Instalacja Flash Cs 3 Pod Wine
swierq
Próbowałem. Za pierwszym razem wine ściągnął conieco jednak nic się póżniej nie uruchomiło. Kolejnym razem efekt jest taki:
fixme:console:AttachConsole stub ffffffff
Begin Adobe Setup
UI mode: Full GUI
fixme:msxml:domdoc_setProperty Unknown property L"async"
fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x127e5c 0x127e68 0x127f48 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x1295e4 0x1295f0 0x127ec8 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x127f5c 0x127f68 0x129668 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x1295e4 0x1295f0 0x127da0 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x127dbc 0x127dc8 0x127be8 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x129d14 0x129d20 0x127bf0 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x1295e4 0x1295f0 0x129b28 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x127b8c 0x127b98 0x129c60 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x129b04 0x129b10 0x1296f8 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x129b04 0x129b10 0x129c60 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12a99c 0x12a9a8 0x12a9f0 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12a914 0x12a920 0x12a9c0 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x127624 0x127630 0x137668 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x1375e4 0x1375f0 0x129bc8 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13969c 0x1396a8 0x1396d8 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12a77c 0x12a788 0x137668 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x140f54 0x140f60 0x129c28 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x127644 0x127650 0x142c48 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12a77c 0x12a788 0x13ad90 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x142c24 0x142c30 0x13eeb0 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12c80c 0x12c818 0x12c258 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12c80c 0x12c818 0x12c0e8 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x144894 0x1448a0 0x146f58 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x140e94 0x140ea0 0x12c100 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x140e94 0x140ea0 0x146ec0 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12c21c 0x12c228 0x12c0e8 (nil)
fixme:browseui:ProgressDialog_SetAnimation (0x12c220, 0x400000, 1000) - stub
fixme:browseui:ProgressDialog_StartProgressDialog Flags PROGDLG_NOTIME not supported
ALSA lib pcm.c:2162:(snd_pcm_open_conf) Cannot open shared library /usr/lib/alsa-lib/libasound_module_pcm_pulse.so
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x1d3224 0x1d3230 0x1d3310 (nil)
fixme:msxml:DllCanUnloadNow
fixme:advapi:LookupAccountNameW (null) L"X" (nil) 0x7ec68c48 (nil) 0x7ec68c4c 0x7ec68c40 - stub
fixme:advapi:LookupAccountNameW (null) L"X" 0x1d61f8 0x7ec68c48 0x1d60b8 0x7ec68c4c 0x7ec68c40 - stub
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x1e4544 0x1e4550 0x1e4630 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x212d74 0x212d80 0x212e48 (nil)
fixme:msi:ACTION_HandleStandardAction unhandled standard action L"SetODBCFolders"
fixme:msi:msi_unimplemented_action_stub RemoveFolders -> 1 ignored L"CreateFolder" table values
fixme:mscoree:LoadLibraryShim (0x6159056c L"fusion.dll", (nil), (nil), 0x7ec68eb0): semi-stub
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12e3d9c 0x12e3da8 0x12e3ea0 (nil)
Begin Adobe Setup
UI mode: Full GUI
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12a134 0x12a140 0x127820 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x128244 0x128250 0x128280 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x127f1c 0x127f28 0x127d80 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12c9e4 0x12c9f0 0x127f68 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x127abc 0x127ac8 0x12aae8 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x127abc 0x127ac8 0x1280f8 (nil)
End Adobe Setup.  Exit code: 0
[X@laptok ~]$ fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12aa64 0x12aa70 0x127de0 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12ad8c 0x12ad98 0x12adc8 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x138cf4 0x138d00 0x12ad78 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x138d54 0x138d60 0x138bd8 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x138d54 0x138d60 0x12ac70 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13ce14 0x13ce20 0x13cef0 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13a5c4 0x13a5d0 0x12ac70 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x12ac0c 0x12ac18 0x12ac60 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x127834 0x127840 0x12ac38 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13aa74 0x13aa80 0x127860 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13a81c 0x13a828 0x13a9d0 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13a4b4 0x13a4c0 0x13a998 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13a67c 0x13a688 0x13a768 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13ecc4 0x13ecd0 0x13a768 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13a81c 0x13a828 0x13a858 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13a83c 0x13a848 0x13aa60 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13459c 0x1345a8 0x1345d8 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x128bd4 0x128be0 0x128c80 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x128bd4 0x128be0 0x13aac0 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13aad4 0x13aae0 0x13ab10 (nil)
fixme:advapi:SetNamedSecurityInfoW L"C:\\Program Files\\Common Files\\Adobe\\caps" 1 -2147483644 0x13aad4 0x13aae0 0x13ab28 (nil)
fixme:shdocvw:PersistStreamInit_InitNew (0x129a18)
fixme:shdocvw:navigate_url Unsupported args (Flags 0x33ef38:3; TargetFrameName 0x33ef28:8)
fixme:urlmon:URLMonikerImpl_BindToObject use running object table
fixme:shdocvw:bind_to_object BindToObject failed: 80004005
fixme:shdocvw:navigate_url Unsupported args (Flags 0x33ef5c:3; TargetFrameName 0x33ef4c:8)
fixme:shdocvw:WebBrowser_put_RegisterAsDropTarget (0x129a18)->(0)
fixme:shdocvw:navigate_url Unsupported args (Flags 0x33ef84:3; TargetFrameName 0x33ef74:8)
fixme:system:SetProcessDPIAware stub!
