Sterownik Czytnika/programatora Phoenix Usb
PstryPtak
hi
i have the seem problem with this dvice
did any one solve this problem with driver
i have os ubuntu hardy 8.04
thanks for any help
here the error when i try to install driver they give it to me
ftdi_sio.c: At top level:
ftdi_sio.c:1325: warning: ?struct usb_serial? declared inside parameter list
ftdi_sio.c:1326: error: conflicting types for ?ftdi_8U232AM_startup?
ftdi_sio.c:692: error: previous declaration of ?ftdi_8U232AM_startup? was here
ftdi_sio.c: In function ?ftdi_8U232AM_startup?:
ftdi_sio.c:1331: warning: passing argument 1 of ?ftdi_common_startup? from incompatible pointer type
ftdi_sio.c:1336: error: dereferencing pointer to incomplete type
ftdi_sio.c:1345: warning: ?struct usb_serial? declared inside parameter list
ftdi_sio.c:1346: error: conflicting types for ?ftdi_FT232BM_startup?
ftdi_sio.c:693: error: previous declaration of ?ftdi_FT232BM_startup? was here
ftdi_sio.c: In function ?ftdi_FT232BM_startup?:
ftdi_sio.c:1351: warning: passing argument 1 of ?ftdi_common_startup? from incompatible pointer type
ftdi_sio.c:1356: error: dereferencing pointer to incomplete type
ftdi_sio.c:1365: warning: ?struct usb_serial? declared inside parameter list
ftdi_sio.c:1366: error: conflicting types for ?ftdi_FT2232C_startup?
ftdi_sio.c:694: error: previous declaration of ?ftdi_FT2232C_startup? was here
ftdi_sio.c: In function ?ftdi_FT2232C_startup?:
ftdi_sio.c:1372: warning: passing argument 1 of ?ftdi_common_startup? from incompatible pointer type
ftdi_sio.c:1377: error: dereferencing pointer to incomplete type
ftdi_sio.c:1379: error: dereferencing pointer to incomplete type
ftdi_sio.c:1394: warning: ?struct usb_serial? declared inside parameter list
ftdi_sio.c:1395: error: conflicting types for ?ftdi_FT232R_startup?
ftdi_sio.c:695: error: previous declaration of ?ftdi_FT232R_startup? was here
ftdi_sio.c: In function ?ftdi_FT232R_startup?:
ftdi_sio.c:1400: warning: passing argument 1 of ?ftdi_common_startup? from incompatible pointer type
ftdi_sio.c:1405: error: dereferencing pointer to incomplete type
ftdi_sio.c:1414: warning: ?struct usb_serial? declared inside parameter list
ftdi_sio.c:1415: error: conflicting types for ?ftdi_USB_UIRT_startup?
ftdi_sio.c:696: error: previous declaration of ?ftdi_USB_UIRT_startup? was here
ftdi_sio.c: In function ?ftdi_USB_UIRT_startup?:
ftdi_sio.c:1420: warning: passing argument 1 of ?ftdi_8U232AM_startup? from incompatible pointer type
ftdi_sio.c:1425: error: dereferencing pointer to incomplete type
ftdi_sio.c:1435: warning: ?struct usb_serial? declared inside parameter list
ftdi_sio.c:1436: error: conflicting types for ?ftdi_HE_TIRA1_startup?
ftdi_sio.c:697: error: previous declaration of ?ftdi_HE_TIRA1_startup? was here
ftdi_sio.c: In function ?ftdi_HE_TIRA1_startup?:
ftdi_sio.c:1441: warning: passing argument 1 of ?ftdi_FT232BM_startup? from incompatible pointer type
ftdi_sio.c:1446: error: dereferencing pointer to incomplete type
ftdi_sio.c:1457: warning: ?struct usb_serial? declared inside parameter list
ftdi_sio.c:1458: error: conflicting types for ?ftdi_userdev_startup?
ftdi_sio.c:698: error: previous declaration of ?ftdi_userdev_startup? was here
ftdi_sio.c: In function ?ftdi_userdev_startup?:
ftdi_sio.c:1466: warning: passing argument 1 of ?ftdi_8U232AM_startup? from incompatible pointer type
ftdi_sio.c:1471: error: dereferencing pointer to incomplete type
ftdi_sio.c:1486: warning: ?struct usb_serial? declared inside parameter list
ftdi_sio.c:1487: error: conflicting types for ?ftdi_shutdown?
