lewy22 Napisano Styczeń 25, 2005 Zgłoszenie Share Napisano Styczeń 25, 2005 Posiadam FC3 , Radeon 9500Pro i kernel-2.6.10-1.741 , zainstalowalem z Livna.org stery do ati : [root@lewy lewy]# yum install ati-fglrx ati-fglrx-devel kernel-module-fglrx-$(uname -r) wszystko sie ladnie zainstalowalo ale po restarcie kompa X-y sie uruchomily : [lewy@lewy ~]$ glxinfo name of display: :0.0 Xlib: extension "XFree86-DRI" missing on display ":0.0". display: :0 screen: 0 direct rendering: No server glx vendor string: SGI server glx version string: 1.2 server glx extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig client glx vendor string: ATI client glx version string: 1.3 client glx extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float, GLX_ATI_render_texture GLX extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_multisample OpenGL vendor string: Mesa project: www.mesa3d.org OpenGL renderer string: Mesa GLX Indirect OpenGL version string: 1.2 (1.5 Mesa 6.1) OpenGL extensions: GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias glu version: 1.3 glu extensions: GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ------------------------------------------------------------ ---------- 0x23 24 tc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 1 0 None 0x24 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 1 0 None 0x25 24 tc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 1 0 None 0x26 24 tc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 1 0 None 0x27 24 dc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 1 0 None 0x28 24 dc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 1 0 None 0x29 24 dc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 1 0 None 0x2a 24 dc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 1 0 None [lewy@lewy ~]$ fgl_glxgears Xlib: extension "XFree86-DRI" missing on display ":0.0". X Error of failed request: BadMatch (invalid parameter attributes) Major opcode of failed request: 143 (GLX) Minor opcode of failed request: 5 (X_GLXMakeCurrent) Serial number of failed request: 30 Current serial number in output stream: 30 czy moze ktos wie co z tym zrobic ? lub ma podobne problemy ? tylko prosze jak cos to jasno bo jestem nowy w temacie (_linuxa_ → Linuksa) ORT , z gory dzieki za pomoc!!! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
stitch Napisano Styczeń 26, 2005 Zgłoszenie Share Napisano Styczeń 26, 2005 Rozumiem ze masz zainstalowane obydwie paczki : ati-fglrx-8.8.25.1-0.lvn.4.3.i386.rpm kernel-module-fglrx-2.6.10-1.741_FC3-8.8.25.1-0.lvn.4.3.i686.rpm Jezeli tak to sprawdz co jest grane w /var/log/Xorg.0.log Ja naprzyklad mialem problem z rozpoznaniem AGP i daj swoj xorg.conf ( ja go konfigurowalem chyba z 5 razy zanim ruszylo ) aaa i jeszcze jedna sprawa sprobuj najpierw zainstalowac/upgradnac paczki z opcja --force jest konflikt miedzy MESA i driverami ATI - musisz nadpisac pliki . Pozdrawiam Stitch Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lewy22 Napisano Styczeń 26, 2005 Autor Zgłoszenie Share Napisano Styczeń 26, 2005 oki z tym juz sobie poradzilem , wszystko jeszcze raz odinstaloawlem pozniej zainstalowalem kernel-source i stery ati z livna.org troche przerobilem xorg.conf korzystajac z rad zawartych na http://www.rage3d.com/ i dziala tylko teraz mam cos takiego : [lewy@lewy ~]$ glxinfo name of display: :0.0 display: :0 screen: 0 direct rendering: Yes server glx vendor string: SGI server glx version string: 1.2 server glx extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig client glx vendor string: ATI client glx version string: 1.3 client glx extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float, GLX_ATI_render_texture GLX extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_multisample OpenGL vendor string: ATI Technologies Inc. OpenGL renderer string: RADEON 9500 Generic OpenGL version string: 1.3.4769 (X4.3.0-8.8.25) OpenGL extensions: GL_ARB_multitexture, GL_EXT_texture_env_add, GL_EXT_compiled_vertex_array, GL_S3_s3tc, GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader, GL_ARB_multisample, GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shader_objects, GL_ARB_shading_language_100, GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp, GL_ARB_texture_compression, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix, GL_ARB_vertex_blend, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_element_array, GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader, GL_ATI_map_object_buffer, GL_ATI_separate_stencil, GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_ATI_vertex_array_object, GL_ATI_vertex_attrib_array_object, GL_ATI_vertex_streams, GL_ATIX_texture_env_combine3, GL_ATIX_texture_env_route, GL_ATIX_vertex_shader_output_point_size, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_texgen_reflection, GL_EXT_texture3D, GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_EXT_vertex_shader, GL_HP_occlusion_test, GL_NV_texgen_reflection, GL_NV_blend_square, GL_NV_occlusion_query, GL_SGI_color_matrix, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_border_clamp, GL_SGIS_texture_lod, GL_SGIS_generate_mipmap, GL_SUN_multi_draw_arrays glu version: 1.3 glu extensions: GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x23 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x24 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1 0 None 0x28 