Gryhild Napisano Listopad 2, 2004 Zgłoszenie Share Napisano Listopad 2, 2004 Witam!!!! Mój sprzęt to : P4-2GHz 256 DDR Radeon 9000 na standartowych sterach z fedory(nic nie zmieniałem) Problem dotyczy tego, że nie mogę tego dooma (_wogóle_ → w ogóle) ORT zainstalować Jedną z prób to było przez cedege 4.0 no i nawet obrazek zobaczyłem, ale to wszystko!! W rezultacie ściągnąłem binarki w wersji 1.1.1282 no i : DOOM 1.1.1282 linux-x86 Oct 4 2004 08:21:14 Hostname: localhost.localdomain Alias: localhost IP: 127.0.0.1 ------ Initializing File System ------ Loaded pk4 /usr/local/games/doom3/base/game00.pk4 with checksum 0x7dafc4d4 Loaded pk4 /usr/local/games/doom3/base/game01.pk4 with checksum 0x16cf3b8a Loaded pk4 /usr/local/games/doom3/base/pak000.pk4 with checksum 0x28d208f1 Loaded pk4 /usr/local/games/doom3/base/pak001.pk4 with checksum 0x40244be0 Loaded pk4 /usr/local/games/doom3/base/pak002.pk4 with checksum 0xc51ecdcd Loaded pk4 /usr/local/games/doom3/base/pak003.pk4 with checksum 0xcd79d028 Loaded pk4 /usr/local/games/doom3/base/pak004.pk4 with checksum 0x765e4f8b Loaded pk4 /usr/local/games/doom3/base/pak005.pk4 with checksum 0x8ffc3621 Current search path: /root/.doom3/base /usr/local/games/doom3/base /usr/local/games/doom3/base/pak005.pk4 (63 files) /usr/local/games/doom3/base/pak004.pk4 (5137 files) /usr/local/games/doom3/base/pak003.pk4 (4676 files) /usr/local/games/doom3/base/pak002.pk4 (6120 files) /usr/local/games/doom3/base/pak001.pk4 (8972 files) /usr/local/games/doom3/base/pak000.pk4 (2698 files) /usr/local/games/doom3/base/game01.pk4 (2 files) /usr/local/games/doom3/base/game00.pk4 (2 files) game DLL: 0x0 in pak: 0x0 file system initialized. -------------------------------------- ----- Initializing Decls ----- ------------------------------ ------- Initializing renderSystem -------- using ARB renderSystem renderSystem initialized. -------------------------------------- 5151 strings read from strings/english.lang Couldn't open journal files execing editor.cfg execing default.cfg couldn't exec DoomConfig.cfg execing autoexec.cfg 5151 strings read from strings/english.lang ----- Initializing Sound System ------ sound system initialized. -------------------------------------- ----- R_InitOpenGL ----- dlopen(libGL.so.1) Open X display Initializing OpenGL display Using XFree86-VidModeExtension Version 2.2 DGA DirectVideo Mouse (Version 2.0) initialized Free86-VidModeExtension Activated at 640x480 Using 8/8/8 Color bits, 8 Alpha bits, 24 depth, 8 stencil display. GL_RENDERER: Mesa DRI R200 20030328 AGP 1x x86/MMX+/SSE2 TCL GL_EXTENSIONS: GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_convolution GL_EXT_copy_texture GL_EXT_draw_range_elements GL_EXT_histogram GL_EXT_packed_pixels GL_EXT_polygon_offset GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_object GL_EXT_texture_lod_bias GL_EXT_vertex_array GL_APPLE_packed_pixels GL_ATI_texture_env_combine3 GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_MESA_window_pos GL_NV_blend_square GL_NV_texture_rectangle GL_NV_texgen_reflection GL_SGI_color_matrix GL_SGI_color_table GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod ------- Input Initialization ------- XKB extension: compile time 0x1:0x0, runtime 0x1:0x0: OK XKB extension present on server ( 0x1:0x0 ) ------------------------------------ ----------- OSS Sound Initialization ----------- opened sound device '/dev/dsp' /dev/dsp - bit rate: 16, channels: 2, frequency: 44100 ------------------------------------------------ ...using GL_ARB_multitexture ...using GL_ARB_texture_env_combine ...using GL_ARB_texture_cube_map ...using GL_ARB_texture_env_dot3 ...using GL_ARB_texture_env_add X..GL_ARB_texture_non_power_of_two not found ...using GL_ARB_texture_compression ...using GL_EXT_texture_filter_anisotropic maxTextureAnisotropy: 16.000000 ...using GL_EXT_texture_lod ...using GL_1.4_texture_lod_bias X..GL_EXT_shared_texture_palette not found ...using GL_EXT_texture3D ...using GL_EXT_stencil_wrap X..GL_NV_register_combiners not found