Groupmems - Segmentations Fault
elkwasik
Czesc,
wiecie moze co moze powodowac ten blad?
i jak sie tego pozbyc?
[root@server51372 ~]# groupmems -a sage_user -g sage_users
Segmentation fault
teraz przy kazdym uzyciu groupmems wywala mi to:
[root@server51372 ~]# groupmems -a rn -g samba_users
*** glibc detected *** groupmems: free(): invalid pointer: 0x09a295f8 ***
======= Backtrace: =========
/lib/libc.so.6[0x875ac1]
/lib/libc.so.6(cfree+0x90)[0x8790f0]
groupmems[0x8049970]
groupmems[0x804a3bb]
groupmems[0x8049a99]
groupmems[0x8049570]
/lib/libc.so.6(__libc_start_main+0xe0)[0x822390]
groupmems[0x8049251]
======= Memory map: ========
00110000-00111000 r-xp 00110000 00:00 0		  [vdso]
007ed000-00808000 r-xp 00000000 08:03 31196651   /lib/ld-2.7.so
00808000-00809000 r-xp 0001a000 08:03 31196651   /lib/ld-2.7.so
00809000-0080a000 rwxp 0001b000 08:03 31196651   /lib/ld-2.7.so
0080c000-0095f000 r-xp 00000000 08:03 31196652   /lib/libc-2.7.so
0095f000-00961000 r-xp 00153000 08:03 31196652   /lib/libc-2.7.so
00961000-00962000 rwxp 00155000 08:03 31196652   /lib/libc-2.7.so
00962000-00965000 rwxp 00962000 00:00 0
00967000-0096a000 r-xp 00000000 08:03 31196654   /lib/libdl-2.7.so
0096a000-0096b000 r-xp 00002000 08:03 31196654   /lib/libdl-2.7.so
0096b000-0096c000 rwxp 00003000 08:03 31196654   /lib/libdl-2.7.so
009b4000-009cd000 r-xp 00000000 08:03 31196663   /lib/libselinux.so.1
009cd000-009cf000 rwxp 00018000 08:03 31196663   /lib/libselinux.so.1
009e6000-009ef000 r-xp 00000000 08:03 31196659   /lib/libcrypt-2.7.so
009ef000-009f0000 r-xp 00008000 08:03 31196659   /lib/libcrypt-2.7.so
009f0000-009f1000 rwxp 00009000 08:03 31196659   /lib/libcrypt-2.7.so
009f1000-00a18000 rwxp 009f1000 00:00 0
00b21000-00b2c000 r-xp 00000000 08:03 31195531   /lib/libgcc_s-4.1.2-20070925.so									.1
00b2c000-00b2d000 rwxp 0000a000 08:03 31195531   /lib/libgcc_s-4.1.2-20070925.so									.1
08048000-0804d000 r-xp 00000000 08:03 4499725	/usr/sbin/groupmems
0804d000-0804e000 rw-p 00004000 08:03 4499725	/usr/sbin/groupmems
09a25000-09a46000 rw-p 09a25000 00:00 0
b7c00000-b7c21000 rw-p b7c00000 00:00 0
b7c21000-b7d00000 ---p b7c21000 00:00 0
b7d1e000-b7f1e000 r--p 00000000 08:03 4492399	/usr/lib/locale/locale-archive
b7f1e000-b7f20000 rw-p b7f1e000 00:00 0
b7f29000-b7f2a000 rw-p b7f29000 00:00 0
bfb6a000-bfb7f000 rw-p bffea000 00:00 0		  [stack]
Aborted
Pozdrawiam,
Pawel
Listingi do 12-15 linijek umieszczaj między znacznikami [code] i [/code], dłuższe niż 15 linii pomiędzy [codebox] i [/codebox] - tak jest czytelniej. Przeczytaj "BB Code Help"
Edytowane przez WalDo
Edycja znaczników code → codebox
strace wypuscilo mi to:
czarna magia ;)
[root@server51372 /]# strace groupmems
execve("/usr/sbin/groupmems", ["groupmems"], [/* 21 vars */]) = 0
brk(0)								  = 0x9250000
access("/etc/ld.so.preload", R_OK)	  = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY)	  = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=40002, ...}) = 0
mmap2(NULL, 40002, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7ff5000
close(3)								= 0
open("/lib/libcrypt.so.1", O_RDONLY)	= 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0 g\236\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=45316, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7ff4000
mmap2(0x9e6000, 201020, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x9e6000
mmap2(0x9ef000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8) = 0x9ef000
mmap2(0x9f1000, 155964, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x9f1000
close(3)								= 0
open("/lib/libselinux.so.1", O_RDONLY)  = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@z\233\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=105968, ...}) = 0
