Problem Z Kismetem
benji
Witam, mam nastepujacy problem z kismetem: po skonfigurowaniu i probie uruchomienia dostaje taki komunikat:
[root@koga ~]# kismet
Launching kismet_server: /usr/bin/kismet_server
Will drop privs to kismet (492) gid 488
No specific sources given to be enabled, all will be enabled.
Non-RFMon VAPs will be destroyed on multi-vap interfaces (ie, madwifi-ng)
Enabling channel hopping.
Enabling channel splitting.
NOTICE: Disabling channel hopping, no enabled sources are able to change channel.
Source 0 (mywifi): Enabling monitor mode for iwl3945 source interface wlan0 channel 6...
Source 0 (mywifi): Opening iwl3945 source interface wlan0...
Spawned channel control process 2464
Dropped privs to kismet (492) gid 488
Allowing clients to fetch WEP keys.
WARNING:  Disabling GPS logging.
Logging networks to /var/log/kismet/Kismet-Jul-08-2009-6.network
Logging networks in CSV format to /var/log/kismet/Kismet-Jul-08-2009-6.csv
Logging networks in XML format to /var/log/kismet/Kismet-Jul-08-2009-6.xml
Logging cryptographically weak packets to /var/log/kismet/Kismet-Jul-08-2009-6.weak
Logging cisco product information to /var/log/kismet/Kismet-Jul-08-2009-6.cisco
Logging data to /var/log/kismet/Kismet-Jul-08-2009-6.dump
Writing data files to disk every 300 seconds.
Mangling encrypted and fuzzy data packets.
Tracking probe responses and associating probe networks.
Reading AP manufacturer data and defaults from /etc/kismet/ap_manuf
Reading client manufacturer data and defaults from /etc/kismet/client_manuf
Using network-classifier based data encryption detection
Not tracking duplicate IVs
Dump file format: wiretap (local code) dump
Crypt file format: airsnort (weak packet) dump
Kismet 2008.05.R1 (Kismet)
Logging data networks CSV XML weak cisco
Listening on port 2501.
Allowing connections from 127.0.0.1/255.255.255.255
Registering builtin client/server protocols...
Registering requested alerts...
Registering builtin timer events...
Gathering packets...
Launched client, pid 2466
Launching kismet_client: /usr/bin/kismet_client
NOTICE: configdir '/root/' does not exist, making it.
FATAL:  Could not make configdir: File exists
Didn't see any weak encryption packets, unlinking weak file
Sending termination request to channel control child 2464...
Waiting for channel control child 2464 to exit...
WARNING: Error disabling monitor mode: mode set ioctl failed 16:Device or resource busy
WARNING: mywifi (wlan0) left in an unknown state.  You may need to manually
	 restart or reconfigure it for normal operation.
WARNING: Sometimes cards don't always come out of monitor mode
	 cleanly.  If your card is not fully working, you may need to
Kismet exiting.[codebox]>
Oto moj plik konfiguracyjny:
