Rt2400 I Kernel 2.6.10
mounter
Witam
Po aktualizacji jadra nie moge skompilowac sterownikow. Oto co wyrzuca 'make'
make[1]: Entering directory `/lib/modules/2.6.10-1.737_FC3/build'
 CC [M]  /root/progrmy/rt2400-1.2.0/Module/rtmp_main.o
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c: In function `RT2400_probe':
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c:132: warning: passing arg 1 of `readl' makes pointer from integer without a cast
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c:133: warning: passing arg 1 of `readl' makes pointer from integer without a cast
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c:178: warning: label `err_out_free_res' defined but not used
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c: In function `RT2400_open':
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c:258: warning: passing arg 2 of `writel' makes pointer from integer without a cast
/root/progrmy/rt2400-1.2.0/Module/rtmp.h:847: sorry, unimplemented: inlining failed in call to 'NICDisableInterrupt': function body not available
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c:205: sorry, unimplemented: called from here
/root/progrmy/rt2400-1.2.0/Module/rtmp.h:850: sorry, unimplemented: inlining failed in call to 'NICEnableInterrupt': function body not available
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c:259: sorry, unimplemented: called from here
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c: In function `RTMPIsr':
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c:378: warning: passing arg 1 of `readl' makes pointer from integer without a cast
/root/progrmy/rt2400-1.2.0/Module/rtmp_main.c:379: warning: passing arg 2 of `writel' makes pointer from integer without a cast
make[2]: *** [/root/progrmy/rt2400-1.2.0/Module/rtmp_main.o] Błąd 1
make[1]: *** [_module_/root/progrmy/rt2400-1.2.0/Module] Błąd 2
make[1]: Leaving directory `/lib/modules/2.6.10-1.737_FC3/build'
rt2400.ko failed to build!
make: *** [module] Błąd 1
przy sterowniku 1.2.1 ten sam problem nie wiem jak sobie z tym poradzic, bo z jajkiem 2.6.9 nie bylo problemow. Moze ktos sie spotkal z taka przypadloscia?