ftdi_sio.c:699: error: previous declaration of ?ftdi_shutdown? was here
ftdi_sio.c: In function ?ftdi_shutdown?:
ftdi_sio.c:1489: error: dereferencing pointer to incomplete type
ftdi_sio.c:1490: error: dereferencing pointer to incomplete type
ftdi_sio.c:1502: error: dereferencing pointer to incomplete type
ftdi_sio.c:1522: error: dereferencing pointer to incomplete type
ftdi_sio.c:1523: error: dereferencing pointer to incomplete type
ftdi_sio.c:1524: error: dereferencing pointer to incomplete type
ftdi_sio.c:1529: warning: ?struct usb_serial_port? declared inside parameter list
ftdi_sio.c:1530: error: conflicting types for ?ftdi_open?
ftdi_sio.c:700: error: previous declaration of ?ftdi_open? was here
ftdi_sio.c: In function ?ftdi_open?:
ftdi_sio.c:1532: error: dereferencing pointer to incomplete type
ftdi_sio.c:1533: error: dereferencing pointer to incomplete type
ftdi_sio.c:1541: error: dereferencing pointer to incomplete type
ftdi_sio.c:1545: error: dereferencing pointer to incomplete type
ftdi_sio.c:1548: error: ?CONFIG_HZ? undeclared (first use in this function)
ftdi_sio.c:1555: warning: passing argument 1 of ?ftdi_set_termios? from incompatible pointer type
ftdi_sio.c:1560: warning: passing argument 1 of ?set_dtr? from incompatible pointer type
ftdi_sio.c:1563: warning: passing argument 1 of ?set_rts? from incompatible pointer type
ftdi_sio.c:1568: warning: implicit declaration of function ?FILL_BULK_URB?
ftdi_sio.c:1568: error: dereferencing pointer to incomplete type
ftdi_sio.c:1569: error: dereferencing pointer to incomplete type
ftdi_sio.c:1570: error: dereferencing pointer to incomplete type
ftdi_sio.c:1572: error: dereferencing pointer to incomplete type
ftdi_sio.c:1572: error: too few arguments to function ?usb_submit_urb?
ftdi_sio.c:1590: warning: ?struct usb_serial_port? declared inside parameter list
ftdi_sio.c:1591: error: conflicting types for ?ftdi_close?
ftdi_sio.c:701: error: previous declaration of ?ftdi_close? was here
ftdi_sio.c: In function ?ftdi_close?:
ftdi_sio.c:1593: error: dereferencing pointer to incomplete type
ftdi_sio.c:1594: error: dereferencing pointer to incomplete type
ftdi_sio.c:1600: warning: implicit declaration of function ?get_usb_serial?
ftdi_sio.c:1600: warning: assignment makes pointer from integer without a cast
ftdi_sio.c:1604: error: dereferencing pointer to incomplete type
ftdi_sio.c:1607: error: dereferencing pointer to incomplete type
ftdi_sio.c:1608: error: dereferencing pointer to incomplete type
ftdi_sio.c:1611: error: ?CONFIG_HZ? undeclared (first use in this function)
ftdi_sio.c:1616: warning: passing argument 1 of ?set_dtr? from incompatible pointer type
ftdi_sio.c:1620: warning: passing argument 1 of ?set_rts? from incompatible pointer type
ftdi_sio.c:1626: error: dereferencing pointer to incomplete type
ftdi_sio.c:1627: error: dereferencing pointer to incomplete type
ftdi_sio.c:1648: warning: ?struct usb_serial_port? declared inside parameter list
ftdi_sio.c:1649: error: conflicting types for ?ftdi_write?
ftdi_sio.c:702: error: previous declaration of ?ftdi_write? was here
ftdi_sio.c: In function ?ftdi_write?:
ftdi_sio.c:1650: warning: initialization makes pointer from integer without a cast
ftdi_sio.c:1651: error: dereferencing pointer to incomplete type
ftdi_sio.c:1734: warning: implicit declaration of function ?usb_serial_debug_data?
ftdi_sio.c:1737: error: dereferencing pointer to incomplete type
ftdi_sio.c:1738: error: dereferencing pointer to incomplete type
ftdi_sio.c:1741: error: ?USB_QUEUE_BULK? undeclared (first use in this function)
ftdi_sio.c:1748: error: too few arguments to function ?usb_submit_urb?
ftdi_sio.c: In function ?ftdi_write_bulk_callback?:
ftdi_sio.c:1778: warning: implicit declaration of function ?port_paranoia_check?