[codebox][root@koga /]# cat /etc/kismet/kismet.conf
# Kismet config file
# Most of the "static" configs have been moved to here -- the command line
# config was getting way too crowded and cryptic.  We want functionality,
# not continually reading --help!
# Version of Kismet config
version=2007.09.R1
# Name of server (Purely for organizational purposes)
servername=Kismet
# User to setid to (should be your normal user)
suiduser=kismet
# Do we try to put networkmanager to sleep?  If you use NM, this is probably
# what you want to do, so that it will leave the interfaces alone while
# Kismet is using them.  This requires DBus support!
networkmanagersleep=false
# Sources are defined as:
# source=sourcetype,interface,name[,initialchannel]
# Source types and required drivers are listed in the README under the
# CAPTURE SOURCES section.
# The initial channel is optional, if hopping is not enabled it can be used
# to set the channel the interface listens on.
# YOU MUST CHANGE THIS TO BE THE SOURCE YOU WANT TO USE
source=iwl3945,wlan0,mywifi
# Comma-separated list of sources to enable.  This is only needed if you defined
# multiple sources and only want to enable some of them.  By default, all defined
# sources are enabled.
# For example:
# enablesources=prismsource,ciscosource
# Automatically destroy VAPs on multi-vap interfaces (like madwifi-ng).
# Madwifi-ng doesn't work in rfmon when non-rfmon VAPs are present, however
# this is a fairly invasive change to the system so it CAN be disabled.  Expect
# things not to work in most cases if you do disable it, however.
vapdestroy=true
# Do we channelhop?
channelhop=true
# How many channels per second do we hop?  (1-10)
channelvelocity=5
# By setting the dwell time for channel hopping we override the channelvelocity
# setting above and dwell on each channel for the given number of seconds.
#channeldwell=10
# Do we split channels between cards on the same spectrum?  This means if
# multiple 802.11b capture sources are defined, they will be offset to cover
# the most possible spectrum at a given time.  This also controls splitting
# fine-tuned sourcechannels lines which cover multiple interfaces (see below)
channelsplit=true
# Basic channel hopping control:
# These define the channels the cards hop through for various frequency ranges
# supported by Kismet.   More finegrain control is available via the
# "sourcechannels" configuration option.
# Don't change the IEEE80211<x> identifiers or channel hopping won't work.
# Users outside the US might want to use this list:
# defaultchannels=IEEE80211b:1,7,13,2,8,3,14,9,4,10,5,11,6,12
defaultchannels=IEEE80211b:1,6,11,2,7,3,8,4,9,5,10
# 802.11g uses the same channels as 802.11b...
defaultchannels=IEEE80211g:1,6,11,2,7,3,8,4,9,5,10
# 802.11a channels are non-overlapping so sequential is fine.  You may want to
# adjust the list depending on the channels your card actually supports.
# defaultchannels=IEEE80211a:36,40,44,48,52,56,60,64,100,104,108,112,116,120,124,128,132,136,140,149,153,
157,161,184,188,192,196,200,204,208,212,216
# Combo cards like Atheros use both 'a' and 'b/g' channels.  Of course, you
# can also explicitly override a given source.  You can use the script
# extras/listchan.pl to extract all the channels your card supports.
defaultchannels=IEEE80211ab:1,6,11,2,7,3,8,4,9,5,10,36,40,44,48,52,56,60,64
# Fine-tuning channel hopping control:
# The sourcechannels option can be used to set the channel hopping for
# specific interfaces, and to control what interfaces share a list of
# channels for split hopping.  This can also be used to easily lock
# one card on a single channel while hopping with other cards.
# Any card without a sourcechannel definition will use the standard hopping
# list.
# sourcechannels=sourcename[,sourcename]:ch1,ch2,ch3,...chN
# ie, for us channels on the source 'prism2source' (same as normal channel
# hopping behavior):
# sourcechannels=prism2source:1,6,11,2,7,3,8,4,9,5,10
# Given two capture sources, "prism2a" and "prism2b", we want prism2a to stay
# on channel 6 and prism2b to hop normally.  By not setting a sourcechannels
# line for prism2b, it will use the standard hopping.
# sourcechannels=prism2a:6
# To assign the same custom hop channel to multiple sources, or to split the
# same custom hop channel over two sources (if splitchannels is true), list
# them all on the same sourcechannels line:
# sourcechannels=prism2a,prism2b,prism2c:1,6,11
# Port to serve GUI data
tcpport=2501
# People allowed to connect, comma seperated IP addresses or network/mask
# blocks.  Netmasks can be expressed as dotted quad (/255.255.255.0) or as
# numbers (/24)
allowedhosts=127.0.0.1
# Address to bind to.  Should be an address already configured already on
# this host, reverts to INADDR_ANY if specified incorrectly.
bindaddress=127.0.0.1
# Maximum number of concurrent GUI's
maxclients=5
# Do we have a GPS?
gps=false
# Host:port that GPSD is running on.  This can be localhost OR remote!
gpshost=localhost:2947
# Do we lock the mode?  This overrides coordinates of lock "0", which will
# generate some bad information until you get a GPS lock, but it will
# fix problems with GPS units with broken NMEA that report lock 0
gpsmodelock=false
