Sikuli
Kapat
Witam!
Czy udało się wam odpalić sikuli na fedorze?
link do projektu: Sikuli download page
błędy z debugera programu:
raceback (most recent call last):
  File "<string>", line 1, in <module>
  File "/home/Kapat/Pobrane/Sikuli-IDE/sikuli-script.jar/Lib/sikuli/Sikuli.py", line 18, in <module>
java.lang.UnsatisfiedLinkError: /home/Kapat/Pobrane/Sikuli-IDE/tmplib/libScreenMatchProxy.so: libcv.so.4: nie mo?na otworzy? pliku obiektu dzielonego: Nie ma takiego pliku ani katalogu
    at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1750)
    at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1646)
    at java.lang.Runtime.load0(Runtime.java:787)
    at java.lang.System.load(System.java:1022)
    at com.wapmx.nativeutils.jniloader.NativeLoader.loadLibrary(NativeLoader.java:44)
    at edu.mit.csail.uid.Finder.<clinit>(Finder.java:16)
    at java.lang.Class.forName0(Native Method)
    at java.lang.Class.forName(Class.java:186)
    at org.python.core.SyspathJavaLoader.loadClass(SyspathJavaLoader.java:107)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
    at org.python.core.Py.findClassEx(Py.java:817)
    at org.python.core.packagecache.SysPackageManager.findClass(SysPackageManager.java:133)
    at org.python.core.packagecache.PackageManager.findClass(PackageManager.java:28)
    at org.python.core.packagecache.SysPackageManager.findClass(SysPackageManager.java:122)
    at org.python.core.PyJavaPackage.__findattr_ex__(PyJavaPackage.java:137)
    at org.python.core.PyObject.__findattr__(PyObject.java:869)
    at org.python.core.imp.import_name(imp.java:771)
    at org.python.core.imp.importName(imp.java:806)
    at org.python.core.ImportFunction.__call__(__builtin__.java:1232)
    at org.python.core.PyObject.__call__(PyObject.java:367)
    at org.python.core.__builtin__.__import__(__builtin__.java:1202)
    at org.python.core.imp.importFromAs(imp.java:884)
    at org.python.core.imp.importFrom(imp.java:860)
    at sikuli.Sikuli$py.f$0(/home/Kapat/Pobrane/Sikuli-IDE/sikuli-script.jar/Lib/sikuli/Sikuli.py:165)
    at sikuli.Sikuli$py.call_function(/home/Kapat/Pobrane/Sikuli-IDE/sikuli-script.jar/Lib/sikuli/Sikuli.py)
    at org.python.core.PyTableCode.call(PyTableCode.java:165)
    at org.python.core.PyCode.call(PyCode.java:18)
    at org.python.core.imp.createFromCode(imp.java:326)
    at org.python.core.util.importer.importer_load_module(importer.java:109)
    at org.python.modules.zipimport.zipimporter.zipimporter_load_module(zipimporter.java:161)
    at org.python.modules.zipimport.zipimporter$zipimporter_load_module_exposer.__call__(Unknown Source)
    at org.python.core.PyBuiltinMethodNarrow.__call__(PyBuiltinMethodNarrow.java:47)
    at org.python.core.imp.loadFromLoader(imp.java:451)
    at org.python.core.imp.find_module(imp.java:408)
    at org.python.core.PyModule.impAttr(PyModule.java:109)
    at org.python.core.imp.import_next(imp.java:637)
    at org.python.core.imp.import_logic(imp.java:699)
    at org.python.core.imp.import_name(imp.java:761)
    at org.python.core.__builtin__.__import__(__builtin__.java:1185)
    at org.python.core.imp.importAll(imp.java:904)
    at org.python.pycode._pyx2.f$0(<string>:1)
    at org.python.pycode._pyx2.call_function(<string>)
    at org.python.core.Py.runCode(Py.java:1204)
    at org.python.core.Py.exec(Py.java:1248)
    at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:172)
    at edu.mit.csail.uid.ScriptRunner.runPython(ScriptRunner.java:52)
    at edu.mit.csail.uid.SikuliIDE$ButtonRun.runPython(SikuliIDE.java:1238)
    at edu.mit.csail.uid.SikuliIDE$ButtonRun$1.run(SikuliIDE.java:1336)
java.lang.UnsatisfiedLinkError: java.lang.UnsatisfiedLinkError: /home/Kapat/Pobrane/Sikuli-IDE/tmplib/libScreenMatchProxy.so: libcv.so.4: nie mo?na otworzy? pliku obiektu dzielonego: Nie ma takiego pliku ani katalogu
Potrzebne są do uruchomienia biblioteki opencv Lib:
[root@ex ~]# ls /usr/lib64/libcv*
/usr/lib64/libcvaux.so.2.0  /usr/lib64/libcvaux.so.2.0.0  /usr/lib64/libcv.so.2.0  /usr/lib64/libcv.so.2.0.0
Zainstaluj sobie jeszcze dodatkowo 32 bitową wersję opencv - prawdopodobnie Sikuli korzysta właśnie z niej ewentualnie z obu. Program wywala błąd o braku właśnie opencv. Nie mam fedory nie mam jak sprawdzić, ale pewnie będzie to coś w stylu:
sudo yum install opencv.i686
ewentualnie pierwsza cyfra po i będzie inna. Poszukaj w repozytoriach i powiedz czy pomogło - czy coś się zmieniło.