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 1 0 None 0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 1 0 None 0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 1 0 None 0x2b 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x2c 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x2d 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x2e 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x2f 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 2 1 None 0x30 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 2 1 None 0x31 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 2 1 None 0x32 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 2 1 None 0x33 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x34 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x35 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x36 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x37 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 4 1 None 0x38 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 4 1 None 0x39 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 4 1 None 0x3a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 4 1 None 0x3b 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x3c 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x3d 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x3e 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x3f 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 6 1 None 0x40 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 6 1 None 0x41 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 6 1 None 0x42 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 6 1 None 0x43 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x44 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x45 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x46 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x47 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1 0 None 0x48 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 1 0 None 0x49 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 1 0 None 0x4a 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 1 0 None 0x4b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x4c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x4d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x4e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x4f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 2 1 None 0x50 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 2 1 None 0x51 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 2 1 None 0x52 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 2 1 None 0x53 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x54 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x55 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x56 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x57 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 4 1 None 0x58 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 4 1 None 0x59 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 4 1 None 0x5a 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 4 1 None 0x5b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x5c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 1 0 None 0x5d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x5e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 1 0 None 0x5f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 6 1 None 0x60 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 6 1 None 0x61 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 6 1 None 0x62 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 6 1 None [lewy@lewy ~]$ fgl_glxgears 1022 frames in 5.0 seconds = 204.400 FPS 1289 frames in 5.0 seconds = 257.800 FPS 1837 frames in 5.0 seconds = 367.400 FPS 2119 frames in 5.0 seconds = 423.800 FPS 2139 frames in 5.0 seconds = 427.800 FPS 2125 frames in 5.0 seconds = 425.000 FPS 2123 frames in 5.0 seconds = 424.600 FPS 2135 frames in 5.0 seconds = 427.000 FPS 2137 frames in 5.0 seconds = 427.400 FPS 2121 frames in 5.0 seconds = 424.200 FPS 2095 frames in 5.0 seconds = 419.000 FPS 2126 frames in 5.0 seconds = 425.200 FPS 1646 frames in 5.0 seconds = 329.200 FPS a to moj xorg.conf : # XFree86 4 configuration created by pyxf86config Section "ServerLayout" Identifier "Default Layout" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" # RgbPath is the location of the RGB database. Note, this is the name of the # file minus the extension (like ".txt" or ".db"). There is normally # no need to change the default. # Multiple FontPath entries are allowed (they are concatenated together) # By default, Red Hat 6.0 and later now use a font server independent of # the X server to render fonts. RgbPath "/usr/X11R6/lib/X11/rgb" FontPath "unix/:7100" EndSection Section "Module" Load "dbe" Load "extmod" Load "fbdevhw" Load "glx" Load "record" Load "freetype" Load "type1" Load "dri" EndSection Section "InputDevice" # Specify which keyboard LEDs can be user-controlled (eg, with xset(1)) # Option "Xleds" "1 2 3" # To disable the XKEYBOARD extension, uncomment XkbDisable. # Option "XkbDisable" # To customise the XKB settings to suit your keyboard, modify the # lines below (which are the defaults). For example, for a non-U.S. # keyboard, you will probably want to use: # Option "XkbModel" "pc102" # If you have a US