geometry_shader4, GL_NV_gpu_program4, GL_NV_half_float,
   GL_NV_light_max_exponent, GL_NV_multisample_coverage,
   GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
   GL_NV_packed_depth_stencil, GL_NV_parameter_buffer_object,
   GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_primitive_restart,
   GL_NV_register_combiners, GL_NV_register_combiners2,
   GL_NV_texgen_reflection, GL_NV_texture_compression_vtc,
   GL_NV_texture_env_combine4, GL_NV_texture_expand_normal,
   GL_NV_texture_rectangle, GL_NV_texture_shader, GL_NV_texture_shader2,
   GL_NV_texture_shader3, GL_NV_transform_feedback, GL_NV_vertex_array_range,
   GL_NV_vertex_array_range2, GL_NV_vertex_program, GL_NV_vertex_program1_1,
   GL_NV_vertex_program2, GL_NV_vertex_program2_option,
   GL_NV_vertex_program3, GL_NVX_conditional_render, GL_SGIS_generate_mipmap,
   GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow,
   GL_SUN_slice_accum
  visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x21 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x22 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x24 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x25 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x26 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x27 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x28 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x29 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x2a 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x2b 24 tc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x2c 24 tc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x2d 24 tc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x2e 24 tc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x2f 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x30 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x31 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x32 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x33 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x34 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x35 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x36 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x37 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x38 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x39 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x3a 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x3b 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x3c 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x3d 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x3e 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x3f 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x40 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x41 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x42 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x43 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x44 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x45 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x46 24 dc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x47 24 dc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x48 24 dc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x49 24 dc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x4a 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x4b 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x4c 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x4d 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x4e 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x4f 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x50 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x51 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x52 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x53 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x54 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x55 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x56 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x57 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x58 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x59 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x23 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x5a 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x5b 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x5c 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x5d 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x5e 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x5f 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x60 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x61 32 tc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x62 32 tc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x63 32 tc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x64 32 tc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x65 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x66 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x67 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x68 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x69 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x6a 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x6b 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 Ncon
0x6c 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 Ncon
0x6d 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x6e 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x6f 32 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x70 32 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x71 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x72 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
0x73 32 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 Ncon
0x74 32 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 Ncon
i to co dostaję to marne :
$ glxgears
67759 frames in 5.0 seconds = 13551.648 FPS
61146 frames in 5.0 seconds = 12229.144 FPS
79479 frames in 5.0 seconds = 15895.717 FPS
77639 frames in 5.0 seconds = 15527.567 FPS
60777 frames in 5.0 seconds = 12155.337 FPS
.. gdzie rok temu to było:
$ glxgears
117181 frames in 5.0 seconds = 23436.149 FPS
Nawet na necie widzę że fps'y ludzie mają lepsze na podobnych kartach:
http://forum.arch-linux.pl/viewtopic.php?pid=17639#p17639
Mój xorg.conf:
Section "Device"
        Identifier  "Videocard0"
        Driver      "nvidia"
        Option      "AddARGBGLXVisuals" "True"
EndSection
Gdzie może być problem? Tzn ilośc fpsów się zmniejszyła dość radykalnie.. konfiguraca kompa niezmieniana. Jedyne co się zmieniło to fedora i stery
Z góry dziękuję za sugestje i propozyce
MC'
Witam,
$ glxgears
$ glxgears
MC'
No ludzie kur... kiedy się nauczycie, że glxgears NIE JEST JAKIMKOLWIEK wyznacznikiem wydajności jeśli chodzi o rendering 3D! Nikt NIGDY nie powinien się nim kierować!
A używasz może compiza albo compiz-fusion?
Nie, niedawno tylko zainstalowałem sobie stery z serii ...09 i z ciakawości sprawdziłem ile klatek dostaje. Dlatego ciekaw jestem z czym to się wiąże
A kto Cię o takie rzeczy pyta. Zauważyłem tylko znaczący spadek ilości fps w glxgears który coś chyba mierzy nie ? A fakt że podałem poprzednie wyniki o wiele lepsze więc co by nie mierzył są gorsze. Nikt nie pisze że to benchmark ale po to ejest by podawać pewne statystyki a te są gorsze !