fixme:dwmapi:DwmIsCompositionEnabled 0x33e81c
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\ssl3.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\plds4.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\nssdbm3.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\sqlite3.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\softokn3.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\nssutil3.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\xul.dll") - Symbol NSGetModule not found
fixme:winsock:WSAIoctl unsupported WS_IOCTL cmd (9800012c)
fixme:iphlpapi:NotifyAddrChange (Handle 0x7d479888, overlapped 0x7d479890): stub
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\js3250.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\nss3.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\nssckbi.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\freebl3.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\xpcom.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\smime3.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\plc4.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\plugins\npnul32.dll") - Symbol NSGetModule not found
0[1cad38]: nsNativeModuleLoader::LoadModule("C:\windows\gecko\0.9.0\wine_gecko\nspr4.dll") - Symbol NSGetModule not found
fixme:shdocvw:ClOleCommandTarget_QueryStatus (0x129ab4)->((null) 1 0x33edb4 (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x129ab4)->((null) 25 2 0x33edc8 (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x129ab4)->((null) 26 2 0x33edc8 (nil))
fixme:shdocvw:ClientSite_GetContainer (0x129ab4)->(0x33ee04)
fixme:shdocvw:ClOleCommandTarget_Exec (0x129ab4)->({000214d1-0000-0000-c000-000000000046} 37 0 0x33eed8 (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x129ab4)->({000214d1-0000-0000-c000-000000000046} 84 0 (nil) 0x33ef68)
fixme:mshtml:HlinkTarget_SetBrowseContext (0x9dfdf0)->((nil))
fixme:shdocvw:BindStatusCallback_OnProgress status code 11
fixme:shdocvw:BindStatusCallback_OnProgress status code 14
fixme:shdocvw:ClOleCommandTarget_QueryStatus (0x129ab4)->((null) 1 0x33ed94 (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x129ab4)->((null) 25 2 0x33eda8 (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x129ab4)->((null) 26 2 0x33eda8 (nil))
fixme:shdocvw:ClientSite_GetContainer (0x129ab4)->(0x33ede4)
fixme:shdocvw:ClOleCommandTarget_Exec (0x129ab4)->({000214d1-0000-0000-c000-000000000046} 37 0 0x33eeb8 (nil))
fixme:shdocvw:ClOleCommandTarget_Exec (0x129ab4)->({000214d1-0000-0000-c000-000000000046} 84 0 (nil) 0x33ef48)
fixme:jscript:JScriptProperty_SetProperty (0x35d41a8)->(70000001 (nil) 0x33e108)
fixme:shdocvw:ClOleCommandTarget_Exec (0x129ab4)->({000214d1-0000-0000-c000-000000000046} 84 0 (nil) 0x33e0f8)
wine: Unhandled page fault on read access to 0xbce8535a at address 0x60e97670 (thread 0027), starting debugger...
wineserver crashed, please enable coredumps (ulimit -c unlimited) and restart.
Listingi do 12-15 linijek umieszczaj między znacznikami [code] i [/code], dłuższe niż 15 linii pomiędzy [codebox] i [/codebox] - tak jest czytelniej. Przeczytaj "BB Code Help". WalDo
Gość
