Kitaro Napisano Listopad 5, 2004 Zgłoszenie Share Napisano Listopad 5, 2004 Witam ostatnio przeglondałem logi i mam takie coś Nov 5 13:54:47 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=81.23.250.167 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=38232 DF PROTO=TCP SPT=4242 DPT=32793 WINDOW=5792 RES=0x00 ACK PSH URGP=0 Nov 5 13:54:48 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=81.23.250.167 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=38233 DF PROTO=TCP SPT=4242 DPT=32793 WINDOW=5792 RES=0x00 ACK PSH URGP=0 Nov 5 13:54:48 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=81.23.250.167 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=38234 DF PROTO=TCP SPT=4242 DPT=32793 WINDOW=5792 RES=0x00 ACK PSH URGP=0 Nov 5 13:54:50 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=81.23.250.167 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=38235 DF PROTO=TCP SPT=4242 DPT=32793 WINDOW=5792 RES=0x00 ACK PSH URGP=0 Nov 5 13:54:53 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=81.23.250.167 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=38236 DF PROTO=TCP SPT=4242 DPT=32793 WINDOW=5792 RES=0x00 ACK PSH URGP=0 Nov 5 13:54:58 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=81.23.250.167 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=38237 DF PROTO=TCP SPT=4242 DPT=32793 WINDOW=5792 RES=0x00 ACK PSH URGP=0 Nov 5 13:55:09 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=81.23.250.167 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=38238 DF PROTO=TCP SPT=4242 DPT=32793 WINDOW=5792 RES=0x00 ACK PSH URGP=0 Nov 5 13:55:20 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=193.19.227.24 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=15006 DF PROTO=TCP SPT=4661 DPT=32784 WINDOW=5718 RES=0x00 ACK PSH URGP=0 Nov 5 13:55:31 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=81.23.250.167 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=38239 DF PROTO=TCP SPT=4242 DPT=32793 WINDOW=5792 RES=0x00 ACK PSH URGP=0 Nov 5 13:57:20 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=193.19.227.24 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=15007 DF PROTO=TCP SPT=4661 DPT=32784 WINDOW=5718 RES=0x00 ACK PSH URGP=0 Nov 5 13:59:20 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=193.19.227.24 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=15008 DF PROTO=TCP SPT=4661 DPT=32784 WINDOW=5718 RES=0x00 ACK PSH URGP=0 Nov 5 14:01:20 shadow kernel: IN=eth0 OUT= MAC=00:00:1c:d6:ae:90:00:30:4f:25:b0:ac:08:00 SRC=193.19.227.24 DST=192.168.0.106 LEN=66 TOS=0x00 PREC=0x00 TTL=49 ID=15009 DF PROTO=TCP SPT=4661 DPT=32784 WINDOW=5718 RES=0x00 ACK PSH URGP=0 co to może znaczyc? może ktoś się domnie włamał Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Listopad 5, 2004 Zgłoszenie Share Napisano Listopad 5, 2004 Używasz Firestartera? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kitaro Napisano Listopad 5, 2004 Autor Zgłoszenie Share Napisano Listopad 5, 2004 Używasz Firestartera? tak, a te logi mają coś wspólnego z firestarterem? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Listopad 5, 2004 Zgłoszenie Share Napisano Listopad 5, 2004 tak, a te logi mają coś wspólnego z firestarterem? Kliknij na link co Ci podałem. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kitaro Napisano Listopad 6, 2004 Autor Zgłoszenie Share Napisano Listopad 6, 2004 tak, a te logi mają coś wspólnego z firestarterem? Kliknij na link co Ci podałem. no juz zrobiłem tak jak tam pisało, tylko nie bardzo rozumie co te logi mają wspólnego z firestarterem, chyba za ciemny na to jestem Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Listopad 6, 2004 Zgłoszenie Share Napisano Listopad 6, 2004 no juz zrobiłem tak jak tam pisało, tylko nie bardzo rozumie co te logi mają wspólnego z firestarterem, chyba za ciemny na to jestem Ja tam firestartera nie używam, ale z tego co widzę, to on wszystko loguje jak popadnie (czy jakoś tak). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Kitaro Napisano Listopad 7, 2004 Autor Zgłoszenie Share Napisano Listopad 7, 2004 Ja tam firestartera nie używam, ale z tego co widzę, to on wszystko loguje jak popadnie (czy jakoś tak). hmmm dziwny ten firestarter jest dzięki za pomoc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