X..GL_EXT_stencil_two_side not found X..GL_ATI_separate_stencil not found X..GL_ATI_fragment_shader not found X..GL_ATI_text_fragment_shader not found X..GL_ARB_vertex_buffer_object not found X..GL_ARB_vertex_program not found X..GL_ARB_fragment_program not found X..EXT_depth_bounds_test not found ---------- R_NV20_Init ---------- Not available. ----------- R200_Init ----------- Not available. ---------- R_ARB2_Init ---------- Not available. ---------- R_Exp_Init ----------- Disabled at compile time. --------------------------------- ----- R_ReloadARBPrograms ----- glprogs/test.vfp: GL_VERTEX_PROGRAM_ARB not available glprogs/test.vfp: GL_FRAGMENT_PROGRAM_ARB not available glprogs/interaction.vfp: GL_VERTEX_PROGRAM_ARB not available glprogs/interaction.vfp: GL_FRAGMENT_PROGRAM_ARB not available glprogs/bumpyEnvironment.vfp: GL_VERTEX_PROGRAM_ARB not available glprogs/bumpyEnvironment.vfp: GL_FRAGMENT_PROGRAM_ARB not available glprogs/ambientLight.vfp: GL_VERTEX_PROGRAM_ARB not available glprogs/ambientLight.vfp: GL_FRAGMENT_PROGRAM_ARB not available glprogs/shadow.vp: GL_VERTEX_PROGRAM_ARB not available glprogs/R200_interaction.vp: GL_VERTEX_PROGRAM_ARB not available glprogs/nv20_bumpAndLight.vp: GL_VERTEX_PROGRAM_ARB not available glprogs/nv20_diffuseColor.vp: GL_VERTEX_PROGRAM_ARB not available glprogs/nv20_specularColor.vp: GL_VERTEX_PROGRAM_ARB not available glprogs/nv20_diffuseAndSpecularColor.vp: GL_VERTEX_PROGRAM_ARB not available glprogs/environment.vfp: GL_VERTEX_PROGRAM_ARB not available glprogs/environment.vfp: GL_FRAGMENT_PROGRAM_ARB not available ------------------------------- WARNING: vertex array range in virtual memory (SLOW) signal caught: Segmentation fault si_code 1 Trying to exit gracefully.. Shutting down sound hardware ----------- OSS Sound Shutdown ----------- unmap dma sound buffer close sound device ------------------------------------------ idRenderSystem::Shutdown() To wywala przy odpaleniu z roota ale z użytkownika jest podobnie!! Wydaje mi się że to chodzi o karte ale nie wiem!! W centrum sterowania system dzwiękowy zmieniłem na opend sound system, więc to powinno działać Będe wdzięczny za pomoc!!!! Unreal Turnament 2004 działa!! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mynus Napisano Listopad 2, 2004 Zgłoszenie Share Napisano Listopad 2, 2004 u mnie na radeonie udało sie uruchomić dooma, ale zamist obrazu miałem tysiące kresek (tylko celownik oraz zdrowie było wyświetlone normalnie), i zrezygnowałem P.S. nie wiem czy to ma znaczenie, ale nie nagrałem tych plików pak0 czy jakoś tak do katalogu tylko zrobiłem dowiązanie z dysku fatowskiego (hmm, moze w tym jest problem) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
perbeatus Napisano Listopad 3, 2004 Zgłoszenie Share Napisano Listopad 3, 2004 Po pierwsze STEROWNIKI fglrx-3.14.1!!! Po drugie nie nagranie pkaów z cd ma znaczenie ale grafa i tak się wali... Jak do tej pory w doom'a na linie mozna sobie pograć tylko na nVidiach niestety Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Esekiell Napisano Listopad 5, 2004 Zgłoszenie Share Napisano Listopad 5, 2004 na stronie suprnova.org jest doom 3 w ver na (_linuxa_ → Linuksa) ORT, kto chce moze go kupic w sklepie torrenta Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
tomcio15 Napisano Listopad 10, 2004 Zgłoszenie Share Napisano Listopad 10, 2004 Info z ostatniej chwili!!! Jak chcecie se pograć w dooma 3 na radku ti musicie sobie koniecznie zaktualizować sterowniki dla kart ATI, bo bez tego nie ma szans na uruchomienie tej gierki Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gryhild Napisano Listopad 16, 2004 Autor Zgłoszenie Share Napisano Listopad 16, 2004 WITAM!! Ja już nic nie wiem!! Pojawiły się stery 3.14.6 dla dooma od ati i jak się dowiedziałem to lipa jak ktoś ma xrog!! Więc moje pytanie jest taki, czy opłaca się ścierać na fc2 z tymi sterami i czy to cos da, bo przecież fc2 jest na xorg?? Jak ktoś wie to będe wdzięczny za pomoc Pozdro!! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
