Karta Pci Usb 2.0
wi-ciu
lspci
bash: lspci: command not found
dmesg
Linux version 2.6.10-1.770_FC3 ([email protected]) (gcc version 3.4.2 20041017 (Red Hat 3.4.2-6.fc3)) #1 Thu Feb 24 14:00:06 EST 2005
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
BIOS-e820: 000000001fff0000 - 000000001fff3000 (ACPI NVS)
BIOS-e820: 000000001fff3000 - 0000000020000000 (ACPI data)
BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
511MB LOWMEM available.
Using x86 segment limits to approximate NX protection
On node 0 totalpages: 131056
  DMA zone: 4096 pages, LIFO batch:1
  Normal zone: 126960 pages, LIFO batch:16
  HighMem zone: 0 pages, LIFO batch:1
DMI 2.3 present.
ACPI: RSDP (v000 GBT                                  ) @ 0x000f6650
ACPI: RSDT (v001 GBT    AWRDACPI 0x42302e31 AWRD 0x01010101) @ 0x1fff3000
ACPI: FADT (v001 GBT    AWRDACPI 0x42302e31 AWRD 0x01010101) @ 0x1fff3040
ACPI: MADT (v001 GBT    AWRDACPI 0x42302e31 AWRD 0x01010101) @ 0x1fff6900
ACPI: DSDT (v001 GBT    AWRDACPI 0x00001000 MSFT 0x0100000c) @ 0x00000000
ACPI: PM-Timer IO Port: 0x4008
Built 1 zonelists
Kernel command line: ro root=LABEL=/ rhgb vga=773  quiet
Initializing CPU#0
CPU 0 irqstacks, hard=c03d3000 soft=c03d2000
PID hash table entries: 2048 (order: 11, 32768 bytes)
Detected 1500.146 MHz processor.
Using pmtmr for high-res timesource
Console: colour dummy device 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 515132k/524224k available (2045k kernel code, 8564k reserved, 655k data, 160k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 2965.50 BogoMIPS (lpj=1482752)
Security Framework v1.0.0 initialized
SELinux:  Initializing.
SELinux:  Starting in permissive mode
selinux_register_security:  Registering secondary module capability
Capability LSM initialized as secondary
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
CPU: After generic identify, caps: 3febfbff 00000000 00000000 00000000
CPU: After vendor identify, caps:  3febfbff 00000000 00000000 00000000
CPU: Trace cache: 12K uops, L1 D cache: 8K
CPU: L2 cache: 256K
CPU: After all inits, caps:        3febf3ff 00000000 00000000 00000080
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
CPU: Intel® Pentium® 4 CPU 1.50GHz stepping 02
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
ACPI: setting ELCR to 0200 (from 0a20)
checking if image is initramfs... it is
Freeing initrd memory: 383k freed
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xf9e50, last bus=2
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20041105
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (00:00)
PCI: Probing PCI hardware (bus 00)
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 13 devices
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
** PCI interrupts are no longer routed automatically.  If this
** causes a device to stop working, it is probably because the
** driver failed to call pci_enable_device().  As a temporary
** workaround, the "pci=routeirq" argument restores the old
** behavior.  If this argument makes the device work again,
** please email the output of "lspci" to [email protected]
** so I can fix the driver.
apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
apm: overridden by ACPI.
audit: initializing netlink socket (disabled)
audit(1113136078.873:0): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
SELinux:  Registering netfilter hooks
Initializing Cryptographic API
ksign: Installing public key data
Loading keyring
- Added public key C1F2FA57F7EECD64
- User ID: Red Hat, Inc. (Kernel Module GPG key)
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
vesafb: framebuffer at 0xd0000000, mapped to 0xe0880000, using 1536k, total 65536k
vesafb: mode is 1024x768x8, linelength=1024, pages=3
vesafb: protected mode interface info at c000:ece0
vesafb: scrolling: redraw
vesafb: Pseudocolor: size=8:8:8:8, shift=0:0:0:0
Console: switching to colour frame buffer device 128x48
fb0: VESA VGA frame buffer device
ACPI: Processor [CPU0] (supports 2 throttling states)
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12
Linux agpgart interface v0.100 © Dave Jones
agpgart: Detected an Intel i845 Chipset.
agpgart: Maximum main memory to use for agp memory: 439M
agpgart: AGP aperture is 64M @ 0xe0000000
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 76 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
divert: not allocating divert_blk for non-ethernet device lo
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH2: IDE controller at PCI slot 0000:00:1f.1
ICH2: chipset revision 18
ICH2: not 100% native mode: will probe irqs later
    ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:pio
    ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0...
