Arbuz Napisano Sierpień 21, 2008 Zgłoszenie Share Napisano Sierpień 21, 2008 Witam Po zastosowaniu rad Waldo odinstalowałem wireless ale nadal mam problem z automatycznym połączeniem z internetem podczas startu systemu oraz uruchomieniem usługi system-config-network. Po uruchomieniu system-config-network wywala to: Component: system-config-network Version: 1.5.10 Summary: TB24531662 NCBackendHal.py:103:getDevices:TypeError: not enough arguments for format string Traceback (most recent call last): File "/usr/sbin/system-config-network-gui", line 166, in runit window = mainDialog() File "/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 275, in __init__ self.load() File "/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 300, in load self.loadHardware() File "/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 312, in loadHardware hardwarelist = getHardwareList() File "/usr/share/system-config-network/netconfpkg/NCHardwareList.py", line 759, in getHardwareList __HWList.load() File "/usr/share/system-config-network/netconfpkg/NCHardwareList.py", line 603, in load self.updateFromSystem() File "/usr/share/system-config-network/netconfpkg/NCHardwareList.py", line 483, in updateFromSystem self.updateFromHal(hdellist) File "/usr/share/system-config-network/netconfpkg/NCHardwareList.py", line 448, in updateFromHal cards = hal.probeCards() File "/usr/share/system-config-network/netconfpkg/NCBackendHal.py", line 124, in probeCards card = self.getDevices(udi) File "/usr/share/system-config-network/netconfpkg/NCBackendHal.py", line 103, in getDevices hw.Description = "%s %s" % self.getVendor(udi) TypeError: not enough arguments for format string Local variables in innermost frame: category: net obj: <ProxyObject wrapping <dbus._dbus.SystemBus (system) at 0x1059e900> :1.2 /org/freedesktop/Hal/devices/net_00_2b_2f_de_ad_01 at 0x105a4eb0> name: eth2 arp_proto_hw_id: 1 hwf: {'Wireless': {0: <class netconfpkg.plugins.NCHWWireless.HwWireless at 0x10173c00>}, 'Ethernet': {0: <class netconfpkg.plugins.NCHWEthernet.HwEthernet at 0x101738a0>}, 'Modem': {0: <class netconfpkg.plugins.NCHWModem.HwModem at 0x101739f0>}, 'ISDN': {0: <class netconfpkg.plugins.NCHWIsdn.HwIsdn at 0x10173930>}, 'Token Ring': {0: <class netconfpkg.plugins.NCHWTokenring.HwTokenring at 0x10173b10>}} self: <netconfpkg.NCBackendHal.NCBackendHal instance at 0x105a0968> hw: Hardware.Status=nieaktywne Hardware.Name=eth2 Hardware.Type=Ethernet hwc: netconfpkg.plugins.NCHWEthernet.HwEthernet htype: Ethernet udi: /org/freedesktop/Hal/devices/net_00_2b_2f_de_ad_01 getHardwareFactory: <function getHardwareFactory at 0x1017d270> Ale za to pojawia się na pasku zadań ikona ApletNetworkManager. Zdecydowanie wolałem system-config-network bo przynajmniej był bezproblemowy w działaniu. Owszem jeśli po starcie systemu wyłączę połączenie sieciowe a następnie je włączę to jest połączenie (strony w firefoxie zaczynają działać). Co ciekawe od samego startu bez problemu startują torrenty. W porównaniu z poprzednią moją instalacją F8 pojawiło się eth2 choć używam eth0. Podczas startu systemu oprócz inicjalizacji eth0 inicjalizują się eth od 0 do 15. Kombinowałem z ustawieniem usług. Jeśli wyłączę NetworkManager to netu nie ma (test firefox-a bo torrenty śmigają) jeśli wyłaczę network sytuacja jest podobna. Podejrzewam że sytuacja ta jest związana z moim grzebaniem w usługach (mam teraz ustawione tak jak to było w poradniku). Czy jest możliwość powrotu do ustawień usług jakie były po bezpośredniej instalacji systemu? Internet mam z neostrady a do kompa mam przez sieciówkę podłączony AcessPoint a ten bezprzewodowo łączy się z Ruterem. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
