lwg Napisano Kwiecień 12, 2008 Zgłoszenie Share Napisano Kwiecień 12, 2008 witam, mam problem z instalacja gier pod fedore 8. Próbowalem uruchomic Fallouta 2, Syberie 1 i 2 i gta vice city i z kazda z nich jest problem. Fallout startuje sie czesto sie wiesza i mozna go tylko skilowac. Syberia zatrzymuje sie na intrze (nie ma obrazu, tylko dzwiek) i tez tylko kill. GTA VC po uruchumieni z konsoli wine daje cos takiego: $ wine gta-vc.exe ALSA lib pcm.c:2106:(snd_pcm_open_conf) Cannot open shared library /usr/lib/alsa-lib/libasound_module_pcm_pulse.so ALSA lib pcm.c:2106:(snd_pcm_open_conf) Cannot open shared library /usr/lib/alsa-lib/libasound_module_pcm_pulse.so fixme:process:IsWow64Process (0xffffffff 0x14cad34) stub! fixme:process:IsWow64Process (0xffffffff 0x14ca85c) stub! fixme:process:IsWow64Process (0xffffffff 0x14ca85c) stub! fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_HANDLE_INFORMATION fixme:ntdll:NtQueryObject Unsupported information class 3 fixme:debugstr:CheckRemoteDebuggerPresent (0xffffffff)->(0x14c940c): Stub! fixme:win:EnumDisplayDevicesW ((null),0,0x14c9270,0x00000000), stub! fixme:d3d:test_pbo_functionality >>>>>>>>>>>>>>>>> GL_INVALID_OPERATION (0x502) from Loading the PBO test texture @ directx.c / 3512 fixme:psapi:EnumPageFilesA (0xd62950, 0x14a9d20) stub fixme:psapi:EnumPageFilesA (0xd62950, 0x147463c) stub fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:process:IsWow64Process (0xffffffff 0x149c41c) stub! fixme:process:IsWow64Process (0xffffffff 0x149c550) stub! fixme:process:IsWow64Process (0xffffffff 0x149c550) stub! fixme:process:IsWow64Process (0xffffffff 0x149c550) stub! fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_HANDLE_INFORMATION fixme:ntdll:NtQueryInformationProcess (process=0xffffffff) Unimplemented information class: ProcessDeviceMap fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:ntdll:NtQuerySystemInformation (0x00000007,0x14a1f8c,0x00000018,(nil)) stub fixme:ntdll:server_ioctl_file Unsupported ioctl 4d0008 (device=4d access=0 func=2 method=0) fixme:cursor:SetSystemCursor (0x10de,00007f00),stub! fixme:cursor:CURSORICON_LoadFromFile No support for .ani cursors. fixme:cursor:SetSystemCursor (0x10de,00007f00),stub! fixme:cursor:SetSystemCursor (0x113e,00007f8a),stub! fixme:cursor:SetSystemCursor (0x1146,00007f00),stub! fixme:cursor:SetSystemCursor (0x1156,00007f03),stub! fixme:cursor:SetSystemCursor (0x115e,00007f01),stub! fixme:cursor:SetSystemCursor (0x116e,00007f88),stub! fixme:cursor:SetSystemCursor (0x117e,00007f86),stub! fixme:cursor:SetSystemCursor (0x118e,00007f83),stub! fixme:cursor:SetSystemCursor (0x119e,00007f85),stub! fixme:cursor:SetSystemCursor (0x11ae,00007f82),stub! fixme:cursor:SetSystemCursor (0x11be,00007f84),stub! fixme:cursor:SetSystemCursor (0x11ce,00007f04),stub! fixme:cursor:SetSystemCursor (0x11de,00007f02),stub! fixme:process:IsWow64Process (0xffffffff 0x14df93c) stub! fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_HANDLE_INFORMATION fixme:ntdll:NtQueryObject Unsupported information class 3 fixme:debugstr:CheckRemoteDebuggerPresent (0xffffffff)->(0x14df93c): Stub! fixme:system:SystemParametersInfoW Unimplemented action: 8193 (SPI_SETFOREGROUNDLOCKTIMEOUT) wine: Unhandled page fault on execute access to 0x01c70076 at address 0x1c70076 (thread 0029), starting debugger... Unhandled exception: page fault on execute access to 0x01c70076 in 32-bit code (0x01c70076). Register dump: CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b EIP:01c70076 ESP:014df5fc EBP:014df650 EFLAGS:00010202( - 00 - -RI1) EAX:01c70076 EBX:00000002 ECX:014df6e8 EDX:00789fd0 ESI:00138a48 EDI:4c99287e Stack dump: 0x014df5fc: 00c88527 4c99287e 00002fe7 01285efb 0x014df60c: 00000002 00131e28 00000000 00000028 0x014df61c: 00000000 00131e28 014df6ec 014df668 0x014df62c: 7e99f15a 00050024 fffffff0 00000001 0x014df63c: 00000000 00000000 00000288 000001db 0x014df64c: 00000000 014df6ac 00c88672 00138a48 Backtrace: =>1 0x01c70076 (0x014df650) 2 0x00c88672 in gta-vc (+0x888672) (0x014df6ac) 3 0x00a2107a in gta-vc (+0x62107a) (0x7e7b2600) 4 0x7e78f8a0 IDirectInputDevice2AImpl_AddRef() in dinput (0x7e792d50) 5 0xfce85356 (0x57e58955) 6 0x00000000 (0x00000000) 0x01c70076: xorl $0x2a38,0x4(%esp) Modules: Module Address Debug info Name (95 modules) ELF 101000- 115000 Deferred libresolv.so.2 ELF 13b000- 16a000 Deferred libfontconfig.so.1 ELF 16c000- 1f8000 Deferred libfreetype.so.6 ELF 1fa000- 203000 Deferred libsm.so.6 ELF 205000- 21f000 Deferred libice.so.6 ELF 370000- 391000 Deferred libexpat.so.1 PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc ELF 3ade000- 3bbd000 Deferred libasound.so.2 PE 21100000-2115c000 Deferred mss32 ELF 7bf00000-7bf03000 Deferred <wine-loader> ELF 7bf4c000-7bf61000 Deferred psapi<elf> \-PE 7bf50000-7bf61000 \ psapi ELF 7bf61000-7bf7f000 Deferred imm32<elf> \-PE 7bf70000-7bf7f000 \ imm32 ELF 7cd02000-7dd0d000 Deferred fglrx_dri.so ELF 7ddbe000-7ddf2000 Deferred d3d9<elf> \-PE 7ddd0000-7ddf2000 \ d3d9 ELF 7de16000-7de49000 Deferred uxtheme<elf> \-PE 7de20000-7de49000 \ uxtheme ELF 7de69000-7de91000 Deferred msacm32<elf> \-PE 7de70000-7de91000 \ msacm32 ELF 7df7b000-7df90000 Deferred midimap<elf> \-PE 7df80000-7df90000 \ midimap ELF 7df90000-7dfc6000 Deferred winealsa<elf> \-PE 7dfa0000-7dfc6000 \ winealsa ELF 7e11e000-7e123000 Deferred libxxf86vm.so.1 ELF 7e14b000-7e163000 Deferred msacm32<elf> \-PE 7e150000-7e163000 \ msacm32 ELF 7e166000-7e1fc000 Deferred winex11<elf> \-PE 7e170000-7e1fc000 \ winex11 ELF 7e30f000-7e323000 Deferred lz32<elf> \-PE 7e310000-7e323000 \ lz32 ELF 7e323000-7e33d000 Deferred version<elf> \-PE 7e330000-7e33d000 \ version ELF 7e33d000-7e405000 Deferred comctl32<elf> \-PE 7e350000-7e405000 \ comctl32 ELF 7e405000-7e462000 Deferred shlwapi<elf> \-PE 7e410000-7e462000 \ shlwapi ELF 7e462000-7e574000 Deferred shell32<elf> \-PE 7e470000-7e574000 \ shell32 ELF 7e574000-7e673000 Deferred wined3d<elf> \-PE 7e590000-7e673000 \ wined3d ELF 7e673000-7e6a1000 Deferred d3d8<elf> \-PE 7e680000-7e6a1000 \ d3d8 ELF 7e6a1000-7e6cf000 Deferred ws2_32<elf> \-PE 7e6b0000-7e6cf000 \ ws2_32 ELF 7e6cf000-7e6e9000 Deferred wsock32<elf> \-PE 7e6d0000-7e6e9000 \ wsock32 ELF 7e6e9000-7e77b000 Deferred winmm<elf> \-PE 7e6f0000-7e77b000 \ winmm ELF 7e77b000-7e7b4000 Export dinput<elf> \-PE 7e780000-7e7b4000 \ dinput ELF 7e7d0000-7e7e8000 Deferred dinput8<elf> \-PE 7e7e0000-7e7e8000 \ dinput8 ELF 7e7e8000-7e807000 Deferred iphlpapi<elf> \-PE 7e7f0000-7e807000 \ iphlpapi ELF 7e807000-7e86b000 Deferred rpcrt4<elf> \-PE 7e810000-7e86b000 \ rpcrt4 ELF 7e86b000-7e90e000 Deferred gdi32<elf> \-PE 7e880000-7e90e000 \ gdi32 ELF 7e90e000-7ea60000 Deferred user32<elf> \-PE 7e930000-7ea60000 \ user32 ELF 7ea60000-7eb10000 Deferred ole32<elf> \-PE 7ea70000-7eb10000 \ ole32 ELF 7eb10000-7eb6c000 Deferred ddraw<elf> \-PE 7eb20000-7eb6c000 \ ddraw ELF 7eb6c000-7eb70000 Deferred iso8859-2.so ELF 7eb77000-7ebc7000 Deferred advapi32<elf> \-PE 7eb80000-7ebc7000 \ advapi32 ELF 7edc7000-7ef00000 Deferred kernel32<elf> \-PE 7ede0000-7ef00000 \ kernel32 ELF 7ef00000-7ef0c000 Deferred libnss_files.so.2 ELF 7ef55000-7f000000 Deferred ntdll<elf> \-PE 7ef70000-7f000000 \ ntdll Threads: process tid prio (all id:s are in hex) 00000008 00000009 0 0000000a 0000000b 0 0000000c 0000000f 0 0000000e 0 0000000d 0 00000010 00000012 0 00000011 0 00000028 (D) Z:\home\lwg\gry\gta\gta-vc.exe 00000032 0 00000031 -1 00000029 0 <== Backtrace: =>1 0x01c70076 (0x014df650) 2 0x00c88672 in gta-vc (+0x888672) (0x014df6ac) 3 0x00a2107a in gta-vc (+0x62107a) (0x7e7b2600) 4 0x7e78f8a0 IDirectInputDevice2AImpl_AddRef() in dinput (0x7e792d50) 5 0xfce85356 (0x57e58955) 6 0x00000000 (0x00000000) [lwg@localhost gta]$ wine gta-vc.exe fixme:midi:OSS_MidiInit Synthesizer supports MIDI in. Not yet supported. fixme:process:IsWow64Process (0xffffffff 0x14cad34) stub! fixme:process:IsWow64Process (0xffffffff 0x14ca85c) stub! fixme:process:IsWow64Process (0xffffffff 0x14ca85c) stub! fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_HANDLE_INFORMATION fixme:ntdll:NtQueryObject Unsupported information class 3 fixme:debugstr:CheckRemoteDebuggerPresent (0xffffffff)->(0x14c940c): Stub! fixme:win:EnumDisplayDevicesW ((null),0,0x14c9270,0x00000000), stub! fixme:d3d:test_pbo_functionality >>>>>>>>>>>>>>>>> GL_INVALID_OPERATION (0x502) from Loading the PBO test texture @ directx.c / 3512 fixme:psapi:EnumPageFilesA (0xd62950, 0x14a9d20) stub fixme:psapi:EnumPageFilesA (0xd62950, 0x147463c) stub fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:process:IsWow64Process (0xffffffff 0x149c41c) stub! fixme:process:IsWow64Process (0xffffffff 0x149c550) stub! fixme:process:IsWow64Process (0xffffffff 0x149c550) stub! fixme:process:IsWow64Process (0xffffffff 0x149c550) stub! fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_HANDLE_INFORMATION fixme:ntdll:NtQueryInformationProcess (process=0xffffffff) Unimplemented information class: ProcessDeviceMap fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:process:IsWow64Process (0xffffffff 0x1061c43) stub! fixme:ntdll:NtQuerySystemInformation (0x00000007,0x14a1f8c,0x00000018,(nil)) stub fixme:ntdll:server_ioctl_file Unsupported ioctl 4d0008 (device=4d access=0 func=2 method=0) fixme:cursor:SetSystemCursor (0x10de,00007f00),stub! fixme:cursor:CURSORICON_LoadFromFile No support for .ani cursors. fixme:cursor:SetSystemCursor (0x10de,00007f00),stub! fixme:cursor:SetSystemCursor (0x113e,00007f8a),stub! fixme:cursor:SetSystemCursor (0x1146,00007f00),stub! fixme:cursor:SetSystemCursor (0x1156,00007f03),stub! fixme:cursor:SetSystemCursor (0x115e,00007f01),stub! fixme:cursor:SetSystemCursor (0x116e,00007f88),stub! fixme:cursor:SetSystemCursor (0x117e,00007f86),stub! fixme:cursor:SetSystemCursor (0x118e,00007f83),stub! fixme:cursor:SetSystemCursor (0x119e,00007f85),stub! fixme:cursor:SetSystemCursor (0x11ae,00007f82),stub! fixme:cursor:SetSystemCursor (0x11be,00007f84),stub! fixme:cursor:SetSystemCursor (0x11ce,00007f04),stub! fixme:cursor:SetSystemCursor (0x11de,00007f02),stub! fixme:process:IsWow64Process (0xffffffff 0x14df93c) stub! fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_HANDLE_INFORMATION fixme:ntdll:NtQueryObject Unsupported information class 3 fixme:debugstr:CheckRemoteDebuggerPresent (0xffffffff)->(0x14df93c): Stub! fixme:system:SystemParametersInfoW Unimplemented action: 8193 (SPI_SETFOREGROUNDLOCKTIMEOUT) wine: Unhandled page fault on execute access to 0x01cb00bb at address 0x1cb00bb (thread 0039), starting debugger... Unhandled exception: page fault on execute access to 0x01cb00bb in 32-bit code (0x01cb00bb). Register dump: CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b EIP:01cb00bb ESP:014df5fc EBP:014df650 EFLAGS:00010206( - 00 - RIP1) EAX:01cb00bb EBX:00000002 ECX:014df6e8 EDX:00789fd0 ESI:0012f998 EDI:4c952835 Stack dump: 0x014df5fc: 00c88527 4c952835 00002fe7 01285efb 0x014df60c: 00000002 00129cd8 00000000 00000038 0x014df61c: 00000000 00129cd8 014df6ec 014df668 0x014df62c: 7e99f15a 0001011a fffffff0 00000001 0x014df63c: 00000000 00000000 00000288 000001db 0x014df64c: 00000000 014df6ac 00c88672 0012f998 Backtrace: =>1 0x01cb00bb (0x014df650) 2 0x00c88672 in gta-vc (+0x888672) (0x014df6ac) 3 0x00a2107a in gta-vc (+0x62107a) (0x7e7b2600) 4 0x7e78f8a0 