g.r.z.e.s Napisano Luty 8, 2008 Zgłoszenie Share Napisano Luty 8, 2008 Po wydaniu polecenia make występuje błąd: grzes@localhost truecrypt-5.0-source]$ make WX_ROOT=/usr/src/wxGTK-2.8.3 wxbui ld Configuring wxWidgets library... Building wxWidgets library... /usr/src/wxGTK-2.8.3/src/gtk/gsockgtk.cpp:134: warning: ‘wxDummyGsockVar’ define d but not used [grzes@localhost truecrypt-5.0-source]$ make Compiling Buffer.cpp Compiling Exception.cpp Compiling Event.cpp Compiling FileCommon.cpp Compiling MemoryStream.cpp Compiling Memory.cpp Compiling PlatformTest.cpp PlatformTest.cpp: In static member function ‘static bool TrueCrypt::PlatformTest ::TestAll()’: PlatformTest.cpp:243: warning: unused variable ‘finally243’ Compiling Serializable.cpp Compiling Serializer.cpp Compiling SerializerFactory.cpp Compiling StringConverter.cpp Compiling TextReader.cpp Compiling Directory.cpp Compiling File.cpp Compiling FilesystemPath.cpp Compiling Mutex.cpp Compiling Pipe.cpp Compiling Poller.cpp Compiling Process.cpp Compiling SystemException.cpp Compiling SystemLog.cpp Compiling Thread.cpp Compiling Time.cpp Updating library Platform.a Compiling Cipher.cpp Compiling EncryptionAlgorithm.cpp Compiling EncryptionMode.cpp Compiling EncryptionModeCBC.cpp Compiling EncryptionModeLRW.cpp Compiling EncryptionModeXTS.cpp Compiling EncryptionTest.cpp Compiling Hash.cpp Compiling Keyfile.cpp Compiling Pkcs5Kdf.cpp Compiling Volume.cpp Compiling VolumeException.cpp Compiling VolumeHeader.cpp Compiling VolumeInfo.cpp Compiling VolumeLayout.cpp Compiling VolumePassword.cpp Compiling VolumePasswordCache.cpp Compiling Aescrypt.c Compiling Aeskey.c Compiling Aestab.c Compiling Bf_ecb.c Compiling Bf_enc.c Compiling Bf_skey.c Compiling C_ecb.c Compiling C_enc.c Compiling C_skey.c Compiling Des.c Compiling Des_enc.c Compiling Ecb3_enc.c Compiling Rmd160.c Compiling Serpent.c Compiling Set_key.c Compiling Sha1.c Compiling Sha2.c Compiling Twofish.c Compiling Whirlpool.c Compiling Crc.c Compiling Endian.c Compiling GfMul.c Compiling Pkcs5.c Updating library Volume.a Compiling FuseService.cpp Updating library Driver.a Compiling CoreBase.cpp Compiling CoreException.cpp Compiling FatFormatter.cpp Compiling HostDevice.cpp Compiling MountOptions.cpp Compiling RandomNumberGenerator.cpp Compiling VolumeCreator.cpp Compiling CoreService.cpp Compiling CoreServiceRequest.cpp Compiling CoreServiceResponse.cpp Compiling CoreUnix.cpp Compiling CoreLinux.cpp Updating library Core.a Precompiling SystemPrecompiled.h Compiling Application.cpp Compiling CommandLineInterface.cpp Compiling FavoriteVolume.cpp Xml.h: In constructor ‘TrueCrypt::XmlParser::XmlParser(const std::string&)’: Xml.h:37: error: ‘FromUTF8’ is not a member of ‘wxString’ make[1]: *** [FavoriteVolume.o] Błąd 1 make: *** [all] Błąd 2 [grzes@localhost truecrypt-5.0-source]$ Jakieś sugestie? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
