bogjoz Napisano Luty 12, 2017 Zgłoszenie Share Napisano Luty 12, 2017 Mam problem z WiFi Komputer jest Dual System Fedora 25 i Win7, WiFi na Win7 działa, po upgrade Fedory do 25 po uruchomieniu WiFI trche działa a następnie gubi połączenie kilka moich diagnostycznych treści z logów: messages: Feb 12 09:59:49 DDI353BW kernel: wlp3s0: Connection to AP 38:2c:4a:ce:e0:10 lostFeb 12 10:00:02 DDI353BW wpa_supplicant[1268]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=38:2c:4a:ce:e0:10 reason=4 locally_generated=1Feb 12 10:00:02 DDI353BW NetworkManager[1133]: <warn> [1486890002.7620] sup-iface[0x5594fba72c00,wlp3s0]: connection disconnected (reason -4)Feb 12 10:00:02 DDI353BW NetworkManager[1133]: <info> [1486890002.7679] device (wlp3s0): supplicant interface state: completed -> disconnectedFeb 12 10:00:02 DDI353BW wpa_supplicant[1268]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLDFeb 12 10:00:02 DDI353BW wpa_supplicant[1268]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=PLFeb 12 10:00:11 DDI353BW NetworkManager[1133]: <info> [1486890011.6624] device (wlp3s0): supplicant interface state: disconnected -> scanningFeb 12 10:00:17 DDI353BW NetworkManager[1133]: <warn> [1486890017.6388] device (wlp3s0): link timed out.Feb 12 10:00:17 DDI353BW NetworkManager[1133]: <info> [1486890017.6392] device (wlp3s0): state change: activated -> failed (reason 'ssid-not-found') [100 120 53]Feb 12 10:00:17 DDI353BW NetworkManager[1133]: <info> [1486890017.6394] manager: NetworkManager state is now CONNECTED_LOCALFeb 12 10:00:17 DDI353BW NetworkManager[1133]: <warn> [1486890017.9419] device (wlp3s0): Activation: failed for connection 'ajbjg24'Feb 12 10:00:17 DDI353BW kernel: IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready iwconfigvirbr0-nic no wireless extensions.virbr0 no wireless extensions.wlp3s0 IEEE 802.11 ESSID:"ajbjg24" Mode:Managed Frequency:2.452 GHz Access Point: 38:2C:4A:CE:E0:10 Bit Rate=7.2 Mb/s Tx-Power=20 dBm Retry short limit:7 RTS thr=2347 B Fragment thr:off Power Management:off Link Quality=70/70 Signal level=-26 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:5 Missed beacon:0enp0s25 no wireless extensions.lo no wireless extensions. gdy zgubi enp0s25 no wireless extensions.lo no wireless extensions.virbr0-nic no wireless extensions.virbr0 no wireless extensions.wlp3s0 IEEE 802.11 ESSID:off/any Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm Retry short limit:7 RTS thr=2347 B Fragment thr:off Power Management:off modinfo rtl8192cefilename: /lib/modules/4.9.8-201.fc25.x86_64/kernel/drivers/net/wireless/realtek/rtlwifi/rtl8192ce/rtl8192ce.ko.xzfirmware: rtlwifi/rtl8192cfwU_B.binfirmware: rtlwifi/rtl8192cfwU.binfirmware: rtlwifi/rtl8192cfw.bindescription: Realtek 8192C/8188C 802.11n PCI wirelesslicense: GPLauthor: Larry Finger <[email protected]>author: Realtek WlanFAE <[email protected]>author: lizhaoming <[email protected]>alias: pci:v000010ECd00008176sv*sd*bc*sc*i*alias: pci:v000010ECd00008177sv*sd*bc*sc*i*alias: pci:v000010ECd00008178sv*sd*bc*sc*i*alias: pci:v000010ECd00008191sv*sd*bc*sc*i*depends: rtlwifi,rtl_pci,rtl8192c-common,mac80211intree: Yvermagic: 4.9.8-201.fc25.x86_64 SMP mod_unloadsignat: PKCS#7signer: sig_key: sig_hashalgo: md4parm: swenc:Set to 1 for software crypto (default 0) (bool)parm: ips:Set to 0 to not use link power save (default 1) (bool)parm: swlps:Set to 1 to use SW control power save (default 0) (bool)parm: fwlps:Set to 1 to use FW control power save (default 1) (bool)parm: debug:Set debug level (0-5) (default 0) (int) i z sudo journalctl _SYSTEMD_UNIT=NetworkManager.service: lut 11 21:02:03 DDI353BW NetworkManager[1128]: <warn> [1486843323.4277] sup-iface[0x55db58847c20,wlp3s0]: connection disconnected (reason -4)lut 11 21:02:03 DDI353BW NetworkManager[1128]: <info> [1486843323.4328] device (wlp3s0): supplicant interface state: completed -> disconnectedlut 11 21:02:12 DDI353BW NetworkManager[1128]: <info> [1486843332.3415] device (wlp3s0): supplicant interface state: disconnected -> scanninglut 11 21:02:18 DDI353BW NetworkManager[1128]: <warn> [1486843338.6442] device (wlp3s0): link timed out.lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.6446] device (wlp3s0): state change: activated -> failed (reason 'ssid-not-found') [100 120 53]lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.6448] manager: NetworkManager state is now CONNECTED_LOCALlut 11 21:02:18 DDI353BW NetworkManager[1128]: <warn> [1486843338.7278] device (wlp3s0): Activation: failed for connection 'ajbjg24'lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.7297] device (wlp3s0): state change: failed -> disconnected (reason 'none') [120 30 0]lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.7425] dhcp4 (wlp3s0): canceled DHCP transaction, DHCP client pid 1383lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.7426] dhcp4 (wlp3s0): state changed bound -> donelut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.7597] device (wlp3s0): set-hw-addr: set MAC address to 72:4D:69:48:F0:A6 (scanning)lut 11 21:02:19 DDI353BW NetworkManager[1128]: <info> [1486843339.1380] device (wlp3s0): supplicant interface state: scanning -> disconnectedlut 11 21:02:19 DDI353BW NetworkManager[1128]: <info> [1486843339.1429] device (wlp3s0): supplicant interface state: