Instalacja Kamery Easy Touch Et-462
necrordian
Musisz w pliku /home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c zmienić includa z #include <asm/semaphore.h> na #include <linux/semaphore.h> bo to pierwsze zostało usunięte z kernela.
Es.
[root@necrordian-desktop gspcav1-20071224]# ./gspca_build
REMOVE the old module if present
ERROR: Module gspca does not exist in /proc/modules
CLEAN gspca source tree
rm -r -f *.o decoder/.gspcadecoder.o.cmd decoder/*.o \
.gspca.o.cmd  *.o *.ko *.mod.* .[a-z]* core *.i \
*.symvers *.err
COMPILE gspca Please Wait ....!!
INSTALL gspca in the kernel binary tree
mkdir -p /lib/modules/`uname -r`/kernel/drivers/usb/media/
rm -f /lib/modules/`uname -r`/kernel/drivers/usb/media/spca5xx.ko
rm -f /lib/modules/`uname -r`/kernel/drivers/media/video/gspca.ko
install -c -m 0644 gspca.ko /lib/modules/`uname -r`/kernel/drivers/usb/media/
install: nie można wykonać stat na `gspca.ko': Nie ma takiego pliku ani katalogu
make: *** [install] Błąd 1
LOAD gspca in memory
FATAL: Module gspca not found.
PRINT COMPILATION MESSAGES if ERRORS look kgspca.err
make -C /lib/modules/`uname -r`/build SUBDIRS=/home/necrordian/Pobrane/gspcav1-20071224 CC=cc modules
make[1]: Wejście do katalogu `/usr/src/kernels/2.6.35.10-74.fc14.i686'
 CC [M]  /home/necrordian/Pobrane/gspcav1-20071224/gspca_core.o
In file included from /home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:845:0:
/home/necrordian/Pobrane/gspcav1-20071224/utils/spcausb.h: In function ‘spca5xxRegRead’:
/home/necrordian/Pobrane/gspcav1-20071224/utils/spcausb.h:95:2: error: implicit declaration of function ‘info’
/home/necrordian/Pobrane/gspcav1-20071224/utils/spcausb.h: In function ‘spca_set_interface’:
/home/necrordian/Pobrane/gspcav1-20071224/utils/spcausb.h:278:2: error: implicit declaration of function ‘warn’
In file included from /home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:853:0:
/home/necrordian/Pobrane/gspcav1-20071224/Sunplus-jpeg/sp5xxfw2.h: In function ‘sp5xxfw2_init’:
/home/necrordian/Pobrane/gspcav1-20071224/Sunplus-jpeg/sp5xxfw2.h:122:2: error: called object ‘info’ is not a function
/home/necrordian/Pobrane/gspcav1-20071224/Sunplus-jpeg/sp5xxfw2.h:136:6: error: called object ‘info’ is not a function
/home/necrordian/Pobrane/gspcav1-20071224/Sunplus-jpeg/sp5xxfw2.h:141:2: error: called object ‘info’ is not a function
/home/necrordian/Pobrane/gspcav1-20071224/Sunplus-jpeg/sp5xxfw2.h:148:6: error: called object ‘info’ is not a function
/home/necrordian/Pobrane/gspcav1-20071224/Sunplus-jpeg/sp5xxfw2.h:176:6: error: called object ‘info’ is not a function
/home/necrordian/Pobrane/gspcav1-20071224/Sunplus-jpeg/sp5xxfw2.h: In function ‘sp5xxfw2_start’:
/home/necrordian/Pobrane/gspcav1-20071224/Sunplus-jpeg/sp5xxfw2.h:214:6: error: called object ‘info’ is not a function
/home/necrordian/Pobrane/gspcav1-20071224/Sunplus-jpeg/sp5xxfw2.h:230:6: error: called object ‘info’ is not a function
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c: In function ‘gspca_kill_transfert’:
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:986:4: error: implicit declaration of function ‘usb_buffer_free’
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c: In function ‘gspca_init_transfert’:
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:1030:4: error: implicit declaration of function ‘usb_buffer_alloc’
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:1030:26: warning: assignment makes pointer from integer without a cast
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c: In function ‘spca5xx_ioctl’:
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:2463:2: error: implicit declaration of function ‘video_usercopy’
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c: At top level:
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:2609:2: error: unknown field ‘owner’ specified in initializer
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:2609:2: warning: initialization from incompatible pointer type
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:2611:2: error: unknown field ‘type’ specified in initializer
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:2615:2: warning: initialization from incompatible pointer type
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c: In function ‘spca50x_create_sysfs’:
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:2769:2: error: implicit declaration of function ‘video_device_create_file’
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:2780:2: error: implicit declaration of function ‘video_device_remove_file’
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c: In function ‘spca5xx_probe’:
/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.c:4301:21: error: incompatible types when assigning to type ‘struct device’ from type ‘struct device *’
make[2]: *** [/home/necrordian/Pobrane/gspcav1-20071224/gspca_core.o] Błąd 1
make[1]: *** [_module_/home/necrordian/Pobrane/gspcav1-20071224] Błąd 2
make[1]: Opuszczenie katalogu `/usr/src/kernels/2.6.35.10-74.fc14.i686'
make: *** [default] Błąd 2
