Dodać Fluxboxa Do Gdm
Piotr82
Zainstalowałem v0.9.12 i chce dodać go do gdm.
Zrobiłem plik w /etc/X11/gdm/Sessions Fluxbox :
#!/bin/bash
exec /etc/X11/xdm/Xsession fluxbox
Potem plik /etc/X11/xdm/Xsession wyglada tak kawałek gdzie dodałem :
fluxbox)
exec -l $SHELL -c "startfluxbox"
# Mandatorily source xinitrc-common, which is common code shared between the
# Xsession and xinitrc scripts which has been factored out to avoid duplication
. /etc/X11/xinit/xinitrc-common
# now, we see if xdm/gdm/kdm has asked for a specific environment
case $# in
1)
    if [ -x "$SWITCHDESKPATH/Xclients.$1" ]; then
      exec -l $SHELL -c "$SWITCHDESKPATH/Xclients.$1";
    fi;
    case "$1" in
    failsafe)
      exec -l $SHELL -c "xterm -geometry 80x24-0-0"
    gnome)
      exec -l $SHELL -c "$DBUS_LAUNCH gnome-session"
    fluxbox)
    kde|kde1|kde2)
      exec -l $SHELL -c "$DBUS_LAUNCH $SWITCHDESKPATH/Xclients.kde"
    twm)
        # fall back to twm
      exec -l $SHELL -c "$DBUS_LAUNCH $SWITCHDESKPATH/Xclients.twm"
      # GDM provies either a command line as the first argument or
      # provides 'failsafe', 'default' or 'custom'.  KDM will do the
      # same at some point
      if [ "$1" != "default" -a "$1" != "custom" ]; then
          exec -l $SHELL -c "$DBUS_LAUNCH $1"
      fi
    esac
esac
No i nic sie nie pojawia w gdm.
