Zdalny Pulpit- Jak?
96th
Mieszkam w UK dwa lata i Polskiego prawie nie używam.
Że tak spytam bezczelnie - Kogo to?
Arabski: Nie znalazło.
Kolego, robisz debila ze mnie czy z siebie?
[root@charon ~]# uname -a
Linux charon 2.6.27.21-170.2.56.fc10.i686 #1 SMP Mon Mar 23 23:37:54 EDT 2009 i686 i686 i386 GNU/Linux
[root@charon ~]# yum search vnc
Loaded plugins: fastestmirror, refresh-packagekit
Loading mirror speeds from cached hostfile
* fedora: sunsite.icm.edu.pl
* rpmfusion-free-updates: ftp.icm.edu.pl
* rpmfusion-nonfree-updates: ftp.icm.edu.pl
* rpmfusion-free: ftp.icm.edu.pl
* rpmfusion-nonfree: ftp.icm.edu.pl
* fusion: www.dfm.uninsubria.it
* updates: sunsite.icm.edu.pl
======================================================== Matched: vnc ========================================================
kdenetwork.i386 : K Desktop Environment - Network Applications
conspy.i386 : Remote control for text mode virtual consoles
gnome-rdp.i386 : Remote Desktop Protocol client for the GNOME desktop environment
gtk-vnc.i386 : A GTK widget for VNC clients
gtk-vnc-devel.i386 : Libraries, includes, etc. to compile with the gtk-vnc library
gtk-vnc-python.i386 : Python bindings for the gtk-vnc library
libvncserver.i386 : Library to make writing a vnc server easy
libvncserver-devel.i386 : Development files for libvncserver
mingw32-gtk-vnc.noarch : MinGW Windows port of VNC client GTK widget
netbeans-svnclientadapter.noarch : Subversion Client Adapter
pyvnc2swf.noarch : Vnc screen recorder
svncpp.i386 : C++ bindings for the Subversion client library
svncpp-devel.i386 : Development resources for the 'svncpp' library
tsclient.i386 : Client for VNC and Windows Terminal Server
vinagre.i386 : VNC client for the GNOME desktop
vino.i386 : A remote desktop system for GNOME
virt-viewer.i386 : Virtual Machine Viewer
vnc.i386 : A remote display system
vnc-libs.i386 : VNC Remote framebuffer libraries
vnc-ltsp-config.noarch : Easy Enabler of VNC remote LTSP desktops
vnc-reflector.i386 : A specialized, multiplexing vnc proxy server
vnc-server.i386 : A VNC server
x2vnc.i386 : Dual screen hack for VNC
xenwatch.i386 : Virtualization utilities, mostly for Xen
xorg-x11-server-source.i386 : Xserver source code required to build VNC server (Xvnc)
xwnc.i386 : Mix of Xvnc and XDarwin with improved protocol
[root@charon ~]#
Jak mogę zrobić zdalny pulpit do komputera z Fedorą za mną (no za mną i trochę w lewo ;))? Szukałem w sieci, ale nic z tego co znalazłem nie zrozumiałem.
Długo.
http://www.youtube.com/watch?v=Ey4ICHyeF8Q - wersja nie wymagająca zrozumienia
http://www.cs.caltech.edu/courses/cs11/misc/xwindows.html - wersja wymagająca zrozumienia
Arabski: Dobra, ślepy jestem, potrzebuje mocniejszych okularów, sorka. To mi wypluło:
               : environment
                   : library
                            : (Xvnc)
Spróbuje je wszystkie zainstalować.
ysio: Dzięki za link, popróbuje.
[bartek@charon ~]$ yum info vnc
Installed Packages
Arch       : i386
Version    : 4.1.3
Release    : 1.fc10
Repo       : installed
Summary    : A remote display system
URL        : http://www.realvnc.com
License    : GPLv2
Description: Virtual Network Computing (VNC) is a remote display system which
           : allows you to view a computing 'desktop' environment not only on the
           : machine where it is running, but from anywhere on the Internet and
           : from a wide variety of machine architectures.  This package contains a
           : client which will allow you to connect to other desktops running a VNC
           : server.
Z mojej strony <EOT>
Mam VNC-Server i go nawet skonfigurowałem ^^ VNC też mam ^^ Serwery włączone na obu komputerach, skonfigurowane i włączają się na starcie (http://www.g-loaded.eu/2005/11/10/configure-vnc-server-in-fedora/) Komputer przez vinagre widzi siebie, a laptop siebie nie. Laptop komputera nie, ani komputer laptopa. Laptop łączy sie przez sieć bezprzewodową; kompter ethernet.
sprawdź firewall - pootwieraj porty 5900 tcp dla vnc, ew 5800 tcp dla przeglądarki z javą
Mogę go poprostu na tą sesje wyłączyć? I jak zadziała to potem ustawić tak jak mówisz?
Wyłączyłem. Widze na laptopie w vinagre komputer ale jak klikne dwa razy to pisze "Połączenie z komputerem 'server' zostało zamknięte".
EDIT: Jak lącze się z Windowsem to to samo się dzieje.
