mskiba Napisano Sierpień 5, 2014 Autor Zgłoszenie Share Napisano Sierpień 5, 2014 Dzięki. Pomoglo dodanie bramy: GATEWAY=192.168.122.1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mskiba Napisano Sierpień 5, 2014 Autor Zgłoszenie Share Napisano Sierpień 5, 2014 Pojawil sie jeszcze jeden problem, ale z innej beczki Na jednym z gosci skonfigurowalem binda: /etc/named.conf // // named.conf // // Provided by Red Hat bind package to configure the ISC BIND named(8) DNS // server as a caching only nameserver (as a localhost DNS resolver only). // // See /usr/share/doc/bind*/sample/ for example named configuration files. // options { listen-on port 53 { 127.0.0.1; }; listen-on-v6 port 53 { ::1; }; directory "/var/named"; dump-file "/var/named/data/cache_dump.db"; statistics-file "/var/named/data/named_stats.txt"; memstatistics-file "/var/named/data/named_mem_stats.txt"; allow-query { localhost; }; /* - If you are building an AUTHORITATIVE DNS server, do NOT enable recursion. - If you are building a RECURSIVE (caching) DNS server, you need to enable recursion. - If your recursive DNS server has a public IP address, you MUST enable access control to limit queries to your legitimate users. Failing to do so will cause your server to become part of large scale DNS amplification attacks. Implementing BCP38 within your network would greatly reduce such attack surface */ recursion yes; dnssec-enable yes; dnssec-validation yes; dnssec-lookaside auto; /* Path to ISC DLV key */ bindkeys-file "/etc/named.iscdlv.key"; managed-keys-directory "/var/named/dynamic"; pid-file "/run/named/named.pid"; session-keyfile "/run/named/session.key"; }; logging { channel default_debug { file "data/named.run"; severity dynamic; }; }; zone "." IN { type hint; file "named.ca"; }; include "/etc/named.rfc1912.zones"; include "/etc/named.root.key"; zone "test.pl" { type master; file "/var/named/test.pl"; allow-query { any; }; notify yes; }; /var/named/test.pl $TTL 86400 $ORIGIN test.pl. @ IN SOA ns1.test.pl. root.test.pl. ( 2011022400 ;; Serial 2d ;; Refresh 15m ;; Update retry 2w ;; Expiry 1h ;; Minimum ) @ IN NS ns1.test.pl. ns1 IN A 192.168.122.10 @ IN A 192.168.122.10 bayer IN A 192.168.122.100 cat /etc/resolv.conf nameserver 127.0.0.1 nameserver 192.168.122.1 nslookup test.pl Server: 127.0.0.1 Address: 127.0.0.1#53 Name: test.pl Address: 192.168.122.10 Do tej pory wszystko pieknie. Problem pojawia sie gdy chce na innym gosciu wykonac to samo polecenie INNY GOSC: cat /etc/resolv.conf nameserver 192.168.122.10 - to jest adres serwera dns nslookup test.pl ;; connection timed out; trying next origin ;; connection timed out; no servers could be reached Gdzie czegos nie zrobilem Z gory dziekuje za pomoc. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Miszcz Napisano Sierpień 5, 2014 Zgłoszenie Share Napisano Sierpień 5, 2014 To jest twój problem : listen-on port 53 { 127.0.0.1; }; Dla każdego systemu adres 127.0.0.1 to jest on sam. Zamień to na właściwy adres serwera i powinno banglać. Ponadto polecam na przyszłość polecenie: netstat -tulpn (czyli co i na jakim adresie nasłuchuje). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mskiba Napisano Sierpień 5, 2014 Autor Zgłoszenie Share Napisano Sierpień 5, 2014 Dzieki za pomoc, ale udalo mi sie do tego dojsc chwile po napisaniu posta Tak jak mowiles: listen-on port 53 { 127.0.0.1; 192.168.122.0/24; }; to zalatwilo sprawe, plus odblokowanie portu 53. Jeszcze jedno: Dodalem domene: test.pl juz na kazdym gosniu ladnie rozwiazuje ta nazwe. Jak dodam adres ip np: autobaza IN A 192.168.122.100 to czy jest jakas mozliwosc, zeby na gosciach pingowac to wywoluja tylko: ping autobaza W windowsie dodaje sie po prostu dns w ustawieniach karty sieciowej, a na fedorce nie moge tego znalezc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mskiba Napisano Sierpień 5, 2014 Autor Zgłoszenie Share Napisano Sierpień 5, 2014 Znalazlem /etc/resolv.conf search test.pl Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mskiba Napisano Sierpień 9, 2014 Autor Zgłoszenie Share Napisano Sierpień 9, 2014 Mam jeszcze pytanko, jak na gosciu w konsoli sprawdzic jak nazywa sie dysk na gospodarzu? [root@md01 dev]# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sr0 11:0 1 1024M 0 rom vda 252:0 0 10G 0 disk ├─vda1 252:1 0 200M 0 part /boot └─vda2 252:2 0 7,8G 0 part ├─md01vg-root 253:0 0 4,9G 0 lvm / ├─md01vg-swap 253:1 0 1000M 0 lvm [SWAP] ├─md01vg-home 253:2 0 1000M 0 lvm /home └─md01vg-var 253:3 0 1000M 0 lvm /var vdb 252:16 0 2G 0 disk vdc 252:32 0 2G 0 disk vdd 252:48 0 2G 0 disk vde 252:64 0 2G 0 disk vdf 252:80 0 2G 0 disk vdg 252:96 0 2G 0 disk vdh 252:112 0 2G 0 disk vdi 252:128 0 2G 0 disk vdj 252:144 0 2G 0 disk vdk 252:160 0 2G 0 disk chodzi mi o te dyski vdb 252:16 0 2G 0 disk vdc 252:32 0 2G 0 disk Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Miszcz Napisano Sierpień 10, 2014 Zgłoszenie Share Napisano Sierpień 10, 2014 Raczej nie wydaje mi się, że to jest możliwe. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
