Alerty
jubix
Co oznaczają te alety?
w83627dhg-isa-0290
Adapter: ISA adapter
Vcore:       +1.35 V  (min =  +0.00 V, max =  +1.74 V)
in1:         +1.60 V  (min =  +0.49 V, max =  +0.64 V)   ALARM
AVCC:        +3.30 V  (min =  +2.98 V, max =  +3.63 V)
in4:         +1.83 V  (min =  +0.17 V, max =  +1.66 V)   ALARM
in5:         +0.10 V  (min =  +1.96 V, max =  +1.57 V)   ALARM
in6:         +0.10 V  (min =  +0.54 V, max =  +0.83 V)   ALARM
3VSB:        +3.30 V  (min =  +2.98 V, max =  +3.63 V)
Vbat:        +3.20 V  (min =  +2.70 V, max =  +3.30 V)
fan1:          0 RPM  (min = 5273 RPM, div = 32)  ALARM
fan2:       3924 RPM  (min = 1048 RPM, div = 8)
fan3:          0 RPM  (min = 3515 RPM, div = 32)  ALARM
fan4:          0 RPM  (min = 1834 RPM, div = 32)  ALARM
fan5:          0 RPM  (min = 5273 RPM, div = 32)  ALARM
temp1:       +45.0°C  (high = +57.0°C, hyst = +96.0°C)  sensor = thermistor
temp2:       +45.0°C  (high = -111.5°C, hyst = -112.0°C)  ALARM  sensor = diode
temp3:       +47.0°C  (high = +70.0°C, hyst = +65.0°C)  sensor = thermistor
Totalnie nic wielkiego w tym przypadku:)
U mnie jest podobnie, po prostu jak przekracza wartości min i max to pokazuje alert, a same wartości min i max są źle zczytywane.
Temperatury są ok, wentylator może mieć taka szybkość, reszta nie ma bo ich nie ma (pewnie nawet nie ma 5 czujników), napięcie 3.3V jest ok (m.in. na PCI), 1.6V to pewnie wejście na procesor, 1.35 to napięcie rdzenia CPU a 1.8 to moze być napięcie na wyjściu VGA, VBat to napięcie baterii.
Masz przykładowo jak wygląda to u mnie i jest ok.
w83627hf-isa-0290
VCore 1:     +1.65 V  (min =  +0.00 V, max =  +4.08 V)
VCore 2:     +1.66 V  (min =  +0.00 V, max =  +4.08 V)
+3.3V:       +2.62 V  (min =  +2.82 V, max =  +3.79 V)   ALARM
+5V:         +5.11 V  (min =  +0.86 V, max =  +1.34 V)   ALARM
+12V:       +11.92 V  (min = +10.76 V, max =  +0.06 V)   ALARM
-12V:        -7.01 V  (min = -14.91 V, max = -14.91 V)   ALARM
-5V:         -5.15 V  (min =  -2.64 V, max =  -7.51 V)   ALARM
V5SB:        +5.59 V  (min =  +0.00 V, max =  +0.00 V)   ALARM
VBat:        +3.09 V  (min =  +1.41 V, max =  +3.86 V)
fan1:          0 RPM  (min = 28125 RPM, div = 8)  ALARM
fan2:          0 RPM  (min =   -1 RPM, div = 8)  ALARM
fan3:       2860 RPM  (min = 1318 RPM, div = 8)
temp1:       +37.0°C  (high = +18.0°C, hyst = +100.0°C)  sensor = thermistor
temp2:       +50.5°C  (high = +70.0°C, hyst = +65.0°C)  sensor = thermistor
temp3:       +35.5°C  (high = +70.0°C, hyst = +65.0°C)  sensor = thermistor
cpu0_vid:   +0.000 V
