tele Napisano Czerwiec 19, 2014 Zgłoszenie Share Napisano Czerwiec 19, 2014 Podczas kompilacji mi wyskoczyło coś takiego extracting debug info from /home/gg/rpmbuild/BUILDROOT/kadu-1.0-rc2.x86_64/usr/bin/kadu/usr/lib/rpm/sepdebugcrcfix: Updated 50 CRC32s, 0 CRC32s did match.21228 blocks+ '[' '%{buildarch}' = noarch ']'+ QA_CHECK_RPATHS=1+ case "${QA_CHECK_RPATHS:-}" in+ /usr/lib/rpm/check-rpaths********************************************************************************* WARNING: 'check-rpaths' detected a broken RPATH and will cause 'rpmbuild'* to fail. To ignore these errors, you can set the '$QA_RPATHS'* environment variable which is a bitmask allowing the values* below. The current value of QA_RPATHS is 0x0000.** 0x0001 ... standard RPATHs (e.g. /usr/lib); such RPATHs are a minor* issue but are introducing redundant searchpaths without* providing a benefit. They can also cause errors in multilib* environments.* 0x0002 ... invalid RPATHs; these are RPATHs which are neither absolute* nor relative filenames and can therefore be a SECURITY risk* 0x0004 ... insecure RPATHs; these are relative RPATHs which are a* SECURITY risk* 0x0008 ... the special '$ORIGIN' RPATHs are appearing after other* RPATHs; this is just a minor issue but usually unwanted* 0x0010 ... the RPATH is empty; there is no reason for such RPATHs* and they cause unneeded work while loading libraries* 0x0020 ... an RPATH references '..' of an absolute path; this will break* the functionality when the path before '..' is a symlink* ** Examples:* - to ignore standard and empty RPATHs, execute 'rpmbuild' like* $ QA_RPATHS=$[ 0x0001|0x0010 ] rpmbuild my-package.src.rpm* - to check existing files, set $RPM_BUILD_ROOT and execute check-rpaths like* $ RPM_BUILD_ROOT=<top-dir> /usr/lib/rpm/check-rpaths* *******************************************************************************ERROR 0001: file '/usr/bin/kadu' contains a standard rpath '/usr/lib64' in [/usr/lib64]błąd: Błędny stan wyjścia z /var/tmp/rpm-tmp.NPAgT2 (%install) To znaczy ze nowe kadu ma architektórę " noarch " ? Chciałem się upewnić bo generalnie z " QA_RPATHS=$[ 0x0001|0x0010 ] rpmbuild my-package.src.rpm " sie kompiluje bez problemu. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Subaru Napisano Czerwiec 20, 2014 Zgłoszenie Share Napisano Czerwiec 20, 2014 Szczerze mówiąc nie kojarzę, by Kadu zmieniło się na noarch. Mam źródła w stanie po instalacji, mógłbym spróbować zbudować pakiety RPM, ale za nic w świecie nie wiem jak. Wiem tylko tyle, że RPMBuild jest w sprawie potrzebny. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
sokar620 Napisano Czerwiec 20, 2014 Zgłoszenie Share Napisano Czerwiec 20, 2014 Kadu nie ma architektury noarch. Poszukaj czy w Twoim specu nie ma Buildarch: noarch. Jeśli Ci wczystko działa to się nie przejmuj. Jak chcesz drążyć temat, to błędy z check-rpaths można rozwiązać dodając: chrpath --delete %{buildroot}%{_bindir}%{name} w sekcji %install. Możesz też poszukać odpowiednika opcji --disable-rpath dla kompilacji kadu (przyda się cmake-gui). Można też tak. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
tele Napisano Czerwiec 20, 2014 Autor Zgłoszenie Share Napisano Czerwiec 20, 2014 Dzięki! Subaru nie próbowałeś się nauczyć robić plik spec do zbudowania paczek rpm ? Chciałbyś spróbować ? Edytowane: Dobrze ze dziury jeszcze w dysku mi nie wypalilo.... - mianowicie metoda prob i bledow probowalem sie pozbyc bledu rpath , wczesniej robilem jakos QA_RPATHS=$[ 0x0001|0x0010 ] rpmbuild my-package.src.rpm ale teraz mi to jakos nie dziala - sama kompilacja przebiegla raczej prawidlowo i instaluje sie tez - problem jest tylko przy budowaniu paczki, w koncu na stronie ubuntu w opisie zmian znalazlem ze oni dodali u siebie opcje -DCMAKE_SKIP_RPATH=True do cmake, sprawdzilem i na Fedorze to dziala. %define name kadu %define version 1.3 Summary: A Gadu-Gadu and XMPP protocol instant messenger client Summary(de): Ein Gadu-Gadu- und XMPP-Protokoll Sofortnachrichtenklient Summary(pl): Nowoczesny komunikator obsługujący sieci Gadu-Gadu i XMPP Name: %{name} Version: %{version} #for pclos Release: mkrel 1 Release: 1 License: GPLv2+ #Group: Networking/Instant messaging Group: Applications/Internet URL: http://www.kadu.net Source0: %{name}-%{version}.tar.bz2 #BuildArch: x86_64 #Obsoletes: %{name}-dev < %version Provides: %{name} #BuildRoot: %{_tmppath}/%{name}-%{version}-buildroot