mmap2(0x9b4000, 109468, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x9b4000
mmap2(0x9cd000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x18) = 0x9cd000
close(3)								= 0
open("/lib/libc.so.6", O_RDONLY)		= 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\360$\202\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1692524, ...}) = 0
mmap2(0x80c000, 1410608, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x80c000
mmap2(0x95f000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x153) = 0x95f000
mmap2(0x962000, 9776, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x962000
close(3)								= 0
open("/lib/libdl.so.2", O_RDONLY)	   = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220z\226\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=20564, ...}) = 0
mmap2(0x967000, 16504, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x967000
mmap2(0x96a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2) = 0x96a000
close(3)								= 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7ff3000
set_thread_area({entry_number:-1 -> 6, base_addr:0xb7ff3920, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
mprotect(0x9ef000, 4096, PROT_READ)	 = 0
mprotect(0x95f000, 8192, PROT_READ)	 = 0
mprotect(0x96a000, 4096, PROT_READ)	 = 0
mprotect(0x808000, 4096, PROT_READ)	 = 0
munmap(0xb7ff5000, 40002)			   = 0
brk(0)								  = 0x9250000
brk(0x9271000)						  = 0x9271000
open("/etc/selinux/config", O_RDONLY|O_LARGEFILE) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=501, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7ffe000
read(3, "\n# This file controls the state "..., 4096) = 501
read(3, "", 4096)					   = 0
close(3)								= 0
munmap(0xb7ffe000, 4096)				= 0
statfs64("/selinux", 84, {f_type=0xf97cff8c, f_bsize=4096, f_blocks=0, f_bfree=0, f_bavail=0, f_files=0, f_ffree=0, f_fsid={0, 0}, f_namelen=255, f_frsize=4096}) = 0
stat64("/selinux/class", {st_mode=S_IFDIR|0555, st_size=0, ...}) = 0
open("/selinux/mls", O_RDONLY|O_LARGEFILE) = 3
read(3, "1", 19)						= 1
close(3)								= 0
open("/usr/lib/locale/locale-archive", O_RDONLY|O_LARGEFILE) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=77962480, ...}) = 0
mmap2(NULL, 2097152, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7df3000
close(3)								= 0
getuid32()							  = 0
getuid32()							  = 0
getgid32()							  = 0
socket(PF_FILE, SOCK_STREAM, 0)		 = 3
fcntl64(3, F_SETFL, O_RDWR|O_NONBLOCK)  = 0
connect(3, {sa_family=AF_FILE, path="/var/run/nscd/socket"}, 110) = -1 ENOENT (No such file or directory)
close(3)								= 0
close(3)								= 0
open("/etc/nsswitch.conf", O_RDONLY)	= 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=1696, ...}) = 0
read(3, "#\n# /etc/nsswitch.conf\n#\n# An ex"..., 4096) = 1696
close(3)								= 0
close(3)								= 0
open("/lib/libnss_files.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\300\30\0\0004\0\0\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=50768, ...}) = 0
mmap2(NULL, 45712, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x111000
mmap2(0x11b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9) = 0x11b000
close(3)								= 0
mprotect(0x11b000, 4096, PROT_READ)	 = 0
open("/etc/group", O_RDONLY|0x80000 /* O_??? */) = 3
fcntl64(3, F_GETFD)					 = 0x1 (flags FD_CLOEXEC)
fstat64(3, {st_mode=S_IFREG|0644, st_size=1038, ...}) = 0
read(3, "root:x:0:root\nbin:x:1:root,bin,d"..., 4096) = 1038
close(3)								= 0
getgid32()							  = 0
close(3)								= 0
getuid32()							  = 0
close(3)								= 0
close(3)								= 0
open("/etc/passwd", O_RDONLY|0x80000 /* O_??? */) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=2544, ...}) = 0
read(3, "root:x:0:0:root:/root:/bin/bash\n"..., 4096) = 2544
close(3)								= 0
open("/etc/.pwd.lock", O_WRONLY|O_CREAT|0x80000, 0600) = 3
