DyM32 Napisano Listopad 17, 2004 Zgłoszenie Share Napisano Listopad 17, 2004 witam mam fedora core2 no i dziś zrobiłem apt-get update potem upgrade no i po tych zabiegach znikł mi mplayer to znaczy jest ale gdy go włanczam to otrzymuję taki komunikat [marineo@host-81-190-146-147 marineo]$ mplayer MPlayer 1.0pre5-3.3.3 © 2000-2004 MPlayer Team CPU: Advanced Micro Devices Athlon MP/XP/XP-M Barton 1914 MHz (Family: 6, Stepping: 0) Detected cache-line size is 64 bytes CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0 Reading config file /etc/mplayer/mplayer.conf Reading config file /home/marineo/.mplayer/config Reading /home/marineo/.mplayer/codecs.conf: Can't open '/home/marineo/.mplayer/codecs.conf': Nie ma takiego pliku ani katalogu Reading /etc/mplayer/codecs.conf: Can't open '/etc/mplayer/codecs.conf': Nie matakiego pliku ani katalogu Using built-in default codecs.conf. Usage: mplayer [options] [url|path/]filename Basic options: (complete list in the man page) -vo <drv[:dev]> select video output driver & device ('-vo help' for a list) -ao <drv[:dev]> select audio output driver & device ('-ao help' for a list) vcd://<trackno> play (S)VCD (Super Video CD) track (raw device, no mount) dvd://<titleno> play DVD title from device instead of plain file -alang/-slang select DVD audio/subtitle language (by 2-char country code) -ss <timepos> seek to given (seconds or hh:mm:ss) position -nosound do not play sound -fs fullscreen playback (or -vm, -zoom, details in the man page) -x <x> -y <y> set display resolution (for use with -vm or -zoom) -sub <file> specify subtitle file to use (also see -subfps, -subdelay) -playlist <file> specify playlist file -vid x -aid y select video (x) and audio (y) stream to play -fps x -srate y change video (x fps) and audio (y Hz) rate -pp <quality> enable postprocessing filter (details in the man page) -framedrop enable frame dropping (for slow machines) Basic keys: (complete list in the man page, also check input.conf) <- or -> seek backward/forward 10 seconds up or down seek backward/forward 1 minute pgup or pgdown seek backward/forward 10 minutes < or > step backward/forward in playlist p or SPACE pause movie (press any key to continue) q or ESC stop playing and quit program + or - adjust audio delay by +/- 0.1 second o cycle OSD mode: none / seekbar / seekbar + timer * or / increase or decrease PCM volume z or x adjust subtitle delay by +/- 0.1 second r or t adjust subtitle position up/down, also see -vf expand * * * SEE THE MAN PAGE FOR DETAILS, FURTHER (ADVANCED) OPTIONS AND KEYS * * * i jako że jestem asem z angielskiego to ni w ząb nie wiem od czego zacząć i gdzie jest problem proszę o sugestie z góry dziękuję Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
roback Napisano Listopad 17, 2004 Zgłoszenie Share Napisano Listopad 17, 2004 Hmm, rozumiem, że efekt Cię nie zadowala, ale co chciałbyś osiągnąć? Dopisz jako parametr nazwę pliku, który chcesz odpalić i powinno działać, ew. dwumlasknij w plik z (np.) filmem po uprzednim ustawieniu mplayer'a jako domyślneo programu do otwierania tego typu plików. Jeśli chcesz odpalić GUI to AFAIR służy do tego polecenie gmplayer Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