IDirectInputDevice2AImpl_AddRef() in dinput (0x7e792d50) 5 0xfce85356 (0x57e58955) 6 0x00000000 (0x00000000) 0x01cb00bb: xorl $0x2a38,0x4(%esp) Modules: Module Address Debug info Name (94 modules) ELF 101000- 115000 Deferred libresolv.so.2 ELF 13b000- 16a000 Deferred libfontconfig.so.1 ELF 16c000- 1f8000 Deferred libfreetype.so.6 ELF 1fa000- 203000 Deferred libsm.so.6 ELF 205000- 21f000 Deferred libice.so.6 ELF 370000- 391000 Deferred libexpat.so.1 PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 400000- 12ca000 Export gta-vc PE 21100000-2115c000 Deferred mss32 ELF 7bf00000-7bf03000 Deferred <wine-loader> ELF 7bfcd000-7bfe2000 Deferred psapi<elf> \-PE 7bfd0000-7bfe2000 \ psapi ELF 7bfe2000-7c000000 Deferred imm32<elf> \-PE 7bff0000-7c000000 \ imm32 ELF 7cddd000-7dde8000 Deferred fglrx_dri.so ELF 7de99000-7decd000 Deferred d3d9<elf> \-PE 7dea0000-7decd000 \ d3d9 ELF 7defa000-7df2d000 Deferred uxtheme<elf> \-PE 7df00000-7df2d000 \ uxtheme ELF 7df4d000-7df62000 Deferred midimap<elf> \-PE 7df50000-7df62000 \ midimap ELF 7df62000-7df8a000 Deferred msacm32<elf> \-PE 7df70000-7df8a000 \ msacm32 ELF 7df8a000-7dfc6000 Deferred wineoss<elf> \-PE 7df90000-7dfc6000 \ wineoss ELF 7e11e000-7e123000 Deferred libxxf86vm.so.1 ELF 7e14c000-7e164000 Deferred msacm32<elf> \-PE 7e150000-7e164000 \ msacm32 ELF 7e166000-7e1fc000 Deferred winex11<elf> \-PE 7e170000-7e1fc000 \ winex11 ELF 7e30f000-7e323000 Deferred lz32<elf> \-PE 7e310000-7e323000 \ lz32 ELF 7e323000-7e33d000 Deferred version<elf> \-PE 7e330000-7e33d000 \ version ELF 7e33d000-7e405000 Deferred comctl32<elf> \-PE 7e350000-7e405000 \ comctl32 ELF 7e405000-7e462000 Deferred shlwapi<elf> \-PE 7e410000-7e462000 \ shlwapi ELF 7e462000-7e574000 Deferred shell32<elf> \-PE 7e470000-7e574000 \ shell32 ELF 7e574000-7e673000 Deferred wined3d<elf> \-PE 7e590000-7e673000 \ wined3d ELF 7e673000-7e6a1000 Deferred d3d8<elf> \-PE 7e680000-7e6a1000 \ d3d8 ELF 7e6a1000-7e6cf000 Deferred ws2_32<elf> \-PE 7e6b0000-7e6cf000 \ ws2_32 ELF 7e6cf000-7e6e9000 Deferred wsock32<elf> \-PE 7e6d0000-7e6e9000 \ wsock32 ELF 7e6e9000-7e77b000 Deferred winmm<elf> \-PE 7e6f0000-7e77b000 \ winmm ELF 7e77b000-7e7b4000 Export dinput<elf> \-PE 7e780000-7e7b4000 \ dinput ELF 7e7d0000-7e7e8000 Deferred dinput8<elf> \-PE 7e7e0000-7e7e8000 \ dinput8 ELF 7e7e8000-7e807000 Deferred iphlpapi<elf> \-PE 7e7f0000-7e807000 \ iphlpapi ELF 7e807000-7e86b000 Deferred rpcrt4<elf> \-PE 7e810000-7e86b000 \ rpcrt4 ELF 7e86b000-7e90e000 Deferred gdi32<elf> \-PE 7e880000-7e90e000 \ gdi32 ELF 7e90e000-7ea60000 Deferred user32<elf> \-PE 7e930000-7ea60000 \ user32 ELF 7ea60000-7eb10000 Deferred ole32<elf> \-PE 7ea70000-7eb10000 \ ole32 ELF 7eb10000-7eb6c000 Deferred ddraw<elf> \-PE 7eb20000-7eb6c000 \ ddraw ELF 7eb6c000-7eb70000 Deferred iso8859-2.so ELF 7eb77000-7ebc7000 Deferred