Andrew_g Napisano Grudzień 14, 2004 Zgłoszenie Share Napisano Grudzień 14, 2004 mam Agfa Snapscan 1236 i nie mogę go odpalić z xsane [andrew@troll andrew]$ sane-find-scanner # No SCSI scanners found. If you expected something different, make sure that # you have loaded a SCSI driver for your SCSI adapter. found USB scanner (vendor=0x06bd, product=0x0002) at libusb:001:002 # Your USB scanner was (probably) detected. It may or may not be supported by # SANE. Try scanimage -L and read the backend's manpage. # Scanners connected to the parallel port or other proprietary ports can't be # detected by this program. # You may want to run this program as root to find all devices. Once you # found the scanner devices, be sure to adjust access permissions as # necessary. [andrew@troll andrew]$ scanimage -L No scanners were identified. If you were expecting something different, check that the scanner is plugged in, turned on and detected by the sane-find-scanner tool (if appropriate). Please read the documentation which came with this software (README, FAQ, manpages). [andrew@troll andrew]$ cat /proc/bus/usb/devices T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=12 MxCh= 0 D: Ver= 1.00 Cls=ff(vend.) Sub=ff Prot=ff MxPS= 8 #Cfgs= 1 P: Vendor=06bd ProdID=0002 Rev= 0.72 S: Manufacturer=AGFA S: Product=SNAPSCAN 1236U C:* #Ifs= 1 Cfg#= 1 Atr=40 MxPwr=100mA I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 8 Ivl=0ms E: Ad=83(I) Atr=03(Int.) MxPS= 8 Ivl=16ms [root@troll RPMS]# /sbin/lsusb Bus 001 Device 002: ID 06bd:0002 AGFA-Gevaert NV SnapScan 1236U Bus 001 Device 001: ID 0000:0000 z góry dzięki za pomoc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
