Instalacja Kde 3.4 Z Rpm...
bsq
poczytalem poczytalem i uznalem ze najlepiej bedzie jak sciagne wszytkie kawalki kde 3.4 i zainstaluje z rpmow, mam ich tyle:
arts-1.4.0-0.fc3.0.i386.rpm
arts-devel-1.4.0-0.fc3.0.i386.rpm
kdeaccessibility-3.4.0-0.fc3.1.i386.rpm
kdeaddons-3.4.0-0.fc3.0.i386.rpm
kdeaddons-atlantikdesigner-3.4.0-0.fc3.0.i386.rpm
kdeaddons-xmms-3.4.0-0.fc3.0.i386.rpm
kdeadmin-3.4.0-0.fc3.0.i386.rpm
kdeartwork-3.4.0-0.fc3.0.i386.rpm
kdeartwork-icons-3.4.0-0.fc3.0.i386.rpm
kdebase-3.4.0-0.fc3.1.i386.rpm
kdebase-devel-3.4.0-0.fc3.1.i386.rpm
kdebindings-3.4.0-0.fc3.0.i386.rpm
kdebindings-devel-3.4.0-0.fc3.0.i386.rpm
kdeedu-3.4.0-0.fc3.0.i386.rpm
kdeedu-devel-3.4.0-0.fc3.0.i386.rpm
kdegames-3.4.0-0.fc3.0.i386.rpm
kdegames-devel-3.4.0-0.fc3.0.i386.rpm
kdegraphics-3.4.0-0.fc3.0.i386.rpm
kdegraphics-devel-3.4.0-0.fc3.0.i386.rpm
kdelibs-3.4.0-0.fc3.0.i386.rpm
kdelibs-devel-3.4.0-0.fc3.0.i386.rpm
kdemultimedia-3.4.0-0.fc3.0.i386.rpm
kdemultimedia-devel-3.4.0-0.fc3.0.i386.rpm
kdenetwork-3.4.0-0.rc1.2.i386.rpm
kdenetwork-devel-3.4.0-0.rc1.2.i386.rpm
kdenetwork-nowlistening-3.4.0-0.rc1.2.i386.rpm
kdepim-3.4.0-0.fc3.0.i386.rpm
kdepim-devel-3.4.0-0.fc3.0.i386.rpm
kdesdk-3.4.0-0.fc3.0.i386.rpm
kdesdk-devel-3.4.0-0.fc3.0.i386.rpm
kdetoys-3.4.0-0.fc3.0.i386.rpm
kdeutils-3.4.0-0.fc3.0.i386.rpm
kdeutils-devel-3.4.0-0.fc3.0.i386.rpm
kdevelop-3.2.0-0.fc3.0.i386.rpm
kdewebdev-3.4.0-0.fc3.0.i386.rpm
kdewebdev-devel-3.4.0-0.fc3.0.i386.rpm
qt-3.3.4-0.fc3.0.i386.rpm
qt-config-3.3.4-0.fc3.0.i386.rpm
qt-designer-3.3.4-0.fc3.0.i386.rpm
qt-devel-3.3.4-0.fc3.0.i386.rpm
qt-MySQL-3.3.4-0.fc3.0.i386.rpm
qt-ODBC-3.3.4-0.fc3.0.i386.rpm
qt-PostgreSQL-3.3.4-0.fc3.0.i386.rpm
wiec spoko luz... biore sie do instalki rpm -U *.* i d*pa... wychodzi to co lubie najbardziej czyli zaleznosci... takie:
       libruby.so.1.8 jest wymagany przez kdebindings-3.4.0-0.fc3.0.i386
       ruby >= 1.8 jest wymagany przez kdebindings-3.4.0-0.fc3.0.i386
       pcre-devel jest wymagany przez kdelibs-devel-3.4.0-0.fc3.0.i386
       libapr-0.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libaprutil-0.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_client-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_delta-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_diff-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_fs-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_fs_base-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_fs_fs-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_ra-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_ra_dav-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_ra_local-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_ra_svn-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_repos-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_subr-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libsvn_wc-1.so.0 jest wymagany przez kdesdk-3.4.0-0.fc3.0.i386
       libmysqlclient.so.10 jest wymagany przez qt-MySQL-3.3.4-0.fc3.0.i386
tia... a jak posciagam troche z tego to wychodzi na jaw ze nastepne problemy...:
       libcrypto.so.0.9.7 jest wymagany przez libmysqlclient14-4.1.9-74243cl.i386
       libssl.so.0.9.7 jest wymagany przez libmysqlclient14-4.1.9-74243cl.i386
       /usr/lib/python2.4/site-packages jest wymagany przez subversion-1.1.3-0_14.rhfc3.at.i386
       libapr-0.so.0 jest wymagany przez subversion-1.1.3-0_14.rhfc3.at.i386
       libaprutil-0.so.0 jest wymagany przez subversion-1.1.3-0_14.rhfc3.at.i386
       python(abi) = 2.4 jest wymagany przez subversion-1.1.3-0_14.rhfc3.at.i386
i tak mozna do usranej smierci... jest jakas wygodniejsza mozliwosc?? tylko nie mowcie mi o tym yum'ie czy jakos tak.. bo tym jak probowalem to sciagalem 1mb okolo 5min a mam 2Mbit lacze... wiec to smiech nie instalacja...:/
Pamiętaj, że samego kde nie musisz pobierać ponownie! Wystarczy, że (w przypadku (_apt'a_ → apta) ORT), wrzucisz mu te paczki do katalogu /var/cache/apt/archives i spróbujesz zainstalować apt-get install dluga_linia_ze_wszystkimi_pelnymi_nazwami_paczek. Co Ci to da? Nie musisz ponownie pobierać KDE, a apt-get w miarę możliwości uzupełni zależności! Powodzenia!
Aha, możesz też wgrać synaptic i ręcznie wskazać mu, gdzie masz na dysku to KDE i zainstalować. Na jedno wyjdzie, ale chyba za pomocą synaptica będzie szybciej.