# Packet filtering options:
# filter_tracker - Packets filtered from the tracker are not processed or
#				  recorded in any way.
# filter_dump	- Packets filtered at the dump level are tracked, displayed,
#				  and written to the csv/xml/network/etc files, but not
#				  recorded in the packet dump
# filter_export  - Controls what packets influence the exported CSV, network,
#				  xml, gps, etc files.
# All filtering options take arguments containing the type of address and
# addresses to be filtered.  Valid address types are 'ANY', 'BSSID',
# 'SOURCE', and 'DEST'.  Filtering can be inverted by the use of '!' before
# the address.  For example,
# filter_tracker=ANY(!00:00:DE:AD:BE:EF)
# has the same effect as the previous mac_filter config file option.
# filter_tracker=...
# filter_dump=...
# filter_export=...
# Alerts to be reported and the throttling rates.
# alert=name,throttle/unit,burst/unit
# The throttle/unit describes the number of alerts of this type that are
# sent per time unit.  Valid time units are second, minute, hour, and day.
# Burst rates control the number of packets sent at a time
# For example:
# alert=FOO,10/min,5/sec
# Would allow 5 alerts per second, and 10 alerts total per minute.
# A throttle rate of 0 disables throttling of the alert.
# See the README for a list of alert types.
alert=NETSTUMBLER,10/min,1/sec
alert=WELLENREITER,10/min,1/sec
alert=LUCENTTEST,10/min,1/sec
alert=DEAUTHFLOOD,10/min,2/sec
alert=BCASTDISCON,10/min,2/sec
alert=CHANCHANGE,5/min,1/sec
alert=AIRJACKSSID,5/min,1/sec
alert=PROBENOJOIN,10/min,1/sec
alert=DISASSOCTRAFFIC,10/min,1/sec
alert=NULLPROBERESP,10/min,1/sec
alert=BSSTIMESTAMP,10/min,1/sec
alert=MSFBCOMSSID,10/min,1/sec
alert=LONGSSID,10/min,1/sec
alert=MSFDLINKRATE,10/min,1/sec
alert=MSFNETGEARBEACON,10/min,1/sec
alert=DISCONCODEINVALID,10/min,1/sec
alert=DEAUTHCODEINVALID,10/min,1/sec
# Known WEP keys to decrypt, bssid,hexkey.  This is only for networks where
# the keys are already known, and it may impact throughput on slower hardware.
# Multiple wepkey lines may be used for multiple BSSIDs.
# wepkey=00:DE:AD:C0:DE:00,FEEDFACEDEADBEEF01020304050607080900
# Is transmission of the keys to the client allowed?  This may be a security
# risk for some.  If you disable this, you will not be able to query keys from
# a client.
allowkeytransmit=true
# How often (in seconds) do we write all our data files (0 to disable)
writeinterval=300
# How old (and inactive) does a network need to be before we expire it?
# This is really only good for limited ram environments where keeping a
# total log of all networks is problematic.  This is in seconds, and should
# be set to a large value like 12 or 24 hours.  This is intended for use
# on stationary systems like an IDS
# logexpiry=86400
# Do we limit the number of networks we log?  This is for low-ram situations
# when tracking everything could lead to the system falling down.  This
# should be combined with a sane logexpiry value to flush out very old
# inactive networks.  This is mainly for stationary systems like an IDS.
# limitnets=10000
# Do we track IVs?  this can help identify some attacks, but takes a LOT
# of memory to do so on a busy network.  If you have the RAM, by all
# means turn it on.
trackivs=false
# Do we use sound?
# Not to be confused with GUI sound parameter, this controls wether or not the
# server itself will play sound.  Primarily for headless or automated systems.
sound=false
# Path to sound player
soundplay=/usr/bin/play
# Optional parameters to pass to the player
# soundopts=--volume=.3
# New network found
sound_new=/usr/share/kismet/wav/new_network.wav
# Wepped new network
# sound_new_wep=/var/lib/kismet/wav/new_wep_network.wav
# Network traffic sound
sound_traffic=/usr/share/kismet/wav/traffic.wav
# Network junk traffic found
sound_junktraffic=/usr/share/kismet/wav/junk_traffic.wav
# GPS lock aquired sound
# sound_gpslock=/usr/share/kismet/wav/foo.wav
# GPS lock lost sound
# sound_gpslost=/usr/share/kismet/wav/bar.wav
# Alert sound
sound_alert=/usr/share/kismet/wav/alert.wav
# Does the server have speech? (Again, not to be confused with the GUI's speech)
speech=false
# Server's path to Festival
festival=/usr/bin/festival
# Are we using festival lite?  If so, set the above "festival" path to also
# point to the "flite" binary
flite=false
# Are we using Darwin speech?
darwinsay=false
# What voice do we use?  (Currently only valid on Darwin)
speech_voice=default
# How do we speak?  Valid options:
# speech	Normal speech
# nato	  NATO spellings (alpha, bravo, charlie)
# spell	 Spell the letters out (aye, bee, sea)
speech_type=nato
# speech_encrypted and speech_unencrypted - Speech templates
# Similar to the logtemplate option, this lets you customize the speech output.
# speech_encrypted is used for an encrypted network spoken string
# speech_unencrypted is used for an unencrypted network spoken string
# %b is replaced by the BSSID (MAC) of the network
# %s is replaced by the SSID (name) of the network
# %c is replaced by the CHANNEL of the network
# %r is replaced by the MAX RATE of the network
speech_encrypted=New network detected, s.s.i.d. %s, channel %c, network encrypted.
speech_unencrypted=New network detected, s.s.i.d. %s, channel %c, network open.