rt_sigaction(SIGALRM, {0x8e5760, ~[], 0}, {SIG_DFL}, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [ALRM], [], 8) = 0
alarm(15)							   = 0
fcntl64(3, F_SETLKW, {type=F_WRLCK, whence=SEEK_SET, start=0, len=0}) = 0
alarm(0)								= 15
rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0
rt_sigaction(SIGALRM, {SIG_DFL}, NULL, 8) = 0
getpid()								= 10291
open("/etc/group.10291", O_WRONLY|O_CREAT|O_EXCL|O_LARGEFILE, 0600) = 4
write(4, "10291\0", 6)				  = 6
close(4)								= 0
link("/etc/group.10291", "/etc/group.lock") = -1 EEXIST (File exists)
open("/etc/group.lock", O_RDWR|O_LARGEFILE) = 4
read(4, "5625\0", 31)				   = 5
close(4)								= 0
kill(5625, SIG_0)					   = -1 ESRCH (No such process)
unlink("/etc/group.lock")			   = 0
link("/etc/group.10291", "/etc/group.lock") = 0
stat64("/etc/group.10291", {st_mode=S_IFREG|0600, st_size=6, ...}) = 0
unlink("/etc/group.10291")			  = 0
open("/etc/group", O_RDWR|O_LARGEFILE)  = 4
fcntl64(4, F_SETFD, FD_CLOEXEC)		 = 0
gettid()								= 10291
open("/proc/self/task/10291/attr/current", O_RDONLY|O_LARGEFILE) = 5
read(5, "system_u:system_r:unconfined_t:s"..., 4095) = 46
close(5)								= 0
fgetxattr(4, "security.selinux"..., "system_u:object_r:etc_t:s0", 255) = 27
socket(PF_FILE, SOCK_STREAM, 0)		 = 5
connect(5, {sa_family=AF_FILE, path="/var/run/setrans/.setrans-unix"}, 110) = -1 ENOENT (No such file or directory)
close(5)								= 0
fstat64(4, {st_mode=S_IFREG|0644, st_size=1038, ...}) = 0
read(4, "root:x:0:root\nbin:x:1:root,bin,d"..., 4096) = 1038
read(4, "", 4096)					   = 0
close(4)								= 0
gettid()								= 10291
open("/proc/self/task/10291/attr/fscreate", O_RDWR|O_LARGEFILE) = 4
write(4, NULL, 0)					   = 0
close(4)								= 0
close(3)								= 0
exit_group(0)						   = ?
ok morsik,
*** glibc detected *** groupmems: free(): invalid pointer: 0x08cd5628 ***
00b21000-00b2c000 r-xp 00000000 08:03 31195531   /lib/libgcc_s-4.1.2-20070925.so.1
00b2c000-00b2d000 rwxp 0000a000 08:03 31195531   /lib/libgcc_s-4.1.2-20070925.so.1
08cd1000-08cf2000 rw-p 08cd1000 00:00 0
b7d72000-b7f72000 r--p 00000000 08:03 4492399    /usr/lib/locale/locale-archive
b7f72000-b7f74000 rw-p b7f72000 00:00 0
b7f7d000-b7f7e000 rw-p b7f7d000 00:00 0
bfc3a000-bfc4f000 rw-p bffea000 00:00 0          [stack]
Aborted
[root@server51372 ~]# strace groupmems
execve("/usr/sbin/groupmems", ["groupmems"], [/* 20 vars */]) = 0
brk(0)                                  = 0x8e8f000
mmap2(NULL, 40002, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7fb6000
close(3)                                = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7fb5000
close(3)                                = 0
close(3)                                = 0
close(3)                                = 0
close(3)                                = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7fb4000
set_thread_area({entry_number:-1 -> 6, base_addr:0xb7fb4920, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
munmap(0xb7fb6000, 40002)               = 0
brk(0)                                  = 0x8e8f000
brk(0x8eb0000)                          = 0x8eb0000
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7fbf000
close(3)                                = 0
munmap(0xb7fbf000, 4096)                = 0
close(3)                                = 0
mmap2(NULL, 2097152, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7db4000
close(3)                                = 0
getuid32()                              = 0
getuid32()                              = 0
getgid32()                              = 0
close(3)                                = 0
close(3)                                = 0
close(3)                                = 0
close(3)                                = 0
