Gość Napisano Marzec 6, 2004 Zgłoszenie Share Napisano Marzec 6, 2004 Z terminala : [root@20ceg003 root]# apt-get install k3b Reading Package Lists... Done Building Dependency Tree... Done You might want to run `apt-get -f install' to correct these: The following packages have unmet dependencies: winex: Conflicts: wine but 20040213-1fc1winehq is to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). [root@20ceg003 root]# apt-get -f install Reading Package Lists... Done Building Dependency Tree... Done Correcting dependencies... Done The following packages will be REMOVED: wine 0 upgraded, 0 newly installed, 1 removed and 119 not upgraded. Need to get 0B of archives. After unpacking 38.7MB disk space will be freed. Do you want to continue? [Y/n] y Committing changes... Preparing... ########################################### [100%] error reading information on service wine: No such file or directory error: %preun(wine-20040213-1fc1winehq) scriptlet failed, exit status 1 W: Some errors occurred while running transaction [root@20ceg003 root]# apt-get remove wine Reading Package Lists... Done Building Dependency Tree... Done The following packages will be REMOVED: wine 0 upgraded, 0 newly installed, 1 removed and 119 not upgraded. Need to get 0B of archives. After unpacking 38.7MB disk space will be freed. Do you want to continue? [Y/n] y Committing changes... Preparing... ########################################### [100%] error reading information on service wine: No such file or directory error: %preun(wine-20040213-1fc1winehq) scriptlet failed, exit status 1 W: Some errors occurred while running transaction [root@20ceg003 root]# apt-get remove winex Reading Package Lists... Done Building Dependency Tree... Done The following packages will be REMOVED: winex 0 upgraded, 0 newly installed, 1 removed and 119 not upgraded. Need to get 0B of archives. After unpacking 34.1MB disk space will be freed. Do you want to continue? [Y/n] y Committing changes... Preparing... ########################################### [100%] mv: cannot stat `//usr/share/doc/winex/mimetypes/x-msdos-program.desktop.old': No such file or directory error: %preun(winex-3.3-1) scriptlet failed, exit status 1 W: Some errors occurred while running transaction [root@20ceg003 root]# No i co teraz? Da się to wywalić ręcznie? Z góry dziękuję za pomoc. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
arek30 Napisano Marzec 14, 2004 Zgłoszenie Share Napisano Marzec 14, 2004 #rpm -e winex --nodeps #rpm -e wine powinno zadziałc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