ftdi_sio.c:1788: error: dereferencing pointer to incomplete type
ftdi_sio.c:1789: warning: implicit declaration of function ?queue_task?
ftdi_sio.c:1789: error: dereferencing pointer to incomplete type
ftdi_sio.c:1789: error: ?tq_immediate? undeclared (first use in this function)
ftdi_sio.c:1790: warning: implicit declaration of function ?mark_bh?
ftdi_sio.c:1790: error: ?IMMEDIATE_BH? undeclared (first use in this function)
ftdi_sio.c:1795: warning: ?struct usb_serial_port? declared inside parameter list
ftdi_sio.c:1796: error: conflicting types for ?ftdi_write_room?
ftdi_sio.c:703: error: previous declaration of ?ftdi_write_room? was here
ftdi_sio.c: In function ?ftdi_write_room?:
ftdi_sio.c:1797: error: dereferencing pointer to incomplete type
ftdi_sio.c:1819: warning: ?struct usb_serial_port? declared inside parameter list
ftdi_sio.c:1820: error: conflicting types for ?ftdi_chars_in_buffer?
ftdi_sio.c:704: error: previous declaration of ?ftdi_chars_in_buffer? was here
ftdi_sio.c: In function ?ftdi_chars_in_buffer?:
ftdi_sio.c:1824: error: dereferencing pointer to incomplete type
ftdi_sio.c: In function ?ftdi_read_bulk_callback?:
ftdi_sio.c:1865: error: ?USB_QUEUE_BULK? undeclared (first use in this function)
ftdi_sio.c:1873: error: dereferencing pointer to incomplete type
ftdi_sio.c:1876: warning: assignment makes pointer from integer without a cast
ftdi_sio.c:1882: error: dereferencing pointer to incomplete type
ftdi_sio.c:1888: error: dereferencing pointer to incomplete type
ftdi_sio.c:1947: error: ?struct tty_struct? has no member named ?flip?
ftdi_sio.c:1987: error: dereferencing pointer to incomplete type
ftdi_sio.c:1989: error: dereferencing pointer to incomplete type
ftdi_sio.c:1990: error: dereferencing pointer to incomplete type
ftdi_sio.c:1991: error: dereferencing pointer to incomplete type
ftdi_sio.c:1994: error: dereferencing pointer to incomplete type
ftdi_sio.c:1994: error: too few arguments to function ?usb_submit_urb?
ftdi_sio.c:2003: warning: ?struct usb_serial_port? declared inside parameter list
ftdi_sio.c:2004: error: conflicting types for ?ftdi_break_ctl?
ftdi_sio.c:709: error: previous declaration of ?ftdi_break_ctl? was here
ftdi_sio.c: In function ?ftdi_break_ctl?:
ftdi_sio.c:2005: error: dereferencing pointer to incomplete type
ftdi_sio.c:2006: error: dereferencing pointer to incomplete type
ftdi_sio.c:2021: error: dereferencing pointer to incomplete type
ftdi_sio.c:2025: error: ?CONFIG_HZ? undeclared (first use in this function)
ftdi_sio.c:2039: warning: ?struct usb_serial_port? declared inside parameter list
ftdi_sio.c:2040: error: conflicting types for ?ftdi_set_termios?
ftdi_sio.c:707: error: previous declaration of ?ftdi_set_termios? was here
ftdi_sio.c: In function ?ftdi_set_termios?:
ftdi_sio.c:2041: error: dereferencing pointer to incomplete type
ftdi_sio.c:2043: error: dereferencing pointer to incomplete type
ftdi_sio.c:2048: error: dereferencing pointer to incomplete type
ftdi_sio.c:2055: error: dereferencing pointer to incomplete type
ftdi_sio.c:2057: error: dereferencing pointer to incomplete type
ftdi_sio.c:2058: error: dereferencing pointer to incomplete type
ftdi_sio.c:2064: error: dereferencing pointer to incomplete type
ftdi_sio.c:2067: error: dereferencing pointer to incomplete type
ftdi_sio.c:2100: error: dereferencing pointer to incomplete type
ftdi_sio.c:2111: error: dereferencing pointer to incomplete type
ftdi_sio.c:2115: error: ?CONFIG_HZ? undeclared (first use in this function)
ftdi_sio.c:2119: warning: passing argument 1 of ?set_dtr? from incompatible pointer type
ftdi_sio.c:2122: warning: passing argument 1 of ?set_rts? from incompatible pointer type
ftdi_sio.c:2128: warning: passing argument 1 of ?change_speed? from incompatible pointer type
ftdi_sio.c:2132: warning: passing argument 1 of ?set_dtr? from incompatible pointer type
ftdi_sio.c:2135: warning: passing argument 1 of ?set_rts? from incompatible pointer type
ftdi_sio.c:2144: error: dereferencing pointer to incomplete type
ftdi_sio.c:2145: error: dereferencing pointer to incomplete type
ftdi_sio.c:2166: error: dereferencing pointer to incomplete type
ftdi_sio.c:2167: error: dereferencing pointer to incomplete type
ftdi_sio.c:2170: error: dereferencing pointer to incomplete type
ftdi_sio.c:2171: error: dereferencing pointer to incomplete type
ftdi_sio.c:2182: error: dereferencing pointer to incomplete type
ftdi_sio.c:2183: error: dereferencing pointer to incomplete type
ftdi_sio.c:2197: warning: ?struct usb_serial_port? declared inside parameter list
ftdi_sio.c:2198: error: conflicting types for ?ftdi_ioctl?