close(3)                                = 0
fstat64(3, {st_mode=S_IFREG|0644, st_size=1044, ...}) = 0
read(3, "root:x:0:root\nbin:x:1:root,bin,d"..., 4096) = 1044
close(3)                                = 0
getgid32()                              = 0
close(3)                                = 0
getuid32()                              = 0
close(3)                                = 0
close(3)                                = 0
close(3)                                = 0
alarm(15)                               = 0
alarm(0)                                = 15
getpid()                                = 31329
open("/etc/group.31329", O_WRONLY|O_CREAT|O_EXCL|O_LARGEFILE, 0600) = 4
write(4, "31329\0", 6)                  = 6
close(4)                                = 0
link("/etc/group.31329", "/etc/group.lock") = -1 EEXIST (File exists)
read(4, "31325\0", 31)                  = 6
close(4)                                = 0
kill(31325, SIG_0)                      = -1 ESRCH (No such process)
link("/etc/group.31329", "/etc/group.lock") = 0
stat64("/etc/group.31329", {st_mode=S_IFREG|0600, st_size=6, ...}) = 0
unlink("/etc/group.31329")              = 0
gettid()                                = 31329
open("/proc/self/task/31329/attr/current", O_RDONLY|O_LARGEFILE) = 5
close(5)                                = 0
close(5)                                = 0
fstat64(4, {st_mode=S_IFREG|0644, st_size=1044, ...}) = 0
read(4, "root:x:0:root\nbin:x:1:root,bin,d"..., 4096) = 1044
close(4)                                = 0
gettid()                                = 31329
open("/proc/self/task/31329/attr/fscreate", O_RDWR|O_LARGEFILE) = 4
close(4)                                = 0
close(3)                                = 0
exit_group(0)                           = ?
Dzieki za zainteresowanie.
Pozdrawiam,
Pawel
no chyba, ze masz na mysli to:
[root@server51372 ~]# strace groupmems -a rn -g samba_users
execve("/usr/sbin/groupmems", ["groupmems", "-a", "rn", "-g", "samba_users"], [/* 20 vars */]) = 0
brk(0)                                  = 0x99ad000
mmap2(NULL, 40002, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7f98000
close(3)                                = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7f97000
close(3)                                = 0
close(3)                                = 0
close(3)                                = 0
close(3)                                = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7f96000
set_thread_area({entry_number:-1 -> 6, base_addr:0xb7f96920, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
munmap(0xb7f98000, 40002)               = 0
brk(0)                                  = 0x99ad000
brk(0x99ce000)                          = 0x99ce000
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7fa1000
close(3)                                = 0
munmap(0xb7fa1000, 4096)                = 0
close(3)                                = 0
mmap2(NULL, 2097152, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7d96000
close(3)                                = 0
getuid32()                              = 0
getuid32()                              = 0
alarm(15)                               = 0
alarm(0)                                = 15
getpid()                                = 555
open("/etc/group.555", O_WRONLY|O_CREAT|O_EXCL|O_LARGEFILE, 0600) = 4
write(4, "555\0", 4)                    = 4
close(4)                                = 0
link("/etc/group.555", "/etc/group.lock") = -1 EEXIST (File exists)
read(4, "495\0", 31)                    = 4
close(4)                                = 0
kill(495, SIG_0)                        = -1 ESRCH (No such process)
link("/etc/group.555", "/etc/group.lock") = 0
stat64("/etc/group.555", {st_mode=S_IFREG|0600, st_size=4, ...}) = 0