# Where do we get our manufacturer fingerprints from?  Assumed to be in the
# default config directory if an absolute path is not given.
ap_manuf=ap_manuf
client_manuf=client_manuf
# Use metric measurements in the output?
metric=false
# Do we write waypoints for gpsdrive to load?  Note:  This is NOT related to
# recent versions of GPSDrive's native support of Kismet.
waypoints=false
# GPSDrive waypoint file.  This WILL be truncated.
waypointdata=%h/.gpsdrive/way_kismet.txt
# Do we want ESSID or BSSID as the waypoint name ?
waypoint_essid=false
# How many alerts do we backlog for new clients?  Only change this if you have
# a -very- low memory system and need those extra bytes, or if you have a high
# memory system and a huge number of alert conditions.
alertbacklog=50
# File types to log, comma seperated
# dump	- raw packet dump
# network - plaintext detected networks
# csv	 - plaintext detected networks in CSV format
# xml	 - XML formatted network and cisco log
# weak	- weak packets (in airsnort format)
# cisco   - cisco equipment CDP broadcasts
# gps	 - gps coordinates
logtypes=dump,network,csv,xml,weak,cisco,gps
# Do we track probe responses and merge probe networks into their owners?
# This isn't always desireable, depending on the type of monitoring you're
# trying to do.
trackprobenets=true
# Do we log "noise" packets that we can't decipher?  I tend to not, since
# they don't have anything interesting at all in them.
noiselog=false
# Do we log corrupt packets?  Corrupt packets have enough header information
# to see what they are, but someting is wrong with them that prevents us from
# completely dissecting them.  Logging these is usually not a bad idea.
corruptlog=true
# Do we log beacon packets or do we filter them out of the dumpfile
beaconlog=true
# Do we log PHY layer packets or do we filter them out of the dumpfile
phylog=true
# Do we mangle packets if we can decrypt them or if they're fuzzy-detected
mangledatalog=true
# Do we do "fuzzy" crypt detection?  (byte-based detection instead of 802.11
# frame headers)
# valid option: Comma seperated list of card types to perform fuzzy detection
#  on, or 'all'
fuzzycrypt=wtapfile,wlanng,wlanng_legacy,wlanng_avs,hostap,wlanng_wext,ipw2200,i
pw2915
# Do we do forgiving fuzzy packet decoding?  This lets us handle borked drivers
# which don't indicate they're including FCS, and then do.
fuzzydecode=wtapfile,radiotap_bsd_a,radiotap_bsd_g,radiotap_bsd_bg,radiotap_bsd_
b,pcapfile
# Do we use network-classifier fuzzy-crypt detection?  This means we expect
# packets that are associated with an encrypted network to be encrypted too,
# and we process them by the same fuzzy compare.
# This essentially replaces the fuzzycrypt per-source option.
netfuzzycrypt=true
# What type of dump do we generate?
# valid option: "wiretap"
dumptype=wiretap
# Do we limit the size of dump logs?  Sometimes ethereal can't handle big ones.
# 0 = No limit
# Anything else = Max number of packets to log to a single file before closing
# and opening a new one.
dumplimit=0
# Do we write data packets to a FIFO for an external data-IDS (such as Snort)?
# See the docs before enabling this.
#fifo=/tmp/kismet_dump
# Default log title
logdefault=Kismet
# logtemplate - Filename logging template.
# This is, at first glance, really nasty and ugly, but you'll hardly ever
# have to touch it so don't complain too much.
# %n is replaced by the logging instance name
# %d is replaced by the current date as Mon-DD-YYYY
# %D is replaced by the current date as YYYYMMDD
# %t is replaced by the starting log time
# %i is replaced by the increment log in the case of multiple logs
# %l is replaced by the log type (dump, status, crypt, etc)
# %h is replaced by the home directory
# ie, "netlogs/%n-%d-%i.dump" called with a logging name of "Pok" could expand
# to something like "netlogs/Pok-Dec-20-01-1.dump" for the first instance and
# "netlogs/Pok-Dec-20-01-2.%l" for the second logfile generated.
# %h/netlots/%n-%d-%i.dump could expand to
# /home/foo/netlogs/Pok-Dec-20-01-2.dump
# Other possibilities:  Sorting by directory
# logtemplate=%l/%n-%d-%i
# Would expand to, for example,
# dump/Pok-Dec-20-01-1
# crypt/Pok-Dec-20-01-1
# and so on.  The "dump", "crypt", etc, dirs must exist before kismet is run
# in this case.
logtemplate=/var/log/kismet/%n-%d-%i.%l
# Where do we store the pid file of the server?
piddir=/var/run/
# Where state info, etc, is stored.  You shouldnt ever need to change this.
# This is a directory.
configdir=%h/
# cloaked SSID file.  You shouldn't ever need to change this.
ssidmap=ssid_map
# Group map file.  You shouldn't ever need to change this.
groupmap=group_map
# IP range map file.  You shouldn't ever need to change this.
ipmap=ip_map
Probowalem juz wylaczac i wlaczac networkmanagera, ustawiac opcje sleepnetworkmanager na false i wynik byl zasadniczo taki sam.
Na innych dystrybucjach nie mam z tym problemu.
Wireshark, yersinia bez problemu dzialaja.
  • Upvote 1
  • Downvote 1
Gość
