entrance Napisano Kwiecień 1, 2009 Zgłoszenie Share Napisano Kwiecień 1, 2009 witam w pospiechu wczoraj przez przypadek usunalem sobie configi yuma z /etc i /etc/yum.repos.d, tak wiec sciagnalem przykladowy plik yum.conf [main] cachedir=/var/cache/yum debuglevel=2 logfile=/var/log/yum.log pkgpolicy=newest retries=3 exactarch=1 obsoletes=1 gpgcheck=1 plugins=1 metadata_expire=1800 installonly_limit=2 # PUT YOUR REPOS HERE OR IN separate files named file.repo # in /etc/yum.repos.d [base] name=Fedora Core baseurl=http://livna-dl.reloumirrors.net/fedora/9/i386/ #mirrorlist=ftp://ftp.unina.it/pub/linux/distributions/fedora/linux/updates/9/SRPMS/repodata/ enabled=1 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-fedora i niestety nadal mam blad poniewaz jesli chce z upgrade'owac jakikolwiek pakiet yum upgrade [pakiet] dostaje caly czas ponizszy wynik Wczytane wtyczki: refresh-packagekit Repository base is listed more than once in the configuration YumRepo Warning: not using ftp, http[s], or file for repos, skipping - -rw-r--r-- 1 ftpuser ftpusers 1341367 Sep 9 2008 comps-f9.xml YumRepo Warning: not using ftp, http[s], or file for repos, skipping - -rw-r--r-- 1 ftpuser ftpusers 1600 Sep 10 2008 f9-updateinfo.xml.gz YumRepo Warning: not using ftp, http[s], or file for repos, skipping - -rw-r--r-- 1 ftpuser ftpusers 1055 Sep 9 2008 filelists.sqlite.bz2 YumRepo Warning: not using ftp, http[s], or file for repos, skipping - -rw-r--r-- 1 ftpuser ftpusers 534 Sep 9 2008 filelists.xml.gz YumRepo Warning: not using ftp, http[s], or file for repos, skipping - -rw-r--r-- 1 ftpuser ftpusers 7699 Sep 9 2008 other.sqlite.bz2 YumRepo Warning: not using ftp, http[s], or file for repos, skipping - -rw-r--r-- 1 ftpuser ftpusers 5476 Sep 9 2008 other.xml.gz YumRepo Warning: not using ftp, http[s], or file for repos, skipping - -rw-r--r-- 1 ftpuser ftpusers 3460 Sep 9 2008 primary.sqlite.bz2 YumRepo Warning: not using ftp, http[s], or file for repos, skipping - -rw-r--r-- 1 ftpuser ftpusers 1744 Sep 9 2008 primary.xml.gz YumRepo Warning: not using ftp, http[s], or file for repos, skipping - -rw-r--r-- 1 ftpuser ftpusers 2659 Sep 10 2008 repomd.xml YumRepo Warning: not using ftp, http[s], or file for repos, skipping - -rw-r--r-- 1 ftpuser ftpusers 1597 Sep 10 2008 updateinfo.xml.gz removing mirrorlist with no valid mirrors: //var/cache/yum/base/mirrorlist.txt Błąd: Cannot retrieve repository metadata (repomd.xml) for repository: base. Please verify its path and try again siedze nad tym od wczoraj i niestety nie udalo mi sie, tak wiec chcialem zapytac w ktorym miejscu szukac przyczyny? pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
..::DAN::.. Napisano Kwiecień 1, 2009 Zgłoszenie Share Napisano Kwiecień 1, 2009 Cześć mój yum.conf z /etc to [main] cachedir=/var/cache/yum keepcache=0 debuglevel=2 logfile=/var/log/yum.log exactarch=1 obsoletes=1 gpgcheck=1 plugins=1 installonly_limit=3 Twój problem to ten, że skoro usunąłeś pliki *.repo to yum "nie wie" gdzie ma sprawdzić czy są aktualizacje skoro nie ma repozytoriów możemy zrobić tak, że Ci wyśle wszystkie pliki z repo jakie mam u siebie repo.zip Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Kwiecień 1, 2009 Zgłoszenie Share Napisano Kwiecień 1, 2009 Ten przykładowy yum.conf strasznie stary jest (pojawia się nazwa Fedora Core), ten który wkleił ..::DAN::.. jest odpowiedni. Co do repozytoriów bylebyś miał fedora i fedora-updates, odnośnie rpmfusion to po prostu usuń zainstalowane pakiety yum remove rpmfusion\* i zainstaluj repo jeszcze raz (yum remove powinno pójść). Jeśli masz F9 też wszystko pójdzie. Yuma masz opisanego na wiki Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
entrance Napisano Kwiecień 1, 2009 Autor Zgłoszenie Share Napisano Kwiecień 1, 2009 wielkie dzieki za pomoc wszystko dziala pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ysio Napisano Kwiecień 1, 2009 Zgłoszenie Share Napisano Kwiecień 1, 2009 wielkie dzieki za pomoc wszystko dziala pozdrawiam wielkie dzieki za pomoc wszystko dziala pozdrawiam na wszelki wypadek podam ci jak powinienes to zrobic: u mnie for a in `find /etc/yu*`; do rpm -qf $a; done|sort|uniq yum-3.2.21-2.fc10.noarch yum-aliases-1.1.19-1.fc10.noarch yum-allowdowngrade-1.1.19-1.fc10.noarch yum-cron-0.8.3-1.fc10.noarch yum-downloadonly-1.1.19-1.fc10.noarch yum-fastestmirror-1.1.19-1.fc10.noarch yum-fedorakmod-1.1.19-1.fc10.noarch yum-filter-data-1.1.19-1.fc10.noarch yum-kernel-module-1.1.19-1.fc10.noarch yum-protect-packages-1.1.19-1.fc10.noarch yum-security-1.1.19-1.fc10.noarch yum-updatesd-0.9-1.fc9.noarch yum-upgrade-helper-1.1.19-1.fc10.noarch yum-verify-1.1.19-1.fc10.noarch yum-versionlock-1.1.19-1.fc10.noarch a ty poleceniem yum reinstall pakiet zreinstaluj wszystkie pakiety - wtedy bedziesz mial na 100% OK oczywiscie nie musisz wszystkich tych pakietow posiadac zainstalowanych w swoim linuksie gdyby yum nie dzialal polecam skorzystanie http://rpm.pbone.net/ w celu znalezienia pakietu sciagniecia i normalnie zainstalowac rpm-em Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
