GalGavu Napisano Wrzesień 9, 2009 Zgłoszenie Share Napisano Wrzesień 9, 2009 Witam. Zainstalowany miałem na kompie windows 7 i linux Mint'a. Podstanowiłem wgrać też Fedorę 11. No i nie mogę przywrócić do życia Mint'a w grubie. Mój grub.conf: # grub.conf generated by anaconda # # Note that you do not have to rerun grub after making changes to this file # NOTICE: You do not have a /boot partition. This means that # all kernel and initrd paths are relative to /, eg. # root (hd0,4) # kernel /boot/vmlinuz-version ro root=/dev/sda5 # initrd /boot/initrd-version.img #boot=/dev/sda default=0 timeout=5 splashimage=(hd0,4)/boot/grub/splash.xpm.gz hiddenmenu title Fedora (2.6.30.5-43.fc11.x86_64) root (hd0,4) kernel /boot/vmlinuz-2.6.30.5-43.fc11.x86_64 ro root=UUID=e9b817ce-16f0-4663-80c1-a23cf23ef87d rhgb quiet initrd /boot/initrd-2.6.30.5-43.fc11.x86_64.img #title Fedora (2.6.29.4-167.fc11.x86_64) # root (hd0,4) # kernel /boot/vmlinuz-2.6.29.4-167.fc11.x86_64 ro #root=UUID=e9b817ce-16f0-4663-80c1-a23cf23ef87d rhgb quiet # initrd /boot/initrd-2.6.29.4-167.fc11.x86_64.img title Linux Mint 7 Gloria, kernel 2.6.28-11-generic root (hd0,5) kernel /boot/vmlinuz-2.6.28-11-generic root=UUID=a9f0d980-52b0-4be3-9191-e37d7ae900a3 ro quiet splash initrd /boot/initrd.img-2.6.28-11-generic quiet title Windows 7 rootnoverify (hd0,0) chainloader +1 Dostaje po wybraniu Linux Mint'a błąd: error 15 - file not found Moje dalsze dane to: - sudo fdisk -l: [root@Gal-PC ~]# sudo fdisk -l Disk /dev/sda: 160.0 GB, 160041885696 bytes 255 heads, 63 sectors/track, 19457 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0xb3372c8f Device Boot Start End Blocks Id System /dev/sda1 * 1 13 102400 7 HPFS/NTFS Partition 1 does not end on cylinder boundary. /dev/sda2 13 4570 36597760 7 HPFS/NTFS /dev/sda3 4570 16318 94371840 7 HPFS/NTFS /dev/sda4 16319 19457 25214017+ 5 Extended /dev/sda5 * 16319 17912 12800000 83 Linux /dev/sda6 17912 19457 12413951+ 83 Linux - sudo blkid: Disk /dev/sda: 160.0 GB, 160041885696 bytes 255 heads, 63 sectors/track, 19457 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0xb3372c8f Device Boot Start End Blocks Id System /dev/sda1 * 1 13 102400 7 HPFS/NTFS Partition 1 does not end on cylinder boundary. /dev/sda2 13 4570 36597760 7 HPFS/NTFS /dev/sda3 4570 16318 94371840 7 HPFS/NTFS /dev/sda4 16319 19457 25214017+ 5 Extended /dev/sda5 * 16319 17912 12800000 83 Linux /dev/sda6 17912 19457 12413951+ 83 Linux [root@Gal-PC ~]# sudo blkid /dev/sda6: UUID="a9f0d980-52b0-4be3-9191-e37d7ae900a3" TYPE="ext4" /dev/sda5: UUID="e9b817ce-16f0-4663-80c1-a23cf23ef87d" TYPE="ext3" SEC_TYPE="ext2" /dev/sda1: UUID="64E0D1EFE0D1C806" LABEL="System Reserved" TYPE="ntfs" /dev/sda2: UUID="EE6098346098058D" LABEL="Win 7" TYPE="ntfs" /dev/sda3: UUID="4E18924F189235C5" LABEL="WspM-slny" TYPE="ntfs" [root@Gal-PC ~]# sudo blkid /dev/sda6: UUID="a9f0d980-52b0-4be3-9191-e37d7ae900a3" TYPE="ext4" /dev/sda5: UUID="e9b817ce-16f0-4663-80c1-a23cf23ef87d" TYPE="ext3" SEC_TYPE="ext2" /dev/sda1: UUID="64E0D1EFE0D1C806" LABEL="System Reserved" TYPE="ntfs" /dev/sda2: UUID="EE6098346098058D" LABEL="Win 7" TYPE="ntfs" /dev/sda3: UUID="4E18924F189235C5" LABEL="WspM-slny" TYPE="ntfs" Czy jest to spowodowane może tym, że Mint jest na ext4. Jeśli tak to jak to ugryźć. A jeśli nie da się naprawić to jak zainstalować teraz Mint'a tak żeby został mi grub z Fedory (zwyczajnie bardzie mi się podoba i wydaje się szybszy). Pozdrawiam Edit: Problem rozwiązany. Jak się domyślam grub z fedory nie obsługuje ext4. Wgrałem grub'a z Mint'a i to rozwiązało problem. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
