pitbull Napisano Listopad 3, 2004 Zgłoszenie Share Napisano Listopad 3, 2004 Witam, mam problem z dobraniem i ustawieniem sterownika do starszego komputera: 0000:01:00.0 VGA compatible controller: Texas Instruments TVP4020 [Permedia 2] (rev 01) Zaś plik /etc/X11/XF86Config-4 prezentuje się następująco: # XF86Config-4 (XFree86 X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the XF86Config-4 manual page. # (Type "man XF86Config-4" at the shell prompt.) # # This file is automatically updated on xserver-xfree86 package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xfree86 # package. # # If you have edited this file but would like it to be automatically updated # again, run the following commands as root: # # cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom # md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum # dpkg-reconfigure xserver-xfree86 Section "Files" FontPath "unix/:7100" # local font server # if the local font server has problems, we can fall back on these FontPath "/usr/lib/X11/fonts/misc" FontPath "/usr/lib/X11/fonts/cyrillic" FontPath "/usr/lib/X11/fonts/100dpi/:unscaled" FontPath "/usr/lib/X11/fonts/75dpi/:unscaled" FontPath "/usr/lib/X11/fonts/Type1" FontPath "/usr/lib/X11/fonts/CID" FontPath "/usr/lib/X11/fonts/Speedo" FontPath "/usr/lib/X11/fonts/100dpi" FontPath "/usr/lib/X11/fonts/75dpi" EndSection Section "Module" Load "GLcore" Load "bitmap" Load "dbe" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "record" Load "speedo" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "keyboard" Option "CoreKeyboard" Option "XkbRules" "xfree86" Option "XkbModel" "pc104" Option "XkbLayout" "pl" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/psaux" Option "Protocol" "PS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "InputDevice" Identifier "Generic Mouse" Driver "mouse" Option "SendCoreEvents" "true" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "Device" Identifier "Generic Video Card" Driver "glint" VideoRam 32000 EndSection Section "Monitor" Identifier "Generic Monitor" HorizSync 30-60 VertRefresh 50-75 Option "DPMS" EndSection Section "Screen" Identifier "Default Screen" Device "Generic Video Card" Monitor "Generic Monitor" DefaultDepth 16 SubSection "Display" Depth 1 Modes "1280x1024" "1280x960" "800x600" "640x480" EndSubSection SubSection "Display" Depth 4 Modes "1280x1024" "1280x960" "800x600" "640x480" EndSubSection SubSection "Display" Depth 8 Modes "1280x1024" "1280x960" "800x600" "640x480" EndSubSection SubSection "Display" Depth 15 Modes "1280x1024" "1280x960" "800x600" "640x480" EndSubSection SubSection "Display" Depth 16 Modes "1280x1024" "1280x960" "800x600" "640x480" EndSubSection SubSection "Display" Depth 24 Modes "1280x1024" "1280x960" "800x600" "640x480" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" InputDevice "Generic Mouse" EndSection Section "DRI" Mode 0666 EndSection Wcześniej driver był ustawione na vesa, jednakże pracował jedynie w trybie 8-bitowym, a kolory były strasznie denne, tzn jakieś takie pozmieniane, niewyraźne etc. Po zamianie na glint nie odczułem wyraźnej różnicy. Mogę ustawiać różne depth, jednakże kolory ciale są do bani :/ Czy może do tejże karty powinienem ustawić inny driver? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