BuildRequires: cmake >= 2.8.12.1 BuildRequires: desktop-file-utils >= 0.22 #for pclos BuildRequires: {_lib}alsa2-devel >= BuildRequires: alsa-lib-devel >= 1.0.27.2 #for pclos BuildRequires: {_lib}enchant-devel BuildRequires: enchant-devel >= 1.6.0 #for pclos BuildRequires: {_lib}gadu-devel BuildRequires: libgadu-devel >= 1.12.0 #for pclos BuildRequires: {_lib}gsm-devel BuildRequires: gsm-devel >= 1.0.13 #for pclos BuildRequires: {_lib}idn-devel BuildRequires: libidn-devel >= 1.28 #for pclos BuildRequires: {_lib}mpdclient-devel BuildRequires: libmpdclient-devel >= 2.7 #for pclos BuildRequires: {_lib}openssl-devel BuildRequires: openssl-devel #for pclos BuildRequires: {_lib}png-devel BuildRequires: libpng-devel >= 1.6.6 #for pclos BuildRequires: {_lib}pulseaudio-devel BuildRequires: pulseaudio-libs-devel #for pclos BuildRequires: {_lib}qt4-devel >= 4.8.0 BuildRequires: qt-devel >= 4.8.6 #for pclos BuildRequires: {_lib}qca2-devel BuildRequires: qca2-devel >= 2.0.3 #for pclos BuildRequires: {_lib}sndfile-devel BuildRequires: libsndfile-devel >= 1.0.25 #for pclos BuildRequires: {_lib}x11-devel BuildRequires: libX11-devel >= 1.6.1 #for pclos BuildRequires: {_lib}xext-devel BuildRequires: libXext-devel >= 1.3.2 #for pclos BuildRequires: {_lib}xfixes-devel BuildRequires: libXfixes-devel >= 5.0.1 #for pclos BuildRequires: {_lib}zlib-devel BuildRequires: zlib-devel >= 1.2.8 BuildRequires: phonon-devel >= 4.7.1 #for pclos BuildRequires: x11-proto-devel BuildRequires: xorg-x11-proto-devel >= 7.7 #for pclos BuildRequires: libindicate-qt-devel BuildRequires: aspell-devel >= 0.60.6.1 BuildRequires: qtwebkit-devel >= 2.3.3 BuildRequires: sqlite-devel >= 3.8.4.3 Requires: glibc >= 2.16 #for pclos Requires: libstdc++6 >= 4.7.2 Requires: libstdc++ >= 4.8.2 #for pclos Requires: %{_lib}xscrnsaver1 Requires: libXScrnSaver >= 1.2.2 Requires: qca2 >= 2.0.3 #for pclos Requires: qt4-database-plugin-sqlite #for pclos Requires: task-qt4 >= 4.8.0 Requires: qt5-qtbase >= 5.2.1 # lib archive need be installed but something not detect rpmbuild #BuildRequires: libarchive-devel <= 2.6.0 %description Kadu is a Polish instant messenger using the Gadu-Gadu and XMPP (since 0.6.6 version) protocol. Kadu is a free software, open-source software and does not contain advertisements (as opposed to the official Gadu-Gadu client, which is closed-source and adware). %description -l de.UTF-8 Kadu ist ein polnischer Sofortnachrichtenklient, der das Gadu-Gadu und XMPP (seit Version 0.6.6) Protokoll benutzt. Kadu ist freie Software, OpenSource Software und enthält keine Werbung (wie es beim offiziellen Gadu-Gadu-Klient der Fall ist). %description -l pl.UTF-8 Kadu to jeden z najpopularniejszych klientów sieci Gadu-Gadu dla systemu Linux. Od wersji 0.6.6 wspiera protokół XMPP. Jest to w pełni funkcjonalny komunikator obsługujący konferencje, animowane emotikony, powiadomienia dźwiękowe, przesyłanie plików oraz szyfrowanie rozmów przy użyciu OpenSSL, a dodatkowo nie wyświetla żadnych reklam. Został wykonany w oparciu o bibliotekę Qt4. #----------------------------------------------------------------------------------- #%package -n %{name}-devel #Summary: Development files for Kadu #Summary(de): Entwicklungsdateien für Kadu #Summary(pl): Pliki nagłówkowe dla Kadu #Group: Networking/Instant messaging #Requires: %name #%description -n %{name}-devel #Development files for Kadu #%description -n %{name}-devel -l de.UTF-8 #Entwicklungsdateien für Kadu #%description -n %{name}-devel -l pl.UTF-8 #Pliki nagłówkowe dla Kadu #------------------------------------------ %prep #-D - nie usuwaj katalogu przed rozpakowanie #-q - tryb cichy #-n - paczka z źródłem nazywa się ianczej niż rpm # setup -q -n kadu-%{ver} %setup -q -n kadu-%{version} %setup -q -T -D # patch1 -p1 # patch2 -p1 %build mkdir build cd build # -DCMAKE_SKIP_RPATH=True --> Don't check RPATH %{cmake} -DCMAKE_SKIP_RPATH=True -DCMAKE_USE_PTHREADS:BOOL=ON -DBUILD_DESCRIPTION="Fedora" .. make -k VERBOSE=1 %{?_smp_mflags} %install rm -rf $RPM_BUILD_ROOT cd build make install DESTDIR=$RPM_BUILD_ROOT %post %{update_menus} %{update_desktop_database} %update_icon_cache hicolor %postun %{clean_menus} %{clean_desktop_database} %clean_icon_cache hicolor %clean #[ "%{buildroot}" != "/" ] && rm -rf %{buildroot} rm -rf $RPM_BUILD_ROOT %files %defattr(-,root,root) ... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
