Jak Ustawić Tvout W Ati Radeon 9200 ?
piggy
Witam
Spróbuj doładować sobie ATI TV TOOL. Niżej masz raport dla mojej kart (9600TX):
[root@localhost enter]# atitvout
atitvout 0.4 :: ATI Rage/Radeon TV Out configuration program
Lennart Poettering <[email protected]> 2001,2002
http://www.stud.uni-hamburg.de/users/lenna...jects/atitvout/
Licensed under the GNU General Public License,
http://www.gnu.org/licenses/gpl.html#SEC1
Supported commands:
help: Shows this help.
vbe: Show some information about the VESA BIOS Extension (VBE).
tvout: Shows some information about the TV Out connector.
standard: Shows some information about the used TV standard.
pal*: Sets PAL mode.
ntsc*: Sets NTSC mode.
detect: Shows a list of attached displays.
active: Shows a list of all active displays.
auto: Activates all attached displays, deactivates all others.
off: Deactives all displays.
l,c,t,lc,lt,ct,lct: Activates the specified display, deactivates all
others. (l = LCD; c = CRT; t = TV)
Use the flags -f and -r for forcing Rage Mobility/Rage LT resp. Radeon/R128 mode.
* Not available on Radeon/Rage 128.
You may specifiy more than one command on the command line. An example:
atitvout pal auto
This command line automatically enables an attached TV and sets it to PAL mode.
PLEASE NOTE: When using the ati driver of XFree 4.1 you should rerun this
utility always after having changed the screen resolution with C-A-+ or C-A--.
Otherwise the displays may go nuts.
PLEASE NOTE: Not all ATI adapters support all of these commands. Please try them
all before complaining.
PLEASE NOTE: Most cards do not allow to activate non attached displays. All calls
to atitvout will fail if you try to enable displays which do not show up in
'atitvout detect'.
PLEASE NOTE: Not all adapters seem to support simultaneously using TV and LCD from
within Linux. Thus 'lt' may fail, while 'l' and 't' succeed. In this case 'auto'
will fail too. In fact 'auto' works only on very few adapters.
Możesz go bez problemu zainstalować przy pomocy apta lub wygodniej synaptikiem. To jest mój raport z synaptica:
This utility program may be used for executing several configuration
commands for the TV Out connector of ATI Rage Mobility P/M graphics
boards under GNU/Linux on x86. It is intended primarily to enable TV
Out support after bootup and for switching the used TV standard from
NTSC to PAL.
The utility makes use of x86-VESA-BIOS-calls and thus is not portable
to other architectures like PPC: No TV-Out on Macs with this tool.
Wersja 0.4-0.1.fc3.rf
Rozmiar: 47,2 KB
Pakiet: atitvout – tool to use ATI TV-OUT
Opiekun: Dag Wieers
Jescze jedno musisz uaktywnić wyjście w czasie konfiguracji sterownika karty graficznej w fglrxconfig.
Marek
