neo-one Napisano Luty 26, 2008 Zgłoszenie Share Napisano Luty 26, 2008 Witam. Grzebie sobie wlasnie w iptables i mam problem ... :lammer: Mianowicie -ping w sieci lokalnej dziala -ping na IP w internecie dziala -ping na domene nie dziala (ping google.com -->nic, elinks google.com --> nic) Wnioskuje ze problem z przepuszczaniem odpowiedzi DNS w zwiazku z tym pytanie jaki porty odblokowac w iptables zeby poszlo ?? Moja Konfiguracja: [root@localhost etc]# iptables -L -v Chain INPUT (policy DROP 166 packets, 17950 bytes) pkts bytes target prot opt in out source destination ACCEPT all -- lo any anywhere anywhere ACCEPT udp -- any any anywhere anywhere udp dpt:domain ACCEPT tcp -- any any anywhere anywhere tcp dpt:domain ACCEPT tcp -- any any anywhere anywhere tcp dpt:http ACCEPT tcp -- any any anywhere anywhere tcp dpt:https ACCEPT tcp -- any any anywhere anywhere tcp dpt:ssh ACCEPT icmp -- any any anywhere anywhere icmp echo-request ACCEPT icmp -- any any anywhere anywhere icmp echo-reply Chain FORWARD (policy ACCEPT 0 packets, 0 bytes) pkts bytes target prot opt in out source destination Chain OUTPUT (policy ACCEPT 6012 packets, 713K bytes) pkts bytes target prot opt in out source destination [root@localhost etc]# cat /home/iptables-save_3 # Generated by iptables-save v1.3.5 on Tue Feb 26 23:10:50 2008 *filter :INPUT DROP [166:17950] :FORWARD ACCEPT [0:0] :OUTPUT ACCEPT [5992:710494] -A INPUT -i lo -j ACCEPT -A INPUT -p udp -m udp --dport 53 -j ACCEPT -A INPUT -p tcp -m tcp --dport 53 -j ACCEPT -A INPUT -p tcp -m tcp --dport 80 -j ACCEPT -A INPUT -p tcp -m tcp --dport 443 -j ACCEPT -A INPUT -p tcp -m tcp --dport 22 -j ACCEPT -A INPUT -p icmp -m icmp --icmp-type 8 -j ACCEPT -A INPUT -p icmp -m icmp --icmp-type 0 -j ACCEPT COMMIT # Completed on Tue Feb 26 23:10:50 2008 komp podlaczony do routera /DHCP,DNS/ Nie ma zadnego GUI wiec rozwiazania klikane odpadaja !! ps: Jesli wylacze Firewall wszystko dziala jak nalezy. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Luty 26, 2008 Zgłoszenie Share Napisano Luty 26, 2008 a czy na inpucie nie powinno być czasem --sport, czyli z którego portu ma wpuszczać połączenia? Spróbuj może z #dns -A INPUT -p udp -m udp --sport 53 --dport 1024:65535 -j ACCEPT -A INPUT -p tcp -m tcp --sport 53 --dport 1024:65535 -j ACCEPT U mnie przynajmniej coś takiego działa bez problemów. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
neo-one Napisano Luty 27, 2008 Autor Zgłoszenie Share Napisano Luty 27, 2008 OK 1. PING na domeny dziala 2. elinks nie chce sie polaczyc z domene ani z ip mimo ze port 80 jest otwarty dla przychodzacych pakietow .. /Making Connection i nic wiecej/ Obecny config iptables: Chain INPUT (policy DROP) target prot opt source destination ACCEPT all -- anywhere anywhere ACCEPT udp -- anywhere anywhere udp dpt:http ACCEPT tcp -- anywhere anywhere tcp dpt:http ACCEPT tcp -- anywhere anywhere tcp dpt:ssh ACCEPT icmp -- anywhere anywhere icmp echo-request ACCEPT icmp -- anywhere anywhere icmp echo-reply ACCEPT udp -- anywhere anywhere udp spt:domain dpts:1024:65535 ACCEPT tcp -- anywhere anywhere tcp spt:domain dpts:1024:65535 