advapi32<elf> \-PE 7eb80000-7ebc7000 \ advapi32 ELF 7edc7000-7ef00000 Deferred kernel32<elf> \-PE 7ede0000-7ef00000 \ kernel32 ELF 7ef00000-7ef0c000 Deferred libnss_files.so.2 ELF 7ef55000-7f000000 Deferred ntdll<elf> \-PE 7ef70000-7f000000 \ ntdll Threads: process tid prio (all id:s are in hex) 00000008 00000009 0 0000000a 0000000b 0 0000000c 0000000f 0 0000000e 0 0000000d 0 00000010 00000012 0 00000011 0 00000035 00000036 0 00000038 (D) Z:\home\lwg\gry\gta\gta-vc.exe 00000042 0 00000041 -1 00000039 0 <== Backtrace: =>1 0x01cb00bb (0x014df650) 2 0x00c88672 in gta-vc (+0x888672) (0x014df6ac) 3 0x00a2107a in gta-vc (+0x62107a) (0x7e7b2600) 4 0x7e78f8a0 IDirectInputDevice2AImpl_AddRef() in dinput (0x7e792d50) 5 0xfce85356 (0x57e58955) 6 0x00000000 (0x00000000) nie wiem co zle robie, nie mam duzego doswiadczenie w Linuksie, i nie bardzo orientuje sie co moze byc tego przyczyna. Pod win XP który tez mam na tym kompie wszystko chodzi bez problemów wiec to nie wina sprzetu. Próbowalem tez instalacji z cedega i efekt taki sam. ----------------- Przy długich listingach należy stosować znaczniki "codebox". WalDo -sory, nie wiedzialem:P Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kalashnikov Napisano Kwiecień 12, 2008 Zgłoszenie Share Napisano Kwiecień 12, 2008 Na początek daj wynik polecenia rpm -qa | grep wine rpm -qa | grep kernel oraz glxinfo | grep rendering Dobrze by było gdybyś podał model karty graficznej, oraz czy instalowałeś do niej jakieś sterowniki. Według "Wine AppDB" ze wszystkimi tymi grami nie powinno być większych problemów z wyjątkiem "Syberii", żeby działała "jako-tako" gra powinna być w wersji 1.0. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lwg Napisano Kwiecień 12, 2008 Autor Zgłoszenie Share Napisano Kwiecień 12, 2008 Na początek daj wynik polecenia rpm -qa | grep wine rpm -qa | grep kernel oraz glxinfo | grep rendering $ rpm -qa | grep wine wine-core-0.9.58-1.fc8 wine-cms-0.9.58-1.fc8 wine-jack-0.9.58-1.fc8 wine-twain-0.9.58-1.fc8 wine-tools-0.9.58-1.fc8 wine-ldap-0.9.58-1.fc8 wine-0.9.58-1.fc8 wine-nas-0.9.58-1.fc8 wine-esd-0.9.58-1.fc8 wine-capi-0.9.58-1.fc8 $ rpm -qa | grep kernel kernel-headers-2.6.24.4-64.fc8 kernel-2.6.24.3-50.fc8 kernel-devel-2.6.24.4-64.fc8 kernel-2.6.24.4-64.fc8 kernel-devel-2.6.24.3-50.fc8 $ glxinfo | grep rendering direct rendering: Yes Dobrze by było gdybyś podał model karty graficznej, oraz czy instalowałeś do niej jakieś sterowniki. ati radeon X600, instalowalem sterowniki wg watku na forum, nie pamietam wg którego, ale instalacja poszla zgodnie z opisem wiec chyba wszystko ok. Mam tez zainstalowany Ati catalyst control center Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kalashnikov Napisano Kwiecień 12, 2008 Zgłoszenie Share Napisano Kwiecień 12, 2008 Jedyne co mogę Ci poradzić to sprawdzenie tego pod