Planet 8305 +fedora Core 2 =kicha :(
Abee
Witam
Mam radiówke Planeta 8305 na chipsecie acx100 i po instalacji według opisu z http://www.fedora.pl/site/forum/index.php?...?showtopic=1389 wyskakuje mi taki błąd po uruchomieniu skryptu:
./start_net
./start_net: line 55: these: command not found
./start_net: line 188: syntax error near unexpected token `)'
./start_net: line 188: `# uncomment this 2 lines below (yeah, it's an ugly workaround!)'
Domyślam sie ze to cos z kluczem ? W sieci mamy szyfrowanie 128bit ASCI klucz o długości 13 znaków --- jak to wpisać ?
Ktoś ma jakieś pomysły ? Linux bez sieci to dla mnie koszmar :(
#!/bin/bash
# start_net script #
# acx100 project #
# acx100.sourceforge.net #
# edited by arnie <[email protected]> #
# Please edit here
DEV=wlan0
ESSID="any" # THIS IS CASE SeNsItIvE!! any == associate to any ESSID
# Default rate configured as 11Mbps to not cause connection problems with non-22Mbps hardware...
RATE=1M
AUTORATE=10
CHAN=11 # it's useful to try to stick to channels 1, 6 or 11 only, since
these don't overlap with other channels
#SHORTPREAMBLE=1 #set a value of 1 in order to use "Short Preamble" (incompatible with very old WLAN hardware!)
#TXPOWER=18 # 0..20 (dBm) (18dBm is firmware default) overly large setting might perhaps destroy your radio eventually!
MODE=Managed # Auto == auto-select Managed or Ad-Hoc depending on
environment
DEBUG=0x00
KEY="tu wpisałem swój 13 cyfrowo-literowy klucz" # WEP128
#KEY0="1234567890" #WEP64
#KEY1="1234567890"
#KEY2="1234567890"
#KEY3="1234567890"
ALG=open # open == Open System, restricted == Shared Key
USE_DHCP=0 # set to 1 for auto configuration instead of fixed IP setting
IP=tu wpisałem swoje IP
NETMASK=255.255.255.0
GATEWAY=10.5.5.1
# Usually no editing should be required below this line...
# -- unless you want this script to fetch stuff with dhcp
if test "$UID" != "0"; then echo "You are not root. To insert the module into your kernel, you need to be root. Enter su and try again. Bailing..."; exit 1; fi
SYNC=`which sync`
INSMOD=`which insmod`
IFCONF=`which ifconfig`
IWCONF=`which iwconfig`
IWPRIV=`which iwpriv`
ROUTE=`which route`
SCRIPT_AT=`dirname $0`
if test -z "$SYNC"; then echo "sync not found. Go get a sane Linux system. Bailing..."; exit 1; fi
if test -z "$INSMOD"; then echo "insmod not found. Go get a sane Linux system. Bailing..."; exit 1; fi
if test -z "$IFCONF"; then echo "ifconfig not found. I can insert the module for you, but you won't be able to configure your interface."; CONTINUE=ASK; fi
if test -z "$IWCONF"; then echo "iwconfig not found. Make sure it is installed. The interface might work without, though."; CONTINUE=ASK; fi
if test -n "$CONTINUE"; then echo -n "Problems encountered. Do you want to continue? [n] "; read ANSWER
case $ANSWER in ( y | Y | Yes | YES | yes | j | J | ja | Ja | JA ) ;;
( * ) exit 1 ;;
esac
fi
case "`uname -r`" in
2.4*)
MODULE_AT="/home/piotrek/WLAN/module/acx100_pci.o"
MODULE_AT="${SCRIPT_AT}/../src/acx_pci.ko"
esac
if test ! -r "$MODULE_AT"; then echo "Module not found or not readable.
Have you built it? This script expects it to be at ../src/acx_pci.[k]o, relative to the script's location. Bailing..."; exit 1; fi
