Gdesklets Fc3
Andrzej Orkan
Na próbę zainstalowania GDESKLETS czyli apt-get install gdesklets dostaję komunikat taki:
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that the package is simply not installable and a bug report against that package should be filed. The following information may help to resolve the situation:
The following packages have unmet dependencies:
gdesklets: Depends: libcrlayeng.so.1
Depends: libcroco.so.1
Depends: libcrseleng.so.2
Depends: libgtop-2.0.so.2
E: Broken packages
Wiem o czym on do mnie mówi, ale co ja mam z tym zrobić? :o Będę wdzięczny za pomysły. Pozdrówka dla wszystkich.
Orkan
