Samba 4 I Win7 (Fedora 19)
m__s
Pierwszy raz mam taki cyrk, że nie mogę udostępnić plików z samby na windows... robiłem to już tyle razy, ale teraz jestem w kropce.
Mam udostępniony dysk /media/temp (ntfs), do tego 3 dyski zaszyfrowane truecrypt-em. Konfiguracja wygląda tak:
[root@syncerror] $ ls -l /media
total 28
drwxrwxrwx. 1 root root  8192 Nov 16 18:53 temp
drwx------. 1 m__s m__s  4096 Nov  1 09:36 truecrypt1
drwx------. 1 m__s m__s 12288 Nov 13 14:53 truecrypt2
drwx------. 1 m__s m__s  4096 Nov 16 20:31 truecrypt3
Teraz kolejno SAMBA:
egrep -v "#|;" /etc/samba/smb.conf
[global]
	workgroup = LAN
	server string = Samba Server Version %v
	netbios name = syncerror
	log file = /var/log/samba/log.%m
	max log size = 50
	security = user
	passdb backend = tdbsam
  wins support = yes
  name resolve order = wins lmhosts hosts bcast
load printers = no
cups options = raw
 [homes]
	comment = Home Directories
	browseable = yes
	writable = yes
	valid users = %S
	valid users = MYDOMAIN\%S
[sdb]
  comment = truecrypt 1
  path = /media/truecrypt1
  valid users = @users
  force group = ms_2911
  create mask = 0660
  directory mask = 0771
  writable = yes
[sdc]
  comment = truecrypt 2
  path = /media/truecrypt2
  create mask = 0660
  writable = yes
[tv_hd]
  comment = tv_hd
  path = /media/truecrypt3/tv_hd
  valid users = m__s
  force group = m__s
  create mask = 0660
  writable = yes
  guest ok = yes
[sde]
  comment = downloads
  path = /media/temp
  force group = users
  create mask = 0660
  writable = yes
  guest ok = yes
[test]
  comment = downloads
  path = /media/temp/test
  valid users = ms_2911
  force group = m__s
  guest ok = yes
netstat:
[root@syncerror] $ netstat -tulpn | egrep "samba|smbd|nmbd|winbind"
tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      30690/smbd
tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      30690/smbd
tcp6       0      0 :::139                  :::*                    LISTEN      30690/smbd
tcp6       0      0 :::445                  :::*                    LISTEN      30690/smbd
smbclient:
[root@syncerror] $ smbclient -L 192.168.0.15 -U m__s
Enter m__s's password:
Domain=[LAN] OS=[Unix] Server=[Samba 4.0.9]
        Sharename       Type      Comment
        homes           Disk      Home Directories
        sdb             Disk      truecrypt 1
        sdc             Disk      truecrypt 2
        tv_hd           Disk      tv_hd
        sde             Disk      downloads
        test            Disk      downloads
        IPC$            IPC       IPC Service (Samba Server Version 4.0.9)
        m__s            Disk      Home Directories
        Server               Comment
        Workgroup            Master
Z Windowsa mogę wejść na moje ip 192.168.0.15 i widzę wszystkie udziały, ale za cholerę nie mogę na nie wejść. Najlepsze, że w logach nic nie ma...
Czy ktoś ma jakiś pomysł? Z góry dziękuję! :wacko:
workgroup takie same masz na windowsie?
ja mam tak:
[global]
workgroup = Grupa_robocza
server string = Komputer z Linuxem
netbios name = samba
#guest account = nobody
#security = share
max log size = 50
security = user
[data]
        path=/data
        writable = yes
        guest ok = yes
        guest only = yes
        create mode = 0777
        directory mode = 0777
        share modes = yes
i działa. Jedyną rzucającą się w oczy różnicą jest właśnie grupa roboczna i
wins support = yes
nie wiem czy potrzebne jest korzystanie z winsów, w domenie rozumiem, ale ta konfiguracja samby nie jest konfiguracją domenową.
Grupę roboczą mam inną niż na komputerze z Windows 7. Wszystko dlatego, że komputer w domu to komputer domowy, który ma udostępniać pliki w sumie, a laptop to sprzęt służbowy, który jest wpięty do domeny w pracy. Jednak nazwa grupy/domeny nie powinna mieć przecież znaczenia bo co za różnica czy wpiszę .\user czy domen\user?
Opcję z wins i name resolve (co wydaje mi się też niepotrzebne) znalazłem gdzieś podaną w odpowiedziach w internecie, gdy ktoś pisał, że samba mu nie działa.
Najbardziej dziwi mnie to, że w logach nie ma dosłownie nic! Ani, że nieznany użytkownik czy błąd hasła, czy też cokolwiek innego. Nawet jak wpisałem log level = 3 to też nic więcej się nie pojawiło!
