Umtsmon + Huawei Technologies Co., Ltd. E220 Hsdpa Modem / E270 Hsdpa/hsupa Modem
Gość
#lsusb
Bus 001 Device 003: ID 12d1:1003 Huawei Technologies Co., Ltd. E220 HSDPA Modem / E270 HSDPA/HSUPA Modem
a w konsoli zwraca:
Ta część wydaje się być OK.
##P5 t=472: stopUpdateTimer
##P5 t=472: PPPConnection run_at_exit() called
##P5 t=472: Runner::findBinaries()
##P5 t=472: lookThroughPath(pccardctl)
##P5 t=472:   * found /sbin/pccardctl
##P5 t=472: lookThroughPath(pppd)
##P5 t=472:   * found /usr/sbin/pppd
##P5 t=472: lookThroughPath(chat)
##P5 t=472:   * found /usr/sbin/chat
##P5 t=472: lookThroughPath(kdesu)
##P5 t=472:   *** searching kdesu really failed :-(
##P5 t=472: lookThroughPath(gnomesu)
##P5 t=472:   *** searching gnomesu really failed :-(
##P5 t=472: lookThroughPath(gksu)
##P5 t=472:   *** searching gksu really failed :-(
##P5 t=472: lookThroughPath(kdesudo)
##P5 t=472:   *** searching kdesudo really failed :-(
##P2 t=472: Helper binary *su (i.e. any known GUI frontend to su) is missing
##P5 t=472: lookThroughPath(usb_modeswitch)
##P5 t=472:   * found /usr/bin/usb_modeswitch
##P5 t=472: DESTRUCTOR TheDeviceManagerSingleton::~TheDeviceManagerSingleton()
##P5 t=472: Device_Option::~Device_Option
##P3 t=472: MonthlyTraffic::save()
##P5 t=472: MonthlyTraffic::save: totals for 2009/11 are: home=0B/0s, roaming=0B/0s
##P3 t=472: LongSerialPort::~LongSerialPort()
##P3 t=472: SerialPort::closeDev() for FD 6
##P5 t=472: 0x86ff200 = Query::setSerial((nil))
##P5 t=472: (nil) = Query::setSerial((nil))
A schody zaczynają się tutaj.
##P5 t=472: DESTRUCTOR TheSettingsSingleton::~TheSettingsSingleton()
#yum search kdesu
polkit-qt.i386 : Qt bindings for PolicyKit
polkit-qt-devel.i386 : Development files for polkit-qt
polkit-qt-examples.i386 : Example files for polkit-qt
taglib-extras.i386 : Taglib support for other formats
taglib-extras-devel.i386 : Development files for taglib-extras
Instalacja pakietów nic nie zmieniła, w google szczątkowe informacje albo nie potrafię wyłowić tych właściwych. Program uruchamiam jako root ponieważ jak uruchomię jako zwykły user to jest jeszcze ciekawiej :/
bash-3.2$ umtsmon
umtsmon version 0.9.72-20090509 .
installing GUI SIGABRT handler
##P1 t=960: Stored device configuration incomplete, reverting to autodetection
##P1 t=961: Found hardware configuration stored to disk
##P1 t=961: binary '/usr/sbin/pppd' is not SUID -> needs fixing
##P1 t=961: binary '/usr/bin/usb_modeswitch' is not SUID -> needs fixing
Na koniec dodam jeszcze że Network manager radzi sobie z modemem bezbłędnie i po instalacji dongla w USB i uzupelnieniu VPN`u dzwoni bezbłędnie i śmiga jak szlony.
Ma ktoś pomysł jak to ugryźć ? Tylko nie wiem czy jest sens, no może edukacyjne.
EDIT:
Operator: Vodafone (moze byc pomocne)
Po zmianie wpisu w sekcji VPN na takie jakie podaje operator, konsola wypluwa:
pppd options in effect:
debug debug debug		# (from command line)
updetach		# (from command line)
idle 7200		# (from command line)
dump		# (from command line)
user web		# (from command line)
password ??????		# (from command line)
/dev/ttyUSB0		# (from command line)
460800		# (from command line)
lock		# (from command line)
crtscts		# (from command line)
modem		# (from command line)
asyncmap 0		# (from command line)
novj		# (from command line)
defaultroute		# (from command line)
usepeerdns		# (from command line)
nobsdcomp		# (from command line)
noipx		# (from command line)
using channel 6
Using interface ppp0
Connect: ppp0 <--> /dev/ttyUSB0
sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0xab788346> <pcomp> <accomp>]
rcvd [LCP ConfReq id=0xf <asyncmap 0x0> <auth chap MD5> <magic 0xf20617> <pcomp> <accomp>]
sent [LCP ConfAck id=0xf <asyncmap 0x0> <auth chap MD5> <magic 0xf20617> <pcomp> <accomp>]
rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0xab788346> <pcomp> <accomp>]
rcvd [LCP DiscReq id=0x10 magic=0xf20617]
rcvd [CHAP Challenge id=0x1 <20493e8d501c33f470458847c0e08643>, name = "UMTS_CHAP_SRVR"]
sent [CHAP Response id=0x1 <58048efdb293eb9165c4a69603028995>, name = "web"]
rcvd [CHAP Success id=0x1 ""]
CHAP authentication succeeded
sent [CCP ConfReq id=0x1 <deflate 15> <deflate(old#) 15>]
sent [iPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
rcvd [LCP ProtRej id=0x11 80 fd 01 01 00 0c 1a 04 78 00 18 04 78 00]
Protocol-Reject for 'Compression Control Protocol' (0x80fd) received
rcvd [iPCP ConfNak id=0x1 <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14> <ms-wins 10.11.12.13> <ms-wins 10.11.12.14>]
sent [iPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 10.11.12.13> <ms-dns3 10.11.12.14>]
Modem hangup
Connection terminated.