# FIRMWARE_AT has to be given as an absolute path!!
FIRMWARE_AT="/home/piotrek/WLAN/firmware"
# check whether either of the two required main firmware files is
# available
if test ! -r "$FIRMWARE_AT/WLANGEN.BIN" -a ! -r "$FIRMWARE_AT/TIACX111.BIN"; then echo "Firmware not found or not readable. Have you placed it in the firmware directory or run make extract_firmware once? This script expects it to be at ../firmware/WLANGEN.BIN (or ../firmware/TIACX111.BIN for the ACX111 chip), relative to the script's location. Bailing..."; exit 1; fi
if test "$RATE" != "11M"; then echo "Transfer rate is not 11 Mbps, but $RATE. If something doesn't work, try 11 Mbps."; fi
# for better debugging
# set -x
#echo 8 > /proc/sys/kernel/printk
# just in case ;)
$SYNC
sleep 1
if test -n "`lsmod |grep acx_pci`"; then ${SCRIPT_AT}/stop_net; fi
$INSMOD $MODULE_AT debug=$DEBUG firmware_dir=$FIRMWARE_AT
if test "$?" = "0"; then echo "Module successfully inserted."; else echo "Error while inserting module! Bailing..."; exit 1; fi
if test -n "$IWCONF"; then
test "$AUTORATE" = "1" && AUTO=auto || AUTO=
if test -n "$RATE"; then
echo Setting rate to $RATE $AUTO.
$IWCONF $DEV rate $RATE $AUTO
test "$?" != "0" && echo Failed.
fi
if test -n "$CHAN"; then
echo Setting channel $CHAN.
$IWCONF $DEV channel $CHAN
fi
if test -n "$SHORTPREAMBLE"; then
echo Setting short preamble to $SHORTPREAMBLE.
$IWPRIV $DEV SetSPreamble $SHORTPREAMBLE
sleep 1
fi
if test -n "$TXPOWER"; then
echo Setting Tx power level to $TXPOWER dBm.
$IWCONF $DEV txpower $TXPOWER
sleep 1
fi
echo Going to try to join or setup ESSID $ESSID.
$IWCONF $DEV essid "$ESSID"
if test -n "$MODE"; then
echo Setting mode to $MODE.
$IWCONF $DEV mode $MODE
fi
if test -n "$KEY"; then
echo Setting key to $KEY, algorithm $ALG.
$IWCONF $DEV key $ALG "$KEY"
fi
if test -n "$KEY0"; then
echo Setting key 0 to $KEY0, algorithm $ALG.
$IWCONF $DEV key $ALG "$KEY0" [1]
fi
if test -n "$KEY1"; then
echo Setting key 1 to $KEY1, algorithm $ALG.
$IWCONF $DEV key $ALG "$KEY1" [2]
fi
if test -n "$KEY2"; then
echo Setting key 2 to $KEY2, algorithm $ALG.
$IWCONF $DEV key $ALG "$KEY2" [3]
fi
if test -n "$KEY3"; then
echo Setting key 3 to $KEY3, algorithm $ALG.
$IWCONF $DEV key $ALG "$KEY3" [4]
fi
fi
# for notebook use - a power LED is sooo useless anyway ;-))
#test -n "$IWPRIV" && "$IWPRIV" $DEV SetLEDPower 0
if test $USE_DHCP -eq 1; then
# fetch an IP address from DHCP
rm -f /etc/dhcpc/dhcpcd-$DEV.pid > /dev/null
dhcpcd -d $DEV -t 5
# OR
# pump -i $DEV
else
# Hehe, this can be done after iwconfigs now :)
$IFCONF $DEV $IP netmask $NETMASK
if test "$?" != "0"; then echo "Error in \"$IFCONF $DEV $IP netmask $NETMASK\". Bailing..."; exit 1; else echo "Interface has been set up successfully."; fi
test -n "$GATEWAY" && $ROUTE add default gw $GATEWAY
fi
# Finally, if you have any buffer management problems report us before
#$IFCONF $DEV mtu 576
#if test "$?" != "0"; then echo "Error in \"$IFCONF $DEV mtu 576\". Bailing..."; exit 1; fi
# just in case ;)
$SYNC
Spróbuj zmienić:
ALG=open na ALG=restricted
a jak będzie nadal tak samo to zmień znowu na ALG=open a naspępnie zrób tak jak jest u mnie:
2.4*)
MODULE_AT="/home/piotrek/WLAN/module/acx100_pci.ko"
oczywiście ten moduł musi mieć taką nazwę więc najpierw sprawdź w /home/piotrek/WLAN/module/
a jak ma inną to zmień.
no więc działa :) ale nie wszystko czyli:
1. działa siec czyli mogę pingować server ale na stronki nie wchodzi
2. pod zwykłym userem nie działa nic ---wywala z błędem że chce uprawnienia root_a
Dodam że w resolv.conf (tak chyba sie to pisało) wpisałem IP servera bo działa jako serwer DNS też oraz 2 inne dodatkowe jakie podał moj provider.
Czy można w tym pliku wpisać IP bez nazwy servera ?
Mam nadzieję że się w tym połapiecie co nabazgrałem :)
