Clanbomber Jak To Zrobic?
andriusza1
Moze mi ktos powiedziec jak mam zainstalowac ta gre? Nie moge tego zainstalowac dostaje taki komunikat:
pt-get install ClanBomber-1.01-1.i386.rpm
Reading Package Lists... Done
Building Dependency Tree... Done
Selecting ClanBomber for 'ClanBomber-1.01-1.i386.rpm'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ClanBomber: Depends: ClanLib (>= 0.2.2) but it is not installable
Depends: libclanCore.so.0 but it is not installable
Czy nie idzie tego pominąć??
