daf Napisano Kwiecień 2, 2008 Zgłoszenie Share Napisano Kwiecień 2, 2008 witam, zainspirowany tym watkiem postanowilem odpalic smartctl na swoim 4-letnim dysku w kompie stacjonarnym. zauwazylem, ze w moim przypadku VALUE zbliza sie do THRESH i to baaaardzo. dodatkowo, mam errory. czy moglbym prosic kogos kto sie na tym zna o rzucenie okiem na moje wyniki? wolalbym miec chwilke na zgranie danych:) smartctl version 5.37 [i386-redhat-linux-gnu] Copyright © 2002-6 Bruce Allen Home page is http://smartmontools.sourceforge.net/ === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 7200.7 and 7200.7 Plus family Device Model: ST3120827AS Serial Number: 3MS01AXM Firmware Version: 3.42 User Capacity: 120,034,123,776 bytes Device is: In smartctl database [for details use: -P show] ATA Version is: 6 ATA Standard is: ATA/ATAPI-6 T13 1410D revision 2 Local Time is: Wed Apr 2 23:02:23 2008 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 430) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. No General Purpose Logging support. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 71) minutes. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 054 050 006 Pre-fail Always - 230667046 3 Spin_Up_Time 0x0003 096 096 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 099 099 020 Old_age Always - 1776 5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 086 060 030 Pre-fail Always - 441208898 9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 10141 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 099 099 020 Old_age Always - 1768 194 Temperature_Celsius 0x0022 043 054 000 Old_age Always - 43 (Lifetime Min/Max 0/16) 195 Hardware_ECC_Recovered 0x001a 054 049 000 Old_age Always - 230667046 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 193 000 Old_age Always - 13 200 Multi_Zone_Error_Rate 0x0000 100 253 000 Old_age Offline - 0 202 TA_Increase_Count 0x0032 100 253 000 Old_age Always - 0 SMART Error Log Version: 1 ATA Error Count: 12 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 12 occurred at disk power-on lifetime: 3053 hours (127 days + 5 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 51 5b 0d 9f 02 ed Error: ABRT at LBA = 0x0d029f0d = 218275597 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 20 00 00 68 9e 02 ed 00 05:08:52.880 READ SECTOR(S) 20 00 00 68 9d 02 ed 00 05:08:52.875 READ SECTOR(S) 20 00 00 68 9c 02 ed 00 05:08:52.836 READ SECTOR(S) 20 00 78 68 44 9d ec 00 05:08:52.795 READ SECTOR(S) 20 00 00 68 43 9d ec 00 05:08:52.780 READ SECTOR(S) Error 11 occurred at disk power-on lifetime: 3052 hours (127 days + 4 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 51 15 aa b3 55 e0 Error: ABRT at LBA = 0x0055b3aa = 5616554 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 20 00 80 3f b3 55 e0 00 03:48:43.170 READ SECTOR(S) 20 00 80 bf b2 55 e0 00 03:48:41.855 READ SECTOR(S) 20 00 80 3f b2 55 e0 00 03:48:41.854 READ SECTOR(S) 20 00 58 e7 b1 55 e0 00 03:48:41.849 READ SECTOR(S) 20 00 28 5f 20 4d e0 00 03:48:37.542 READ SECTOR(S) Error 10 occurred at disk power-on lifetime: 3048 hours (127 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 51 70 5a 08 9e e1 Error: ABRT at LBA = 0x019e085a = 27134042 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 20 00 81 49 08 9e e1 00 00:19:53.814 READ SECTOR(S) 30 00 80 97 cd 9d e1 00 00:19:53.808 WRITE SECTOR(S) 20 00 08 c7 3b 00 e0 00 00:19:53.800 READ SECTOR(S) 20 00 10 47 45 64 e2 00 00:19:53.779 READ SECTOR(S) 20 00 08 6f 0c 34 e2 00 00:19:53.925 READ SECTOR(S) Error 9 occurred at disk power-on lifetime: 3048 hours (127 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 51 70 f8 ff ff ef Error: ABRT at LBA = 0x0ffffff8 = 268435448 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c4 00 7f 28 46 2c ed 00 00:12:47.015 READ MULTIPLE c4 00 7f a9 45 2c ed 00 00:12:46.605 READ MULTIPLE c4 00 7f 2a 45 2c ed 00 00:12:46.099 READ MULTIPLE c4 00 73 b7 44 2c ed 00 00:12:45.900 READ MULTIPLE c4 00 7f 38 44 2c ed 00 00:12:45.867 READ MULTIPLE Error 8 occurred at disk power-on lifetime: 3048 hours (127 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 51 5f a9 44 6f e8 Error: ICRC, ABRT 95 sectors at LBA = 0x086f44a9 = 141509801 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 80 88 44 6f e8 00 00:11:54.556 READ DMA c8 00 80 08 44 6f e8 00 00:11:54.554 READ DMA ca 00 10 ef 43 91 e1 00 00:11:54.553 WRITE DMA c8 00 80 88 43 6f e8 00 00:11:54.552 READ DMA c8 00 80 08 43 6f e8 00 00:11:54.551 READ DMA SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. zalaczam tez lspci 00:00.0 Host bridge: Intel Corporation 82915G/P/GV/GL/PL/910GL Memory Controller Hub (rev 04) 00:01.0 PCI bridge: Intel Corporation 82915G/P/GV/GL/PL/910GL PCI Express Root Port (rev 04) 00:1b.0 Audio device: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller (rev 03) 00:1c.0 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 1 (rev 03) 00:1c.1 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 2 (rev 03) 00:1d.0 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 03) 00:1d.1 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 03) 00:1d.2 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 03) 00:1d.3 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev 03) 00:1d.7 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 03) 00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev d3) 00:1f.0 ISA bridge: Intel Corporation 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge (rev 03) 00:1f.1 IDE interface: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller (rev 03) 00:1f.2 IDE interface: Intel Corporation 82801FR/FRW (ICH6R/ICH6RW) SATA Controller (rev 03) 00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 03) 02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8053 PCI-E Gigabit Ethernet Controller (rev 15) 04:00.0 VGA compatible controller: nVidia Corporation NV43 [GeForce 6600] (rev a2) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
daf Napisano Kwiecień 5, 2008 Autor Zgłoszenie Share Napisano Kwiecień 5, 2008 (na zagranicznych forach jest 'bump' wiec 'wymyslilem' polski odpowiednik) bum czy nikt nie potrafi mi pomoc w tym temacie? bardzo prosze. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