Dobra udało mi się wreszcie uruchomić log leve = 3. To co dostaję w outpucie...
[2013/11/17 23:33:05.831570,  3] ../source3/locking/share_mode_lock.c:406(fetch_share_mode_unlocked)
  Could not fetch share entry
[2013/11/17 23:33:05.837605,  3] ../source3/rpc_server/srv_pipe.c:691(api_pipe_bind_req)
  api_pipe_bind_req: srvsvc -> srvsvc rpc service
[2013/11/17 23:33:05.837679,  3] ../source3/rpc_server/srv_pipe.c:340(check_bind_req)
  check_bind_req for \srvsvc
[2013/11/17 23:33:05.837749,  3] ../source3/rpc_server/srv_pipe.c:347(check_bind_req)
  check_bind_req: srvsvc -> srvsvc rpc service
[2013/11/17 23:33:05.839991,  3] ../source3/rpc_server/srv_pipe_hnd.c:122(free_pipe_context)
  free_pipe_context: destroying talloc pool of size 28
[2013/11/17 23:33:05.843126,  3] ../source3/rpc_server/srv_pipe.c:1369(api_rpcTNP)
  api_rpcTNP: rpc command: SRVSVC_NETSHAREENUMALL
[2013/11/17 23:33:05.843357,  3] ../source3/rpc_server/srv_pipe_hnd.c:122(free_pipe_context)
  free_pipe_context: destroying talloc pool of size 357
[2013/11/17 23:33:06.999628,  3] ../source3/smbd/vfs.c:1140(check_reduced_name)
  check_reduced_name [.] [/test]
[2013/11/17 23:33:06.999842,  3] ../source3/smbd/vfs.c:1270(check_reduced_name)
  check_reduced_name: . reduced to /test
[2013/11/17 23:33:07.005337,  3] ../source3/smbd/vfs.c:1140(check_reduced_name)
[2013/11/17 23:33:07.005585,  3] ../source3/smbd/vfs.c:1270(check_reduced_name)
[2013/11/17 23:33:07.009885,  3] ../source3/smbd/vfs.c:1140(check_reduced_name)
[2013/11/17 23:33:07.010030,  3] ../source3/smbd/vfs.c:1270(check_reduced_name)
[2013/11/17 23:33:07.010164,  3] ../source3/smbd/dosmode.c:160(unix_mode)
  unix_mode(.) returning 0760
[2013/11/17 23:33:07.793280,  3] ../source3/smbd/vfs.c:1140(check_reduced_name)
[2013/11/17 23:33:07.793422,  3] ../source3/smbd/vfs.c:1270(check_reduced_name)
Pod Win7 nie ma różnicy czy wpiszesz domenta\user czy też .\user gdzie kropka traktowana jest jako lokalna domenena. Ale sprawdziłem sobie w domencie pod WinXp i nie działa.
Co do grupy roboczej. Mam w pracy komputer łączące dwie niezależne domeny i z jednej strony jest widoczny (tej której domenę mam wpisaną) z drugiej nie.
A czy masz dostęp do innych zaosbów poza tymi dyskami ?
A próbowałeś "nazwa srv. z sambą\user" zamiast ".\user"? Bo jeśli kropka nie będzie działać, to to pierwsze już musi.
Tak mam dostęp. Zrobiłem sobie katalog /home/m__s/test, któremu dałem chmod 777 lub nawet zrobiłem katalog /test i też nic...
Powoli kończą mi się pomysły.
skonfigurowałem sobie sambę wg tego :
http://www.howtoforge.com/fedora-19-samba-standalone-server-with-tdbsam-backend
po kolei.
Wyłączenie selinuxa - restart
vi /etc/samba/smb.conf
[global]
workgroup = MOJADOMENAPRACOWA
server string = Samba serwer Version %v
netbios name = TEST
max log size = 50
security = user
load printers = yes
cups options = raw
[homes]
browseable = no
writable = yes
[test]
comment = test zasob
path = /test
public = yes
writable = yes
zasób test :
chmod -R 777 /test
chown -R root:users /test
useradd jas -m -G users
passwd jas
smbpasswd -a jas
i jeszcze na firewallu trzeba wypuścić samba i samba-cliente - konfiguracja przy uruchomieniu + konfiguracja trwała.
Wszystko chodzi.
Pomogło wyłączenie SELinux. Pytanie czym i dlaczego on blokuje dostęp do Samby i jak ewentualnie to obejść bez wyłączania SELinux'a?
Co to za mongolskie zasady blokują dostęp do usług :-(
Rozumiem, że iptables/firewall to jedno a selinux to drugie.