disconnected -> inactivelut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.0857] policy: auto-activating connection 'ajbjg24'lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.0867] device (wlp3s0): Activation: starting connection 'ajbjg24' (6c1351a6-a242-4167-9971-caf0d0a9c7f7)lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.0868] device (wlp3s0): state change: disconnected -> prepare (reason 'none') [30 40 0]lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.0870] manager: NetworkManager state is now CONNECTINGlut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.0887] device (wlp3s0): set-hw-addr: set-cloned MAC address to 7C:E9:D3:EE:E1:74 (permanent)lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4433] device (wlp3s0): supplicant interface state: inactive -> disabledlut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4683] device (wlp3s0): state change: prepare -> config (reason 'none') [40 50 0]lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4686] device (wlp3s0): Activation: (wifi) access point 'ajbjg24' has security, but secrets are required.lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4687] device (wlp3s0): state change: config -> need-auth (reason 'none') [50 60 0]lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4731] device (wlp3s0): state change: need-auth -> prepare (reason 'none') [60 40 0]lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4735] device (wlp3s0): supplicant interface state: disabled -> inactive Czy ktoś ma jakąś sugestię Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
racon Napisano Luty 13, 2017 Zgłoszenie Share Napisano Luty 13, 2017 Mam problem z WiFi Komputer jest Dual System Fedora 25 i Win7, WiFi na Win7 działa, po upgrade Fedory do 25 po uruchomieniu WiFI trche działa a następnie gubi połączenie i z sudo journalctl _SYSTEMD_UNIT=NetworkManager.service:lut 11 21:02:03 DDI353BW NetworkManager[1128]: <warn> [1486843323.4277] sup-iface[0x55db58847c20,wlp3s0]: connection disconnected (reason -4)lut 11 21:02:03 DDI353BW NetworkManager[1128]: <info> [1486843323.4328] device (wlp3s0): supplicant interface state: completed -> disconnected lut 11 21:02:12 DDI353BW NetworkManager[1128]: <info> [1486843332.3415] device (wlp3s0): supplicant interface state: disconnected -> scanning lut 11 21:02:18 DDI353BW NetworkManager[1128]: <warn> [1486843338.6442] device (wlp3s0): link timed out. lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.6446] device (wlp3s0): state change: activated -> failed (reason 'ssid-not-found') [100 120 53] lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.6448] manager: NetworkManager state is now CONNECTED_LOCAL lut 11 21:02:18 DDI353BW NetworkManager[1128]: <warn> [1486843338.7278] device (wlp3s0): Activation: failed for connection 'ajbjg24' lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.7297] device (wlp3s0): state change: failed -> disconnected (reason 'none') [120 30 0] lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.7425] dhcp4 (wlp3s0): canceled DHCP transaction, DHCP client pid 1383 lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.7426] dhcp4 (wlp3s0): state changed bound -> done lut 11 21:02:18 DDI353BW NetworkManager[1128]: <info> [1486843338.7597] device (wlp3s0): set-hw-addr: set MAC add księgowa Warszawa ress to 72:4D:69:48:F0:A6 (scanning) lut 11 21:02:19 DDI353BW NetworkManager[1128]: <info> [1486843339.1380] device (wlp3s0): supplicant interface state: scanning -> disconnected lut 11 21:02:19 DDI353BW NetworkManager[1128]: <info> [1486843339.1429] device (wlp3s0): supplicant interface state: disconnected -> inactive lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.0857] policy: auto-activating connection 'ajbjg24' lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.0867] device (wlp3s0): Activation: starting connection 'ajbjg24' (6c1351a6-a242-4167-9971-caf0d0a9c7f7) lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.0868] device (wlp3s0): state change: disconnected -> prepare (reason 'none') [30 40 0] lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.0870] manager: NetworkManager state is now CONNECTING lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.0887] device (wlp3s0): set-hw-addr: set-cloned MAC address to 7C:E9:D3:EE:E1:74 (permanent) lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4433] device (wlp3s0): supplicant interface state: inactive -> disabled lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4683] device (wlp3s0): state change: prepare -> config (reason 'none') [40 50 0] lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4686] device (wlp3s0): Activation: (wifi) access point 'ajbjg24' has security, but secrets are required. lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4687] device (wlp3s0): state change: config -> need-auth (reason 'none') [50 60 0] lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4731] device (wlp3s0): state change: need-auth -> prepare (reason 'none') [60 40 0] lut 11 21:02:20 DDI353BW NetworkManager[1128]: <info> [1486843340.4735] device (wlp3s0): supplicant interface state: disabled -> inactive Czy ktoś ma jakąś sugestię Hmm, a może spróbuj przejść na inny menadzer sieci? Z Netwok Menagera na np. wicd? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