unlink("/etc/group.555")                = 0
gettid()                                = 555
open("/proc/self/task/555/attr/current", O_RDONLY|O_LARGEFILE) = 5
close(5)                                = 0
close(5)                                = 0
open("/dev/tty", O_RDWR|O_NOCTTY|O_NONBLOCK) = 5
writev(5, [{"*** glibc detected *** ", 23}, {"groupmems", 9}, {": ", 2}, {"free(): invalid pointer", 23}, {": 0x", 4}, {"099b1628", 8}, {" ***\n", 5}], 7*** glibc detected *** groupmems: free(): invalid pointer: 0x099b1628 ***
) = 74
open("/etc/ld.so.cache", O_RDONLY)      = 6
fstat64(6, {st_mode=S_IFREG|0644, st_size=40002, ...}) = 0
mmap2(NULL, 40002, PROT_READ, MAP_PRIVATE, 6, 0) = 0xb7d8c000
close(6)                                = 0
open("/lib/libgcc_s.so.1", O_RDONLY)    = 6
read(6, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260&\262\0004\0\0\0"..., 512) = 512
mmap2(NULL, 2097152, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0) = 0xb7b8c000
munmap(0xb7b8c000, 475136)              = 0
munmap(0xb7d00000, 573440)              = 0
mprotect(0xb7c00000, 135168, PROT_READ|PROT_WRITE) = 0
fstat64(6, {st_mode=S_IFREG|0755, st_size=46808, ...}) = 0
mmap2(0xb21000, 48228, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 6, 0) = 0xb21000
mmap2(0xb2c000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 6, 0xa) = 0xb2c000
close(6)                                = 0
munmap(0xb7d8c000, 40002)               = 0
write(5, "======= Backtrace: =========\n", 29======= Backtrace: =========
) = 29
writev(5, [{"/lib/libc.so.6", 14}, {"[0x", 3}, {"875ac1", 6}, {"]\n", 2}], 4/lib/libc.so.6[0x875ac1]
) = 25
writev(5, [{"/lib/libc.so.6", 14}, {"(", 1}, {"cfree", 5}, {"+0x", 3}, {"90", 2}, {")", 1}, {"[0x", 3}, {"8790f0", 6}, {"]\n", 2}], 9/lib/libc.so.6(cfree+0x90)[0x8790f0]
) = 37
writev(5, [{"groupmems", 9}, {"[0x", 3}, {"8049970", 7}, {"]\n", 2}], 4groupmems[0x8049970]
) = 21
writev(5, [{"groupmems", 9}, {"[0x", 3}, {"804a3bb", 7}, {"]\n", 2}], 4groupmems[0x804a3bb]
) = 21
writev(5, [{"groupmems", 9}, {"[0x", 3}, {"8049a99", 7}, {"]\n", 2}], 4groupmems[0x8049a99]
) = 21
writev(5, [{"groupmems", 9}, {"[0x", 3}, {"8049570", 7}, {"]\n", 2}], 4groupmems[0x8049570]
) = 21
writev(5, [{"/lib/libc.so.6", 14}, {"(", 1}, {"__libc_start_main", 17}, {"+0x", 3}, {"e0", 2}, {")", 1}, {"[0x", 3}, {"822390", 6}, {"]\n", 2}], 9/lib/libc.so.6(__libc_start_main+0xe0)[0x822390]
) = 49
writev(5, [{"groupmems", 9}, {"[0x", 3}, {"8049251", 7}, {"]\n", 2}], 4groupmems[0x8049251]
) = 21
write(5, "======= Memory map: ========\n", 29======= Memory map: ========
) = 29
open("/proc/self/maps", O_RDONLY)       = 6
read(6, "00110000-00111000 r-xp 00110000 "..., 1024) = 1024
write(5, "00110000-00111000 r-xp 00110000 "..., 102400110000-00111000 r-xp 00110000 00:00 0          [vdso]
009f0000-009f1000 rwxp 00009000 08:03 31196659   /lib/li) = 1024
read(6, "bcrypt-2.7.so\n009f1000-00a18000 "..., 1024) = 701
write(5, "bcrypt-2.7.so\n009f1000-00a18000 "..., 701bcrypt-2.7.so
099ad000-099ce000 rw-p 099ad000 00:00 0
b7d96000-b7f96000 r--p 00000000 08:03 4492399    /usr/lib/locale/locale-archive
b7f96000-b7f98000 rw-p b7f96000 00:00 0
b7fa1000-b7fa2000 rw-p b7fa1000 00:00 0
bfa14000-bfa29000 rw-p bffea000 00:00 0          [stack]
) = 701
read(6, "", 1024)                       = 0
close(6)                                = 0
rt_sigprocmask(SIG_UNBLOCK, [ABRT], NULL, 8) = 0
tgkill(555, 555, SIGABRT)               = 0
--- SIGABRT (Aborted) @ 0 (0) ---
+++ killed by SIGABRT +++
Tak to na końcu. W końcu program po podaniu argumentów robi zupełnie co innego niż jak go włączysz bez argumentów.
Skąd masz ten program? To binarka czy ręcznie kompilowałeś?
Nie znam się za bardzo, ale mi to wygląda na problem z zapisem do pamięci.
Gość