hda: ST340810A, ATA DISK drive
elevator: using anticipatory as default io scheduler
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: Pioneer DVD-ROM ATAPIModel DVD-106S 012, ATAPI CD/DVD-ROM drive
hdd: LITE-ON LTR-48246S, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 78165360 sectors (40020 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
hda: cache flushes not supported
hda: hda1 hda2 < hda5 > hda3 hda4
hdc: ATAPI 40X DVD-ROM drive, 256kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 48X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
ide-floppy driver 0.99.newide
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
mice: PS/2 mouse device common for all mice
input: AT Translated Set 2 keyboard on isa0060/serio0
input: PS/2 Generic Mouse on isa0060/serio1
md: md driver 0.90.1 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 1024 buckets, 32Kbytes
TCP: Hash tables configured (established 32768 bind 9362)
Initializing IPsec netlink socket
NET: Registered protocol family 17
ACPI wakeup devices:
SLPB PCI0 HUB0 USB0 USB1
ACPI: (supports S0 S1 S4 S5)
Freeing unused kernel memory: 160k freed
kjournald starting.  Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
security:  3 users, 4 roles, 320 types, 23 bools
security:  53 classes, 10921 rules
SELinux:  Completing initialization.
SELinux:  Setting up existing superblocks.
SELinux: initialized (dev hda3, type ext3), uses xattr
SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
SELinux: initialized (dev mqueue, type mqueue), not configured for labeling
SELinux: initialized (dev hugetlbfs, type hugetlbfs), not configured for labeling
SELinux: initialized (dev devpts, type devpts), uses transition SIDs
SELinux: initialized (dev eventpollfs, type eventpollfs), uses genfs_contexts
SELinux: initialized (dev futexfs, type futexfs), uses genfs_contexts
SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
SELinux: initialized (dev proc, type proc), uses genfs_contexts
SELinux: initialized (dev bdev, type bdev), uses genfs_contexts
SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
SELinux: initialized (dev usbfs, type usbfs), uses genfs_contexts
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
ne2k-pci.c:v1.03 9/22/2003 D. Becker/P. Gortmaker
  http://www.scyld.com/network/ne2k-pci.html
ACPI: PCI Interrupt Link [LNKF] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI interrupt 0000:02:05.0[A] -> GSI 11 (level, low) -> IRQ 11
divert: allocating divert_blk for eth0
eth0: RealTek RTL-8029 found at 0xc000, IRQ 11, 00:05:1C:14:EC:F4.
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 9
PCI: setting IRQ 9 as level-triggered
ACPI: PCI interrupt 0000:00:1f.5 -> GSI 9 (level, low) -> IRQ 9
PCI: Setting latency timer of device 0000:00:1f.5 to 64
intel8x0_measure_ac97_clock: measured 49478 usecs
intel8x0: clocking to 48000
hw_random: RNG not detected
ACPI: PCI Interrupt Link [LNK0] enabled at IRQ 9
ACPI: PCI interrupt 0000:02:02.3[A] -> GSI 9 (level, low) -> IRQ 9
ehci_hcd 0000:02:02.3: EHCI Host Controller
ehci_hcd 0000:02:02.3: irq 9, pci mem 0xe7001000
ehci_hcd 0000:02:02.3: new USB bus registered, assigned bus number 1
PCI: cache line size of 128 is not supported by device 0000:02:02.3
ehci_hcd 0000:02:02.3: USB 2.0 initialized, EHCI 1.00, driver 26 Oct 2004
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 4 ports detected
ohci_hcd: 2004 Nov 08 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 5
PCI: setting IRQ 5 as level-triggered
ACPI: PCI interrupt 0000:02:02.0 -> GSI 5 (level, low) -> IRQ 5
ohci_hcd 0000:02:02.0: OHCI Host Controller
ohci_hcd 0000:02:02.0: irq 5, pci mem 0xe7002000
ohci_hcd 0000:02:02.0: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
ACPI: PCI interrupt 0000:02:02.1[C] -> GSI 11 (level, low) -> IRQ 11
ohci_hcd 0000:02:02.1: OHCI Host Controller
ohci_hcd 0000:02:02.1: irq 11, pci mem 0xe7000000
ohci_hcd 0000:02:02.1: new USB bus registered, assigned bus number 3
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
USB Universal Host Controller Interface driver v2.2
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 5