ftdi_sio.c:708: error: previous declaration of ?ftdi_ioctl? was here
ftdi_sio.c: In function ?ftdi_ioctl?:
ftdi_sio.c:2199: error: dereferencing pointer to incomplete type
ftdi_sio.c:2200: error: dereferencing pointer to incomplete type
ftdi_sio.c:2216: error: dereferencing pointer to incomplete type
ftdi_sio.c:2217: error: dereferencing pointer to incomplete type
ftdi_sio.c:2221: error: ?CONFIG_HZ? undeclared (first use in this function)
ftdi_sio.c:2231: error: dereferencing pointer to incomplete type
ftdi_sio.c:2232: error: dereferencing pointer to incomplete type
ftdi_sio.c:2260: warning: passing argument 1 of ?set_dtr? from incompatible pointer type
ftdi_sio.c:2265: warning: passing argument 1 of ?set_rts? from incompatible pointer type
ftdi_sio.c:2277: warning: passing argument 1 of ?set_dtr? from incompatible pointer type
ftdi_sio.c:2283: warning: passing argument 1 of ?set_rts? from incompatible pointer type
ftdi_sio.c:2296: warning: passing argument 1 of ?set_dtr? from incompatible pointer type
ftdi_sio.c:2302: warning: passing argument 1 of ?set_rts? from incompatible pointer type
ftdi_sio.c:2320: warning: passing argument 1 of ?get_serial_info? from incompatible pointer type
ftdi_sio.c:2323: warning: passing argument 1 of ?set_serial_info? from incompatible pointer type
ftdi_sio.c:2379: warning: ?struct usb_serial_port? declared inside parameter list
ftdi_sio.c:2380: error: conflicting types for ?ftdi_throttle?
ftdi_sio.c:710: error: previous declaration of ?ftdi_throttle? was here
ftdi_sio.c: In function ?ftdi_throttle?:
ftdi_sio.c:2382: error: dereferencing pointer to incomplete type
ftdi_sio.c:2386: warning: ?struct usb_serial_port? declared inside parameter list
ftdi_sio.c:2387: error: conflicting types for ?ftdi_unthrottle?
ftdi_sio.c:711: error: previous declaration of ?ftdi_unthrottle? was here
ftdi_sio.c: In function ?ftdi_unthrottle?:
ftdi_sio.c:2389: error: dereferencing pointer to incomplete type
ftdi_sio.c:2393: error: dereferencing pointer to incomplete type
ftdi_sio.c:2395: error: dereferencing pointer to incomplete type
ftdi_sio.c:2396: error: dereferencing pointer to incomplete type
ftdi_sio.c:2397: error: dereferencing pointer to incomplete type
ftdi_sio.c:2400: error: dereferencing pointer to incomplete type
ftdi_sio.c:2400: error: too few arguments to function ?usb_submit_urb?
ftdi_sio.c: In function ?ftdi_init?:
ftdi_sio.c:2409: warning: implicit declaration of function ?usb_serial_register?
ftdi_sio.c: In function ?ftdi_exit?:
ftdi_sio.c:2437: warning: implicit declaration of function ?usb_serial_deregister?
ftdi_sio.c:2456: error: expected ?)? before string constant
ftdi_sio.c:2459: error: expected ?)? before string constant
ftdi_sio.c:2462: error: expected ?)? before string constant
make: *** [ftdi_sio.o] Error 1
  • 4 weeks later...
