Ati Radeon 9550
wklaczynski
Posiadam stery z Livny, mam takie ustawienia, jest tochę problemów ale działa, co jescze mogę ustawić aby wszystko było oki?
Section "Device"
Identifier "Videocard0"
Driver "fglrx"
VendorName "Videocard vendor"
BoardName "ATI Radeon 9600"
# ### generic DRI settings ###
# === disable PnP Monitor ===
#Option "NoDDC"
# === disable/enable XAA/DRI ===
Option "no_accel" "no"
Option "no_dri" "no"
# === misc DRI settings ===
Option "mtrr" "off" # disable DRI mtrr mapper, driver has its own code for mtrr
# ### FireGL DDX driver module specific settings ###
# === Screen Management ===
#Option "DesktopSetup" "0x00000100"
#Option "MonitorLayout" "AUTO, AUTO"
Option "MonitorLayout" "STV,CRT"
Option "IgnoreEDID" "off"
Option "HSync2" "unspecified"
Option "VRefresh2" "unspecified"
Option "ScreenOverlap" "0"
# === TV-out Management ===
Option "NoTV" "no"
Option "TVStandard" "PAL-D"
Option "TVHSizeAdj" "-2"
Option "TVVSizeAdj" "2"
Option "TVHPosAdj" "0"
Option "TVVPosAdj" "0"
Option "TVHStartAdj" "0"
Option "TVColorAdj" "0"
Option "GammaCorrectionI" "0x06419064"
Option "GammaCorrectionII" "0x06419064"
# === OpenGL specific profiles/settings ===
Option "Capabilities" "0x00000000"
# === Video Overlay for the Xv extension ===
Option "VideoOverlay" "on"
# === OpenGL Overlay ===
# Note: When OpenGL Overlay is enabled, Video Overlay
# will be disabled automatically
Option "OpenGLOverlay" "off"
# === Center Mode (Laptops only) ===
Option "CenterMode" "off"
# === Pseudo Color Visuals (8-bit visuals) ===
Option "PseudoColorVisuals" "off"
# === QBS Management ===
Option "Stereo" "off"
Option "StereoSyncEnable" "1"
# === FSAA Management ===
Option "FSAAEnable" "no"
Option "FSAAScale" "1"
Option "FSAADisableGamma" "no"
Option "FSAACustomizeMSPos" "no"
Option "FSAAMSPosX0" "0.000000"
Option "FSAAMSPosY0" "0.000000"
Option "FSAAMSPosX1" "0.000000"
Option "FSAAMSPosY1" "0.000000"
Option "FSAAMSPosX2" "0.000000"
Option "FSAAMSPosY2" "0.000000"
Option "FSAAMSPosX3" "0.000000"
Option "FSAAMSPosY3" "0.000000"
Option "FSAAMSPosX4" "0.000000"
Option "FSAAMSPosY4" "0.000000"
Option "FSAAMSPosX5" "0.000000"
Option "FSAAMSPosY5" "0.000000"
# === Misc Options ===
Option "UseFastTLS" "0"
Option "BlockSignalsOnLock" "on"
Option "UseInternalAGPGART" "yes"
Option "ForceGenericCPU" "no"
BusID "PCI:1:0:0" # vendor=1002, device=4150
Screen 0
EndSection
I dlaczego? lubię wiedzieć!
Option "UseInternalAGPGART" "yes" sproboj zmienic na "no" u mnie dalo to tyle ze zamiast 300 klatek/s w fglxgears mam ponad 1800 .
w opcji tej chodzi o to czy uzywany ma byc wewnetrzny modul 'agpgart'(tak jak masz w tej chwili) czy ten ktory byl wkompilowany w jadro. przy instalcji zalecana jest ta druga opcja (co faktycznie bynajmiej u mnie dalo klawy wzrost wydajnosci) co do reszty opcji troche siedzialem i zmienialem sobie ale nie daja jakis wielkich rezultatow co do wydajnosci