ACCEPT tcp -- anywhere anywhere tcp dpt:bootpc Chain FORWARD (policy ACCEPT) target prot opt source destination Chain OUTPUT (policy ACCEPT) wie ktos moze jak to naprawic ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Luty 27, 2008 Zgłoszenie Share Napisano Luty 27, 2008 #zezwalamy na trwające sesje (koniecznie na początku łańcucha INPUT) -A INPUT -p tcp -m state --state RELATED,ESTABLISHED -j ACCEPT #wpuszczamy http -A INPUT -p tcp -m tcp --sport 80 -m state --state NEW -j ACCEPT A z tym ? Zainstalowałem elinksa żeby sprawdzić i wygląda że działa. Dodatkowo jak chcesz żeby po otwartych portach nikt nie wykonał jakichś dziwnych sekwencji flag innych niż SYN->ACK,SYN->ACK możesz też je poblokować, u mnie np funkcjonuje coś takiego: -A INPUT -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,PSH,URG -j DROP -A INPUT -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG NONE -j DROP -A INPUT -m state --state NEW -p tcp --tcp-flags SYN,RST,ACK,FIN,URG,PSH ACK -j DROP -A INPUT -m state --state NEW -p tcp --tcp-flags SYN,RST,ACK,FIN,URG,PSH FIN -j DROP -A INPUT -m state --state NEW -p tcp --tcp-flags SYN,RST,ACK,FIN,URG,PSH FIN,URG,PSH -j DROP -A INPUT -m state --state INVALID -p tcp --tcp-flags ! SYN,RST,ACK,FIN,PSH,URG SYN,RST,ACK,FIN,PSH,URG -j DROP -A INPUT -p tcp -m tcp --tcp-flags SYN,RST SYN,RST -j DROP -A INPUT -p tcp -m tcp --tcp-flags FIN,SYN FIN,SYN -j DROP ps. jak ktoś ma jeszcze jakieś sugestie to chętnie wysłucham :-) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
neo-one Napisano Luty 28, 2008 Autor Zgłoszenie Share Napisano Luty 28, 2008 Pozmienialem --dport (porty docelowe) na --sport (porty zrodlowe) i dziala. Jednak czy takie rozwiazanie nie zostawia otwartych portow na mojej masynie? np: ACCEPT udp -- anywhere anywhere udp spt:domain dpts:1024:65535 zezwala na polaczenie ze zdalnego portu 53 na ktorykolwiek port z zakresu od 1024 do 65535 tak ? Czy cos zle zrozumialem? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Adi1981 Napisano Luty 28, 2008 Zgłoszenie Share Napisano Luty 28, 2008 Owszem, dlatego też można dodatkowo zabzpieczyć system przez blokowanie sekwencji flag. Ogólnie nie nie pamiętam dokładnie, ale dns chyba odsyła odpowiedź właśnie na wysokie porty, można by sprawdzić wiresharkiem jak to się odbywa i wtedy ewentualnie skorygować. Przydatne okazuje się tutaj też google. Ażeby bardziej zabezpieczyć się możesz też ewentualnie do regułki dodać jako źródło IP serwera DNS z którego korzystasz. No i dobrze jest też imo OUTPUT ustawić na politykę DROP, żeby niedopuszczać do wysłania jakichś dziwnych zapytań. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
neo-one Napisano Luty 28, 2008 Autor Zgłoszenie Share Napisano Luty 28, 2008 Wpadlem chwile wczesniej na zastosowanie sniffera DNS odsyla odpowiedzi na port UDP 1034 Pokombinowalem jeszcze troche i skan nmapem pokazuje mi ze mam otwarty jedynie port ssh /22/ i httpd /80/ i o to mi chodzilo! Chyba zaczynam lapac co i jak z iptables ale jeszcze dloga droga przedemna Nadszedl czas zeby zucic okiem na regolki z flagami ... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
