Qdvdauthor
guciol
Jezeli ma ktos tenb prorgamik i pracuje na nim to prosze niech sie odezwie na [email protected] albo tutaj na forum.
Program zainstalowalem poprawnie - znaczy bez zadnych bledow. Problem pojawia sie przy CREATE DVD.
prosze o pomoc
WYKAZ z "Executing Dialog"
  INFO: [jpeg2yuv] Parsing & checking input files.
  INFO: [jpeg2yuv] YUV colorspace detected.
  INFO: [jpeg2yuv] Starting decompression
  INFO: [jpeg2yuv] Image dimensions are 352x288
  INFO: [jpeg2yuv] Movie frame rate is:  25.000000 frames/second
  INFO: [jpeg2yuv] Non-interlaced/progressive frames.
  INFO: [jpeg2yuv] Frame size:  352 x 288
  INFO: [jpeg2yuv] Number of Loops 1
  INFO: [jpeg2yuv] Now generating YUV4MPEG stream.
  INFO: [jpeg2yuv] Processing non-interlaced/interleaved /tmp/panama/Main Menu VMGMbackground.jpg, size 73163l.
  INFO: [jpeg2yuv] Rescaling color values.
  INFO: [mpeg2enc] Selecting DVD output profile
++ WARN: [mpeg2enc] No aspect ratio specifed and no guess possible: assuming 4:3 display aspect!
  INFO: [mpeg2enc] Progressive input - selecting progressive encoding.
  INFO: [mpeg2enc] Encoding MPEG-2 video to /tmp/panama/Main Menu VMGM.m2v
  INFO: [mpeg2enc] Horizontal size: 352 pel
  INFO: [mpeg2enc] Vertical size: 288 pel
  INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
  INFO: [mpeg2enc] Frame rate code:   3 = 25.0 (PAL/SECAM VIDEO / converted FILM)
  INFO: [mpeg2enc] Bitrate: 7500 KBit/s
  INFO: [mpeg2enc] Quality factor: 8 (Quantisation = 9) (1=best, 31=worst)
  INFO: [mpeg2enc] Field order for input: none/progressive
  INFO: [mpeg2enc] Sequence unlimited length
  INFO: [mpeg2enc] Search radius: 16
  INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
  INFO: [mpeg2enc] Setting colour/gamma parameters to "PAL B/G"
  INFO: [mpeg2enc] Progressive format frames = 1
  INFO: [mpeg2enc] Using default unmodified quantization matrices
  INFO: [mpeg2enc] Buffering 33 frames
  INFO: [mpeg2enc] GOP start (15 frames)
  INFO: [mpeg2enc] Frame end 0 I quant=8.00 total act=162.64044
  INFO: [mpeg2enc] Frame end 1 P quant=8.00 total act=199.47046
  INFO: [mpeg2enc] Frame end 2 P quant=8.00 total act=234.92437
  INFO: [mpeg2enc] Frame end 3 P quant=8.00 total act=270.34025
  INFO: [mpeg2enc] Frame end 4 P quant=8.00 total act=305.75455
  INFO: [mpeg2enc] Frame end 5 P quant=8.00 total act=341.16806
  INFO: [mpeg2enc] Frame end 6 P quant=8.00 total act=376.58157
  INFO: [mpeg2enc] Frame end 7 P quant=8.00 total act=411.99508
  INFO: [mpeg2enc] Frame end 8 P quant=8.00 total act=447.40859
  INFO: [mpeg2enc] Frame end 9 P quant=8.00 total act=482.82210
  INFO: [mpeg2enc] Frame end 10 P quant=8.00 total act=518.23561
  INFO: [mpeg2enc] Frame end 11 P quant=8.00 total act=553.64912
  INFO: [mpeg2enc] Frame end 12 P quant=8.00 total act=589.06263
  INFO: [mpeg2enc] Frame end 13 P quant=8.00 total act=624.47614
  INFO: [mpeg2enc] Frame end 14 P quant=8.00 total act=659.88965
  INFO: [mpeg2enc] Frame end 15 I quant=8.00 total act=822.53009
