Cezar3W Napisano Listopad 25, 2009 Zgłoszenie Share Napisano Listopad 25, 2009 Chodzi o Ethernet controller: Intel Corporation 82573L Gigabit Ethernet Controller Ściągam sterowniki pod Linux stąd. Następnie stosuje sie do instrukcji w pliku README. Building and Installation ========================= To build a binary RPM* package of this driver, run 'rpmbuild -tb <filename.tar.gz>'. Replace <filename.tar.gz> with the specific filename of the driver. NOTE: For the build to work properly, the currently running kernel MUST match the version and configuration of the installed kernel sources. If you have just recompiled the kernel reboot the system now. RPM functionality has only been tested in Red Hat distributions. 1. Move the base driver tar file to the directory of your choice. For example, use /home/username/e1000e or /usr/local/src/e1000e. 2. Untar/unzip archive: tar zxf e1000e-x.x.x.tar.gz 3. Change to the driver src directory: cd e1000e-x.x.x/src/ 4. Compile the driver module: # make install The binary will be installed as: /lib/modules/<KERNEL VERSION>/kernel/drivers/net/e1000e/e1000e.[k]o The install locations listed above are the default locations. They might not be correct for certain Linux distributions. Po wpisaniu make install dostaje odpowiedź: Makefile:70: *** Linux kernel source not found in any of these locations: Makefile:71: Makefile:72: *** Install the appropriate kernel development package, e.g. Makefile:73: *** kernel-devel, for building kernel modules and try again. Stop. Jestem laikiem, dopiero zaczynam z linuxem :lammer: Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
qmic Napisano Listopad 25, 2009 Zgłoszenie Share Napisano Listopad 25, 2009 Jest napisane co trzeba zrobić - zainstaluj kernel-devel yum install kernel-devel Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
