F20 Widzi Połowe Ram
littlefox
Witam,
Ostatnio zainstalowałem Fedore 20 wraz z XFCE. Wszystko było by okej gdybym przypadkiem nie zauważył że system widzi ok. połowe dostępnej pamięci. W laptopie (acer travelmate 5740) zainstalowane mam 2 kości: 4GB + 1 GB, na Windows8 oraz Gentoo z najnowszym jądrem widział cały ram. Poniżej co zwraca konsola:
[root@localhost /]# more /proc/version
Linux version 3.12.8-300.fc20.i686 (mockbuild@bkernel02) (gcc version 4.8.2 2013
1212 (Red Hat 4.8.2-7) (GCC) ) #1 SMP Thu Jan 16 01:28:49 UTC 2014
[root@localhost /]# free
             total       used       free     shared    buffers     cached
Mem:       2380588    1332904    1047684     129812     157736     597980
-/+ buffers/cache:     577188    1803400
Swap:            0          0          0
[root@localhost /]# more /proc/meminfo
MemTotal:        2380588 kB
MemFree:         1047504 kB
Buffers:          157736 kB
Cached:           598108 kB
SwapCached:            0 kB
Active:           706244 kB
Inactive:         549056 kB
Active(anon):     500216 kB
Inactive(anon):   129208 kB
[root@localhost /]# dmidecode -t memory
# dmidecode 2.12
SMBIOS 2.6 present.
Handle 0x001A, DMI type 16, 15 bytes
Physical Memory Array
	Use: System Memory
	Error Correction Type: None
	Maximum Capacity: 16 GB
	Error Information Handle: No Error
	Number Of Devices: 2
Handle 0x001B, DMI type 17, 28 bytes
Memory Device
	Array Handle: 0x001A
	Error Information Handle: 0x001D
	Total Width: 64 bits
	Data Width: 64 bits
	Form Factor: SODIMM
	Set: None
	Locator: DIMM0
	Bank Locator: BANK 0
	Type: DDR3
	Type Detail: Synchronous
	Speed: 1067 MHz
	Manufacturer: Not Specified
	Serial Number: 7931AF34
	Asset Tag: Unknown
	Part Number: ACR128X64D3S1333C9
	Rank: Unknown
Handle 0x001C, DMI type 6, 12 bytes
Memory Module Information
	Socket Designation: DIMM0
	Bank Connections: None
	Current Speed: Unknown
	Type: DIMM
	Installed Size: 1024 MB (Single-bank Connection)
	Enabled Size: 1024 MB (Single-bank Connection)
	Error Status: OK
Handle 0x001F, DMI type 17, 28 bytes
Memory Device
	Error Information Handle: 0x0021
	Data Width: 64 bits
	Form Factor: SODIMM
	Set: None
	Locator: DIMM1
	Bank Locator: BANK 2
	Type: DDR3
	Speed: 1067 MHz
	Serial Number: 01166DB9
	Asset Tag: Unknown
	Part Number: Not Specified
	Rank: Unknown
Handle 0x0020, DMI type 6, 12 bytes
	Socket Designation: DIMM1
	Type: DIMM
	Installed Size: 4096 MB (Single-bank Connection)
	Enabled Size: 4096 MB (Single-bank Connection)
	Error Status: OK
Handle 0x0025, DMI type 5, 20 bytes
Memory Controller Information
	Error Detecting Method: None
	Error Correcting Capabilities:
		Unknown
		None
	Supported Interleave: One-way Interleave
	Current Interleave: One-way Interleave
	Maximum Memory Module Size: 8192 MB
	Maximum Total Memory Size: 16384 MB
	Supported Speeds:
		Other
	Supported Memory Types:
		Other
	Memory Module Voltage: Unknown
	Associated Memory Slots: 2
		0x001C
		0x0020
	Enabled Error Correcting Capabilities:
		None
System aktualny, nic nie grzebany. Partycje swap usunąłem podczas instalacji ponieważ przy dostępnej pamięci i małej pojemności dysku go nie potrzebuje.
W czym może być problem (sprawdzałem config jądra i wygląda ok)?
Okej, ale czy system nie powinien widzieć właśnie tych 4 GB zamiast 2,3GB (MemTotal: 2380588 kB)?
Nie - w systemach x86 zobaczysz właśnie takie ilości pamięci i wynika to z ich adresowania. Dlatego z ilością powyżej 3GB RAM musisz albo zainstalować system 64 bitowy lub jądro PAE (rozszerza adresowanie). Tyczy się do każdego systemu, czy to Linux, Windows, OS X, Solaris itd. Tak to po prostu działa :)
