Andrzej Orkan Napisano Październik 31, 2004 Zgłoszenie Share Napisano Październik 31, 2004 Sluchajcie, mam problem. Zainstalowalem sobie FC2 i probuje uruchomic pod kompilatorem gcc podstawowy program: # include <iostream.h> int main() { cout << "hello" << endl; return 0; } Po prostu podstawa. Ale kompilator mi to odrzucil! Ktos wie o co w tym biega? Prosze o pomoc!!!! Orkan P.S. A to co wyrzucil gcc na ekran: In file included from /usr/local/include/c++/3.3/backward/iostream.h:31, from andy.cpp:1: /usr/local/include/c++/3.3/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header. Please consider using one of the 32 headers found in section 17.4.1.2 of the C++ standard. Examples include substituting the <X> header for the <X.h> header for C++ includes, or <sstream> instead of the deprecated header <strstream.h>. To disable this warning use -Wno-deprecated. Undefined first referenced symbol in file std::basic_ostream<char, std::char_traits<char> >::operator<<(std::basic_ostream<char, std::char_traits<char> >& (*)(std::basic_ostream<char, std::char_traits<char> >&))/var/tmp//cc1sSYRm.o std::cout /var/tmp//cc1sSYRm.o std::ios_base::Init::~Init [in-charge]()/var/tmp//cc1sSYRm.o std::ios_base::Init::Init[in-charge]()/var/tmp//cc1sSYRm.o __gxx_personality_v0 /var/tmp//cc1sSYRm.o std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)/var/tmp//cc1sSYRm.o std::basic_ostream<char, std::char_traits<char> >& std::endl<char, std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&)/var/tmp//cc1sSYRm.o ld: fatal: Symbol referencing errors. No output written to a.out collect2: ld returned 1 exit status Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Październik 31, 2004 Zgłoszenie Share Napisano Październik 31, 2004 /usr/local/include/c++/3.3/backward/iostream.h:31, Skąd masz tę paczkę? W RedHacie/Fedorze żadna paczka nic nie zapisuje w /usr/local/ Zainstaluj kompilator z dystrybucji i zobacz czy działa. /usr/local/include/c++/3.3/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header. Please consider using one of the 32 headers found in section 17.4.1.2 of the C++ standard. Examples include substituting the <X> header for the <X.h> header for C++ includes, or <sstream> instead of the deprecated header <strstream.h>. To disable this warning use -Wno-deprecated. Też mi to wyskoczyło, ale się skompilowało :-) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
McGiwer Napisano Październik 31, 2004 Zgłoszenie Share Napisano Październik 31, 2004 # include <iostream.h> int main() { cout << "hello" << endl; return 0; } Jesli tak wyglada Twoj kod, to jest w nim blad. Zapomniales dodac czegos takiego jak using std::cout; lub using namespace std; Poza tym, do kompilacji kodu w C++ polecalbym raczej g++, a nie gcc. P.S. Przy tak krotkim kodzie mozesz dac bez niczego w stylu using costam, tylko po prostu w funkcji std::cout i problem rozwiazany Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
perbeatus Napisano Październik 31, 2004 Zgłoszenie Share Napisano Październik 31, 2004 jeśli korzysta z iostream.h to nie musi być std ale wtedy wyskakują warrningi bo domyślnie powinno korzystać się z iostream. a błąd tkwi faktycznie w g++ zamiast gcc. A tak apropos Orkan to polecam do programowania Anjute. Dostępna przez (_apt'a_ → apta) ORT i (_yum'a_ → yuma) ORT, bardzo dobre środowisko do programowania Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Andrzej Orkan Napisano Listopad 1, 2004 Autor Zgłoszenie Share Napisano Listopad 1, 2004 Dzieki dzieki dzieki wielkie wszystkim. Jest OK. Pozdrawiam wszystkich. Orkan Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
