puti Napisano Maj 22, 2015 Zgłoszenie Share Napisano Maj 22, 2015 Witam, ustawiłem sobie politykę skalowania CPU tak aby na baterii CPU nie wychodził ponad 1,5GHz. Niestety to nie działa : [michalp@localhost ~]$ cpupower frequency-info analyzing CPU 0: driver: intel_pstate CPUs which run at the same hardware frequency: 0 CPUs which need to have their frequency coordinated by software: 0 maximum transition latency: 0.97 ms. hardware limits: 1.20 GHz - 3.30 GHz available cpufreq governors: performance, powersave current policy: frequency should be within 1.20 GHz and 1.50 GHz. The governor "powersave" may decide which speed to use within this range. current CPU frequency is 3.17 GHz. niezależnie czy zarządcą będzie powersave czy performance skalują sobie jak chcą wg limitu hardware a nie policy, którą napisałem [michalp@localhost ~]$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq1500000 o co może chodzić ? Pozdrawiam Michał Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
puti Napisano Maj 23, 2015 Autor Zgłoszenie Share Napisano Maj 23, 2015 odpowiedź z http://forums.fedoraforum.org: That's correct. This issue has been discussed here on the forum in the past. With modern Intel cpu's, the cpu itself will always determine the actual frequency to use. The cpu frequency and power level is very dynamic (can change hundreds of times in a second) so what you see as the "current CPU frequency" using cpupower is only a momentary snapshot. Actually, cpupower can't even begin to keep up the actual frequency changes. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
