Acr122U210 Pc/Sc Lite Daemon - No Device Found
virus1010
Czesc mam problem z czytnikiem kart mifare Acr122u210 pod linuxem
Moje parametry to: Fedora 17, zainstalowane wszystkie niezbedne paczki (rpm) pcsc-lite-ccid-1.4.6-1, Libnfc 1.4.2-2, libnf devel 1.4.2-2, libnfc examples 1.4.2-2, libudev 182-3, libudev devel 182-3, libusb 1.0.9-0.6, libusb devel 1.0.9, pcsc ccid libs 1.8.3-1, pcsc lite devel, pcsc lite 1.8.3-1, pcsc lite acsccid, pcsc tools 1.4.17-3, i oryginalne sterowniki ccid do kartyze strony acs.com.hk acsccid 1.0.2-1
Zaastanawiam się czy nie jest to wina tego ze mam zainstalowane 3 rozne paczki sterownikow ccid czyli: acsccid 1.0.2-1, pcsc lite acsccid, pcsc-lite-ccid-1.4.6-1, probowalem na samych producenta nie wykrywalo (_wogole_ → w ogóle) ORT czytnika a w tym moencie wyglada to tak:
Po wpisaniu w terminalu pcscd_scan:
PC/SC device scanner
V 1.4.17 © 2001-2009, Ludovic Rousseau <[email protected]>
Compiled with PC/SC lite version: 1.7.4
Scanning present readers...
0: ACS ACR122U 00 00
Sun Aug 26 20:24:42 2012
Reader 0: ACS ACR122U 00 00
Card state: Card inserted,
ATR: 3B 8F 80 01 80 4F 0C A0 00 00 03 06 03 00 01 00 00 00 00 6A
+ TS = 3B --> Direct Convention
+ T0 = 8F, Y(1): 1000, K: 15 (historical bytes)
TD(1) = 80 --> Y(i+1) = 1000, Protocol T = 0
TD(2) = 01 --> Y(i+1) = 0000, Protocol T = 1
+ Historical bytes: 80 4F 0C A0 00 00 03 06 03 00 01 00 00 00 00
Category indicator byte: 80 (compact TLV data object)
Tag: 4, len: F (initial access data)
Initial access data: 0C A0 00 00 03 06 03 00 01 00 00 00 00
+ TCK = 6A (correct checksum)
Possibly identified card (using /usr/share/pcsc/smartcard_list.txt):
3B 8F 80 01 80 4F 0C A0 00 00 03 06 .. 00 01 00 00 00 00 ..
Mifare Standard 1K (as per PCSC std part3)
3B 8F 80 01 80 4F 0C A0 00 00 03 06 03 .. .. 00 00 00 00 ..
RFID - ISO 14443 Type A Part 3 (as per PCSC std part3)
Philips MIFARE Standard (1 Kbytes EEPROM)
http://www.nxp.com/products/identificat … e/classic/
RFID - ISO 14443 Type A - Transport for London Oyster
ACOS5/1k Mirfare
RFID - ISO 14443 Type A - NXP Mifare card with 1k EEPROM
Sun Aug 26 20:24:45 2012
Card state: Card removed,
Po wpisaniu w terminalu nfc-list:
[root@error ~]# nfc-list
nfc-list use libnfc 1.4.2 (r891)
Connected to NFC device: ACS ACR122U 00 00 / ACR122U210 - PN532 v1.6 (0x07)
1 ISO14443A passive target(s) was found:
ATQA (SENS_RES): 00 04
UID (NFCID1): 8e 46 02 c4
SAK (SEL_RES): 08
Gdy wpisuje pcscd nic sie nie dzieje chwile mysli i przerzuca mnie do nowej lini (tak jakby daemon nie dzialal jak trzeba) wyglada to tak:
[root@error ~]# pcscd
[root@error ~]#
Gdy wpisuje w terminalu : lsnfc
[root@error ~]# lsnfc
ERROR: No device found.
W czym może być problem ?
Gość