  INFO: [mpeg2enc] Frame end 16 P quant=8.00 total act=859.36011
  INFO: [mpeg2enc] Frame end 17 P quant=8.00 total act=894.81403
  INFO: [mpeg2enc] Frame end 18 P quant=8.00 total act=930.22990
  INFO: [mpeg2enc] Frame end 19 P quant=8.00 total act=965.64420
  INFO: [mpeg2enc] Frame end 20 P quant=8.00 total act=1001.05771
  INFO: [mpeg2enc] Frame end 21 P quant=8.00 total act=1036.47122
  INFO: [mpeg2enc] Frame end 22 P quant=8.00 total act=1071.88473
  INFO: [mpeg2enc] Frame end 23 P quant=8.00 total act=1107.29824
  INFO: [mpeg2enc] Frame end 24 P quant=8.00 total act=1142.71175
  INFO: [mpeg2enc] Frame end 25 P quant=8.00 total act=1178.12526
  INFO: [mpeg2enc] Frame end 26 P quant=8.00 total act=1213.53877
  INFO: [mpeg2enc] Frame end 27 P quant=8.00 total act=1248.95228
  INFO: [mpeg2enc] Frame end 28 P quant=8.00 total act=1284.36579
  INFO: [mpeg2enc] Frame end 29 P quant=8.00 total act=1319.77930
  INFO: [mpeg2enc] Signaling last frame = 49
  INFO: [mpeg2enc] Frame end 30 I quant=8.00 total act=1482.41975
  INFO: [mpeg2enc] Frame end 31 P quant=8.00 total act=1519.24977
  INFO: [mpeg2enc] Frame end 32 P quant=8.00 total act=1554.70368
  INFO: [mpeg2enc] Frame end 33 P quant=8.00 total act=1590.11956
  INFO: [mpeg2enc] Frame end 34 P quant=8.00 total act=1625.53386
  INFO: [mpeg2enc] Frame end 35 P quant=8.00 total act=1660.94737
  INFO: [mpeg2enc] Frame end 36 P quant=8.00 total act=1696.36088
  INFO: [mpeg2enc] Frame end 37 P quant=8.00 total act=1731.77439
  INFO: [mpeg2enc] Frame end 38 P quant=8.00 total act=1767.18790
  INFO: [mpeg2enc] Frame end 39 P quant=8.00 total act=1802.60141
  INFO: [mpeg2enc] Frame end 40 P quant=8.00 total act=1838.01492
  INFO: [mpeg2enc] Frame end 41 P quant=8.00 total act=1873.42843
  INFO: [mpeg2enc] Frame end 42 P quant=8.00 total act=1908.84194
  INFO: [mpeg2enc] Frame end 43 P quant=8.00 total act=1944.25545
  INFO: [mpeg2enc] Frame end 44 P quant=8.00 total act=1979.66896
  INFO: [mpeg2enc] GOP start (5 frames)
  INFO: [mpeg2enc] Frame end 45 I quant=8.00 total act=2142.30940
  INFO: [mpeg2enc] Frame end 46 P quant=8.00 total act=2179.13942
  INFO: [mpeg2enc] Frame end 47 P quant=8.00 total act=2214.59333
  INFO: [mpeg2enc] Frame end 48 P quant=8.00 total act=2250.00921
  INFO: [mpeg2enc] Frame end 49 P quant=8.00 total act=2285.42351
  INFO: [mpeg2enc] GOP start (0 frames)
  INFO: [mpeg2enc] Guesstimated final muxed size = 82616
/tmp/execute.sh: line 3: toolame: command not found
dd:
zapis `standardowe wyjście'
: Przerwany potok
773+0 rekordów wczytanych
772+0 rekordów zapisanych
  INFO: [mplex] mplex version 1.6.2 (2.2.3 $Date: 2004/01/13 20:45:26 $)
**ERROR: [mplex] Unable to open file /tmp/panama/Main Menu VMGM.mp2 for reading.
/tmp/execute.sh: line 3: /tmp/panama/Main Menu VMGM.mpg: Nie ma takiego pliku ani katalogu
  INFO: [jpeg2yuv] Processing non-interlaced/interleaved /tmp/panama/PALbackground.jpg, size 71831l.
