chakjer Napisano Marzec 28, 2005 Zgłoszenie Share Napisano Marzec 28, 2005 mam standartowa instalke FC3 aktualnie siedze na xfce bo az sie bije wejsc na kde bo to ogolnie prowadzi do ogolnego chaosu zwis systemu po ktorym jako laik rzadko udaje mi sie go odpalic, przewaznie jest zacheta z gruba ( no to robie reinstalke) najczesciej zaczyna sie od tego ze uwala mi firefoxa od tak ( gdzie moge sprawdzic jakislog z tego bo w katalogu /var/log nic w zadnym pliku nie pisze ) pozniej pokolei kicker arts itp. logi bledow Using host libthread_db library "/lib/tls/libthread_db.so.1". [Thread debugging using libthread_db enabled] [New Thread -1208469824 (LWP 5630)] [KCrash handler] #4 0x008f7962 in operator new () from /usr/lib/libstdc++.so.6 #5 0x03b5085e in ?? () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #6 0x00000000 in ?? () Using host libthread_db library "/lib/tls/libthread_db.so.1". [Thread debugging using libthread_db enabled] [New Thread -1208469824 (LWP 5609)] [KCrash handler] #4 0x008927f4 in ?? () from /usr/lib/libstdc++.so.6 #5 0x008f7957 in operator new () from /usr/lib/libstdc++.so.6 #6 0x03eecece in QGList::append () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #7 0x03c3defa in QObject::connectInternal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #8 0x03c3e727 in QObject::connect () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #9 0x03c57c7d in QSignal::connect () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #10 0x03c5f09c in QSingleShotTimer::start () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #11 0x03c5f222 in QTimer::singleShot () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #12 0x045122dd in KDirWatchPrivate::slotRescan () from /usr/lib/libkio.so.4 #13 0x04513041 in KDirWatchPrivate::qt_invoke () from /usr/lib/libkio.so.4 #14 0x03c3f10e in QObject::activate_signal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #15 0x03c3f7e4 in QObject::activate_signal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #16 0x03f738dd in QTimer::timeout () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #17 0x03c5eebc in QTimer::event () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #18 0x03be0539 in QApplication::internalNotify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #19 0x03be06ca in QApplication::notify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #20 0x001b93f8 in KApplication::notify () from /usr/lib/libkdecore.so.4 #21 0x03bd48ab in QEventLoop::activateTimers () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #22 0x03b906fe in QEventLoop::processEvents () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #23 0x03bf5b85 in QEventLoop::enterLoop () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #24 0x03bf5ade in QEventLoop::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #25 0x03bdf73b in QApplication::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #26 0x00340ce3 in kdemain () from /usr/lib/libkdeinit_kded.so #27 0x0032d670 in kdeinitmain () from /usr/lib/kde3/kded.so #28 0x0804dfb1 in ?? () #29 0x00000001 in ?? () #30 0x09ecc438 in ?? () #31 0x00000001 in ?? () #32 0x00000000 in ?? () Using host libthread_db library "/lib/tls/libthread_db.so.1". [Thread debugging using libthread_db enabled] [New Thread -1208469824 (LWP 5645)] [KCrash handler] #4 0x008927f4 in ?? () from /usr/lib/libstdc++.so.6 #5 0x008f7957 in operator new () from /usr/lib/libstdc++.so.6 #6 0x03eecece in QGList::append () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #7 0x03c3dfaa in QObject::connectInternal () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #8 0x03c3e727 in QObject::connect () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #9 0x03c0a083 in QGuardedPtrPrivate::QGuardedPtrPrivate () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #10 0x03c57ea1 in QSignal::activate () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #11 0x03c5f0ff in QSingleShotTimer::event () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #12 0x03be0539 in QApplication::internalNotify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #13 0x03be06ca in QApplication::notify () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #14 0x001b93f8 in KApplication::notify () from /usr/lib/libkdecore.so.4 #15 0x03bd48ab in QEventLoop::activateTimers () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #16 0x03b906fe in QEventLoop::processEvents () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #17 0x03bf5b85 in QEventLoop::enterLoop () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #18 0x03bf5ade in QEventLoop::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #19 0x03bdf73b in QApplication::exec () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #20 0x00d7b8dc in kdemain () from /usr/lib/libkdeinit_konqueror.so #21 0x00349694 in kdeinitmain () from /usr/lib/kde3/konqueror.so #22 0x0804dfb1 in ?? () #23 0x00000003 in ?? () #24 0x09f822e0 in ?? () #25 0x00000001 in ?? () #26 0x09f81f6c in ?? () #27 0x00000000 in ?? () Wiecej nie bede tego wklejal rece mi opadaja jakies pomysly instalka fc3 to KDE Desktop Environment XFCE firefox thunderbird Sound and Video z tamtad stamtąd wszystko wylatuje oprocz xmms X Software Development. KDE Software Development. na sam koniec tylko stery z nvidii i obsluga ntfs Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Marzec 29, 2005 Zgłoszenie Share Napisano Marzec 29, 2005 System zaktualizowany w ogóle? Na zwykłych sterownikach też są takie problemy? W ~/.xsession-errors są jakieś dodatkowe informacje? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
chakjer Napisano Marzec 29, 2005 Autor Zgłoszenie Share Napisano Marzec 29, 2005 to dziwne ale nie mam takiego pliku jak ~/.xsession-errors czyli jak się domyślam nie ma błędów na standartowych sterownikach to samo się działo wywaliłem kde i zainstalowałem gnome ( narazie udaje skałę ) sterowników bym nie podejrzewał ponieważ wcześniej przez chwile używalem suse 9.2 i tam był problem ze sterownikami ale dostaczonymi razem z systemem ( do obsługi 3d ) po instalce z nvidii sterowników wszystko było dobrze ot taka wada sprzętu ze kde na fc3 nie ruszy u mnie dzięki za pomoc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