starszym wine. Sam też mam taki problem, że każdy (może nie każdy, ale ten z RPM fedory owszem) nowszy wine niż 0.9.47 sprawia identyczne problemy. Jak Cię to interesuje to: Usuń aktualne wine yum remove wine-core wine-cms wine-jack wine-twain wine-tools wine-ldap wine wine-nas wine-esd wine-capi Ściągnij starsze wget http://download.fedora.redhat.com/pub/fedora/linux/releases/8/Everything/i386/os/Packages/wine-0.9.47-1.fc8.i386.rpm Zainstaluj yum localinstall wine-0.9.47-1.fc8.i386.rpm Dalej Yum sam powinien ściągnąć i zainstalować resztę pakietów. Jak dalej nie pomoże, to będziesz mógł bez problemu wrócić do nowszego i próbować inaczej kombinować... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lwg Napisano Kwiecień 13, 2008 Autor Zgłoszenie Share Napisano Kwiecień 13, 2008 ciezko powiedziec czy to cos pomoglo bo mam teraz inny problem, zrobilem jak napisales, mam starsza wersje juz ale po probie startu gta wyskakuje mi blad (w okienku, nie w konsoli): A required security module cannot be activated. This program cannot be executed (7000). Please have a look at http://www.securom.com/message.asp?m=module&c=7000 for further, more detailed information. ale podana tam strona zawiera informacje jak poradzic sobie pod Windowsem gra jest oryginalna Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kalashnikov Napisano Kwiecień 13, 2008 Zgłoszenie Share Napisano Kwiecień 13, 2008 Potrzebujesz No-CD (Crack), znajdziesz go na gamecopyworld.com. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lwg Napisano Kwiecień 13, 2008 Autor Zgłoszenie Share Napisano Kwiecień 13, 2008 no niestety Unhandles Exception jest, próbowalem rózne cracki. Jak dalej nie pomoże, to będziesz mógł bez problemu wrócić do nowszego i próbować inaczej kombinować... wrócic do nowszego to chyba wroce tylko co dalej kombinowac? W poniedzialek bede mial nowa karte graficzna, moze na niej bedzie lepiej... A tak apropo zmieny karty, to zapytam juz tu, jak to w linuksie wyglada? sa jakies problemy czy fedora 8 sama zobaczy ze karta jest inna i przestawi co trzeba? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kalashnikov Napisano Kwiecień 13, 2008 Zgłoszenie Share Napisano Kwiecień 13, 2008 No nie mam pojęcia... Możesz jeszcze spróbować odinstalować PulseAudio, bo gry mają z nim problemy, ale nie wydaje mi się, żeby to pomogło. Sprawdzić możesz jeszcze używając Cedegi, stabilna wersja jest płatna, ale kod rozwojowy możesz ściągnąć z CVS - Cedega CVS - Podstawy Instalacji ver. 1.1 Co do karty graficznej, to zależy od karty. Jak kupisz Radeona zgodnego ze sterownikiem który masz w tej chwili to nie powinno być problemów, jeżeli kupisz inną kartę np. GeForce, albo starszego () Radeona to powinieneś odinstalować, i zainstalować zgodne sterowniki. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