  INFO: [mpeg2enc] Encoding MPEG-2 video to /tmp/panama/PAL.m2v
  INFO: [mpeg2enc] Frame end 0 I quant=8.00 total act=155.50937
  INFO: [mpeg2enc] Frame end 1 P quant=8.00 total act=191.84697
  INFO: [mpeg2enc] Frame end 2 P quant=8.00 total act=226.84002
  INFO: [mpeg2enc] Frame end 3 P quant=8.00 total act=261.80120
  INFO: [mpeg2enc] Frame end 4 P quant=8.00 total act=296.76016
  INFO: [mpeg2enc] Frame end 5 P quant=8.00 total act=331.71834
  INFO: [mpeg2enc] Frame end 6 P quant=8.00 total act=366.67651
  INFO: [mpeg2enc] Frame end 7 P quant=8.00 total act=401.63469
  INFO: [mpeg2enc] Frame end 8 P quant=8.00 total act=436.59286
  INFO: [mpeg2enc] Frame end 9 P quant=8.00 total act=471.55104
  INFO: [mpeg2enc] Frame end 10 P quant=8.00 total act=506.50922
  INFO: [mpeg2enc] Frame end 11 P quant=8.00 total act=541.46739
  INFO: [mpeg2enc] Frame end 12 P quant=8.00 total act=576.42557
  INFO: [mpeg2enc] Frame end 13 P quant=8.00 total act=611.38374
  INFO: [mpeg2enc] Frame end 14 P quant=8.00 total act=646.34192
  INFO: [mpeg2enc] Frame end 15 I quant=8.00 total act=801.85129
  INFO: [mpeg2enc] Frame end 16 P quant=8.00 total act=838.18889
  INFO: [mpeg2enc] Frame end 17 P quant=8.00 total act=873.18194
  INFO: [mpeg2enc] Frame end 18 P quant=8.00 total act=908.14312
  INFO: [mpeg2enc] Frame end 19 P quant=8.00 total act=943.10208
  INFO: [mpeg2enc] Frame end 20 P quant=8.00 total act=978.06026
  INFO: [mpeg2enc] Frame end 21 P quant=8.00 total act=1013.01843
  INFO: [mpeg2enc] Frame end 22 P quant=8.00 total act=1047.97661
  INFO: [mpeg2enc] Frame end 23 P quant=8.00 total act=1082.93478
  INFO: [mpeg2enc] Frame end 24 P quant=8.00 total act=1117.89296
  INFO: [mpeg2enc] Frame end 25 P quant=8.00 total act=1152.85113
  INFO: [mpeg2enc] Frame end 26 P quant=8.00 total act=1187.80931
  INFO: [mpeg2enc] Frame end 27 P quant=8.00 total act=1222.76748
  INFO: [mpeg2enc] Frame end 28 P quant=8.00 total act=1257.72566
  INFO: [mpeg2enc] Frame end 29 P quant=8.00 total act=1292.68384
  INFO: [mpeg2enc] Frame end 30 I quant=8.00 total act=1448.19321
  INFO: [mpeg2enc] Frame end 31 P quant=8.00 total act=1484.53080
  INFO: [mpeg2enc] Frame end 32 P quant=8.00 total act=1519.52386
  INFO: [mpeg2enc] Frame end 33 P quant=8.00 total act=1554.48503
  INFO: [mpeg2enc] Frame end 34 P quant=8.00 total act=1589.44400
  INFO: [mpeg2enc] Frame end 35 P quant=8.00 total act=1624.40217
  INFO: [mpeg2enc] Frame end 36 P quant=8.00 total act=1659.36035
  INFO: [mpeg2enc] Frame end 37 P quant=8.00 total act=1694.31852
  INFO: [mpeg2enc] Frame end 38 P quant=8.00 total act=1729.27670
  INFO: [mpeg2enc] Frame end 39 P quant=8.00 total act=1764.23488
  INFO: [mpeg2enc] Frame end 40 P quant=8.00 total act=1799.19305
  INFO: [mpeg2enc] Frame end 41 P quant=8.00 total act=1834.15123
  INFO: [mpeg2enc] Frame end 42 P quant=8.00 total act=1869.10940
  INFO: [mpeg2enc] Frame end 43 P quant=8.00 total act=1904.06758
  INFO: [mpeg2enc] Frame end 44 P quant=8.00 total act=1939.02575
  INFO: [mpeg2enc] Frame end 45 I quant=8.00 total act=2094.53513
  INFO: [mpeg2enc] Frame end 46 P quant=8.00 total act=2130.87272
  INFO: [mpeg2enc] Frame end 47 P quant=8.00 total act=2165.86578
  INFO: [mpeg2enc] Frame end 48 P quant=8.00 total act=2200.82695
  INFO: [mpeg2enc] Frame end 49 P quant=8.00 total act=2235.78592
  INFO: [mpeg2enc] Guesstimated final muxed size = 79428
dd:
: Przerwany potok
1025+0 rekordów wczytanych
1024+0 rekordów zapisanych
**ERROR: [mplex] Unable to open file /tmp/panama/PAL.mp2 for reading.
/tmp/execute.sh: line 3: /tmp/panama/PAL.mpg: Nie ma takiego pliku ani katalogu
DVDAuthor::dvdauthor, version 0.6.10.
Build options: gnugetopt iconv freetype
Send bugs to <[email protected]>
INFO: Locale=pl_PL.UTF-8
INFO: Converting filenames to UTF-8
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing /tmp/panama/PAL_menu.mpg...
ERR:  Error opening /tmp/panama/PAL_menu.mpg: Nie ma takiego pliku ani katalogu
Gość