Microsoft Natural keyboard, you can use: # Option "XkbModel" "microsoft" # # Then to change the language, change the Layout setting. # For example, a german layout can be obtained with: # Option "XkbLayout" "de" # or: # Option "XkbLayout" "de" # Option "XkbVariant" "nodeadkeys" # # If you'd like to switch the positions of your capslock and # control keys, use: # Option "XkbOptions" "ctrl:swapcaps" # Or if you just want both to be control, use: # Option "XkbOptions" "ctrl:nocaps" # Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "pl" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "yes" EndSection Section "Monitor" Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "FLATRON F700" DisplaySize 330 250 HorizSync 30.0 - 70.0 VertRefresh 50.0 - 160.0 Option "dpms" EndSection Section "Device" Identifier "Videocard0" Driver "fglrx" VendorName "Videocard vendor" BoardName "ATI Radeon 9500 Pro" Option "VideoOverlay" "on" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 16 Modes "800x600" "640x480" EndSubSection SubSection "Display" Viewport 0 0 Depth 24 Modes "1024x768" "800x600" "640x480" EndSubSection EndSection Section "DRI" Group 0 Mode 0666 EndSection Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
stitch Napisano Styczeń 26, 2005 Zgłoszenie Share Napisano Styczeń 26, 2005 To chyba dobrze masz ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lewy22 Napisano Styczeń 26, 2005 Autor Zgłoszenie Share Napisano Styczeń 26, 2005 nom 3D dziala w tux racer , jeszcze musze tylko posprawdzac na innych gierkach tylko dziwna jest tak duza ilosc komunikatow podczas glrxinfo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
pit664 Napisano Styczeń 26, 2005 Zgłoszenie Share Napisano Styczeń 26, 2005 lewy22 a wrzuc tutaj wynik fglrxinfo ? poszła Ci akceleracja ATI bez rozbudowania sekcji "device"? pozdr dodane: juz sam sprawdziłem -idzie - tylko ja musze dodac jednak: Option "UseInternalAGPGART" "no" bez tego zwis (doczytałem ze fglrx słabo obsługuje SiS w wewnętrznym AGPGART). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Brutus Napisano Styczeń 26, 2005 Zgłoszenie Share Napisano Styczeń 26, 2005 pit664 To samo musialem dodac zeby na nforce 2 ruszylo grunt ze dziala Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
pit664 Napisano Styczeń 27, 2005 Zgłoszenie Share Napisano Styczeń 27, 2005 Pewnie ze działa, działało mi w wcześniej, ale miałem bardzo rozbudowany xorg.conf bo wklejałem całą sekcję "device" z wygenerowanego XF86Config-4 (duża kobyła - patrz mój wczesniejszy post o tym), a tu masz - lewy22 dał króciutki xorg.conf i chodzi...., chwila myslówki, dodałem opcję AGP na kernelowy agpgart (to doczytałem juz wcześniej) i też chodzi! a róznica w klatkach nieznaczna.... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lewy22 Napisano Styczeń 30, 2005 Autor Zgłoszenie Share Napisano Styczeń 30, 2005 mam tylko takiego xorg.conf jakiego juz wczesniej podalem ale na Quake 3 nie moge narzekac wkoncu mi sie udalo cos samemu zrobic i dziala jestem jeszcze troszke zielony pod linuxem ale czasami mi cos wychodzi Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Woody99 Napisano Styczeń 30, 2005 Zgłoszenie Share Napisano Styczeń 30, 2005 witam przyglądam się i próbuję zrobić to co tu jest napisane ale nic mi z tego niewychodzi i (_niedziała_ → nie działa) ORT mi nadal karta tak jak powinna z ty6m że ja posiadam auroxa 10 może tu jest mój problem ?? pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
morcin Napisano Luty 1, 2005 Zgłoszenie Share Napisano Luty 1, 2005 lewy22 a wrzuc tutaj wynik fglrxinfo ? poszła Ci akceleracja ATI bez rozbudowania sekcji "device"? pozdr dodane: juz sam sprawdziłem -idzie - tylko ja musze dodac jednak: Option "UseInternalAGPGART" "no" bez tego zwis (doczytałem ze fglrx słabo obsługuje SiS w wewnętrznym AGPGART). witam! Widzę że przebrnełeś przez instalację na SIS, ja mam k7s8x i nie mogę sobie poradzić- może się podzielisz wiedzą. Mam problem tego rodzaju że nie mogę załadować agpgart koniecznego do obsługi AGP aby poszła akceleracja (fglrx jako moduł mam załadowane) nie mogę zmienić wywołań do pci w agpgart_be.c ponieważ ten plik nie istnieje (?) Próbowałem załadować agpgart z pakietu udev ale natrafiam na konflikt: jest już zainstalowany udevfs.... Jaka jest droga do wyjścia z tej sytuacji? wyczerpałem już skarbnice "googlowe" może wiesz co jest z tym sisem i jak się uporać? byłbym wdzięczny za każdą pomoc... p.s wcześniej miałem stery Nvidi -może jakiś konflikt modułów jądra? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lewy22 Napisano Luty 1, 2005 Autor Zgłoszenie Share Napisano Luty 1, 2005 witam przyglądam się i próbuję zrobić to co tu jest napisane ale nic mi z tego niewychodzi i (_niedziała_ → nie działa) ORT mi nadal karta tak jak powinna z ty6m że ja posiadam auroxa 10 może tu jest mój problem ?? pozdrawiam mi pomogla jeszcze ta stronka : http://www.stanford.edu/~fenn/linux/radeon.shtml ale i tak jak narazie zalwazylem dwa bledy , czasami mi sie X-y wieszaja jak sie wlancza jakis wygaszacz ekranu i ostatnio sie wiesza ut_2003 ale to wszystko zalezy od dnia , a moze to kryzys mojego kompa Wiem jedno , jak bede mial troche kasy to (_napewno_ → na pewno) ORT zmieniam radeona na Geforce mam juz dosc problemow z tym radeonem , jak Ati chce olewac (_linuxa_ → Linuksa) ORT to ja tez ich oleje : Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
