Karta Pcmcia Asus Wl-107g
hello_world
Mam problem z połączeniem się z moim AP poprzez kartę Asus wl-107g opartą o rt2500.
Co najlepsze mam jajko 2.6.31.1 i mi ją wykrywa, diody ładnie się palą NetworkManager pokazuje sieci bezprzewodowe ale jak probuje sie polaczyć to kicha.
Wynik /var/log/messages po włożeniu karty
Oct 11 17:17:50 dell kernel: pcmcia_socket pcmcia_socket0: pccard: CardBus card inserted into slot 0
Oct 11 17:17:50 dell kernel: rt2500pci 0000:04:00.0: enabling device (0000 -> 0002)
Oct 11 17:17:50 dell kernel: rt2500pci 0000:04:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
Oct 11 17:17:50 dell kernel: Registered led device: rt2500pci-phy6::radio
Oct 11 17:17:50 dell kernel: Registered led device: rt2500pci-phy6::quality
Oct 11 17:17:50 dell NetworkManager: <info>  (wlan0): driver supports SSID scans (scan_capa 0x01).
Oct 11 17:17:50 dell NetworkManager: <info>  (wlan0): new 802.11 WiFi device (driver: 'rt2500pci')
Oct 11 17:17:50 dell NetworkManager: <info>  (wlan0): exported as /org/freedesktop/Hal/devices/net_00_23_54_07_f9_ca_0
Oct 11 17:17:55 dell NetworkManager: <info>  (wlan0): device state change: 1 -> 2 (reason 2)
Oct 11 17:17:55 dell NetworkManager: <info>  (wlan0): bringing up device.
Oct 11 17:17:55 dell kernel: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Oct 11 17:17:55 dell NetworkManager: <info>  (wlan0): preparing device.
Oct 11 17:17:55 dell NetworkManager: <info>  (wlan0): deactivating device (reason: 2).
Oct 11 17:17:55 dell NetworkManager: <info>  Policy set 'domek' (eth1) as default for routing and DNS.
Oct 11 17:17:55 dell NetworkManager: <info>  (wlan0): device state change: 2 -> 3 (reason 0)
Oct 11 17:17:55 dell NetworkManager: <info>  (wlan0): supplicant interface state:  starting -> ready
Oct 11 17:18:18 dell kernel: pcmcia_socket pcmcia_socket0: pccard: card ejected from slot 0
Oct 11 17:18:18 dell NetworkManager: <info>  (wlan0): now unmanaged
Oct 11 17:18:18 dell kernel: rt2500pci 0000:04:00.0: PCI INT A disabled
Oct 11 17:18:18 dell NetworkManager: <info>  (wlan0): device state change: 3 -> 1 (reason 36)
Oct 11 17:18:18 dell NetworkManager: <info>  (wlan0): cleaning up...
Oct 11 17:18:28 dell kernel: pcmcia_socket pcmcia_socket0: pccard: CardBus card inserted into slot 0
Oct 11 17:18:28 dell kernel: rt2500pci 0000:04:00.0: enabling device (0000 -> 0002)
Oct 11 17:18:28 dell kernel: rt2500pci 0000:04:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
Oct 11 17:18:28 dell kernel: Registered led device: rt2500pci-phy7::radio
Oct 11 17:18:28 dell kernel: Registered led device: rt2500pci-phy7::quality
Oct 11 17:18:28 dell NetworkManager: <info>  (wlan0): driver supports SSID scans (scan_capa 0x01).
Oct 11 17:18:28 dell NetworkManager: <info>  (wlan0): new 802.11 WiFi device (driver: 'rt2500pci')
Oct 11 17:18:28 dell NetworkManager: <info>  (wlan0): exported as /org/freedesktop/Hal/devices/net_00_23_54_07_f9_ca
Oct 11 17:18:32 dell NetworkManager: <info>  (wlan0): device state change: 1 -> 2 (reason 2)
Oct 11 17:18:32 dell NetworkManager: <info>  (wlan0): bringing up device.
Oct 11 17:18:32 dell kernel: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Oct 11 17:18:32 dell NetworkManager: <info>  (wlan0): preparing device.
Oct 11 17:18:32 dell NetworkManager: <info>  (wlan0): deactivating device (reason: 2).
Oct 11 17:18:32 dell NetworkManager: <info>  Policy set 'domek' (eth1) as default for routing and DNS.
Oct 11 17:18:32 dell NetworkManager: <info>  (wlan0): device state change: 2 -> 3 (reason 0)
Oct 11 17:18:32 dell NetworkManager: <info>  (wlan0): supplicant interface state:  starting -> ready
Wynik lsmod |grep -i rt
lsmod |grep -i rt
rt2500pci              14732  0
rt2x00pci               6892  1 rt2500pci
rt2x00lib              33600  2 rt2500pci,rt2x00pci
input_polldev           3412  1 rt2x00lib
mac80211              147924  2 rt2x00pci,rt2x00lib
cfg80211               70544  2 rt2x00lib,mac80211
eeprom_93cx6            1952  1 rt2500pci
iTCO_vendor_support     2988  1 iTCO_wdt
Jak patrze w logach w momencie proby polaczenia z moją siecia to karta nawiazuje polaczenie z AP ale dhcp z AP nie moze nadać adresu