ACPI: PCI interrupt 0000:00:1f.2[D] -> GSI 5 (level, low) -> IRQ 5
uhci_hcd 0000:00:1f.2: UHCI Host Controller
PCI: Setting latency timer of device 0000:00:1f.2 to 64
uhci_hcd 0000:00:1f.2: irq 5, io base 0xd000
uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 4
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ACPI: PCI Interrupt Link [LNK1] enabled at IRQ 11
ACPI: PCI interrupt 0000:00:1f.4[C] -> GSI 11 (level, low) -> IRQ 11
uhci_hcd 0000:00:1f.4: UHCI Host Controller
PCI: Setting latency timer of device 0000:00:1f.4 to 64
uhci_hcd 0000:00:1f.4: irq 11, io base 0xd800
uhci_hcd 0000:00:1f.4: new USB bus registered, assigned bus number 5
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 2 ports detected
usb 4-1: new low speed USB device using uhci_hcd and address 2
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
input: USB HID v1.00 Keyboard [                  Wireless Keyboard  mouse] on usb-0000:00:1f.2-1
input: USB HID v1.00 Mouse [                  Wireless Keyboard  mouse] on usb-0000:00:1f.2-1
usb 4-2: new low speed USB device using uhci_hcd and address 3
input: USB HID v1.00 Mouse [uSB Wheel Mouse] on usb-0000:00:1f.2-2
SELinux: initialized (dev ramfs, type ramfs), uses genfs_contexts
NET: Registered protocol family 10
Disabled Privacy Extensions on device c03697c0(lo)
IPv6 over IPv4 tunneling driver
divert: not allocating divert_blk for non-ethernet device sit0
drivers/usb/input/hid-input.c: event field not found
ACPI: Power Button (FF) [PWRF]
ACPI: Sleep Button (CM) [sLPB]
ibm_acpi: ec object not found
EXT3 FS on hda3, internal journal
device-mapper: 4.3.0-ioctl (2004-09-30) initialised: [email protected]
NTFS driver 2.1.22 [Flags: R/W MODULE].
NTFS volume version 3.1.
SELinux: initialized (dev hda5, type ntfs), uses genfs_contexts
Adding 618492k swap on /dev/hda4.  Priority:-1 extents:1
SELinux: initialized (dev binfmt_misc, type binfmt_misc), uses genfs_contexts
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
pnp: Device 00:09 disabled.
ieee1394: Initialized config rom entry `ip1394'
ip_tables: © 2000-2002 Netfilter core team
ip_conntrack version 2.1 (4095 buckets, 32760 max) - 360 bytes per conntrack
SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), uses genfs_contexts
pnp: Device 00:09 activated.
lp0: using parport0 (interrupt-driven).
lp0: console ready
eth0: no IPv6 routers present
Dziwne... Jesteś zalogowany jako root (su -)? Teoretycznie nie trzeba mieć uprawnień (_root'a_ → roota) ORT, ale kto wie....
Masz wgraną paczkę pciutils?
Sprawdź to poleceniem:
rpm -q pciutils
Jeśli nie masz, to wpisz:
yum install pciutils
W takim razie spróbuj poszukać, gdzie jest plik wejściowy:
whereis lspci
U mnie jest w /sbin/lspci i dokładnie takim poleceniem spróbuj go odpalić.
Jeśli możesz otworzyć ten plik powyższym poleceniem, to znaczy, że masz problem z plikiem ~/.bash_profile, w takim wypadku wklej go tu.
nie wiem, o co ci chodziło, więc wypisuję obie rzeczy:
/sbin/lspci
00:00.0 Host bridge: Intel Corp. 82845 845 (Brookdale) Chipset Host Bridge (rev 03)
00:01.0 PCI bridge: Intel Corp. 82845 845 (Brookdale) Chipset AGP Bridge (rev 03)
00:1e.0 PCI bridge: Intel Corp. 82801 PCI Bridge (rev 12)
00:1f.0 ISA bridge: Intel Corp. 82801BA ISA Bridge (LPC) (rev 12)
00:1f.1 IDE interface: Intel Corp. 82801BA IDE U100 (rev 12)
00:1f.2 USB Controller: Intel Corp. 82801BA/BAM USB (Hub #1) (rev 12)
00:1f.3 SMBus: Intel Corp. 82801BA/BAM SMBus (rev 12)
00:1f.4 USB Controller: Intel Corp. 82801BA/BAM USB (Hub #2) (rev 12)
00:1f.5 Multimedia audio controller: Intel Corp. 82801BA/BAM AC'97 Audio (rev 12)
01:00.0 VGA compatible controller: nVidia Corporation NV17 [GeForce4 MX 460] (rev a3)
02:02.0 USB Controller: ALi Corporation USB 1.1 Controller (rev 03)
02:02.1 USB Controller: ALi Corporation USB 1.1 Controller (rev 03)
02:02.3 USB Controller: ALi Corporation USB 2.0 Controller (rev 01)
02:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8029(AS)
cat /home/wi-ciu/.bash_profile
# .bash_profile
# Get the aliases and functions
if [ -f ~/.bashrc ]; then
        . ~/.bashrc
fi
# User specific environment and startup programs
PATH=$PATH:$HOME/bin
export PATH
unset USERNAME
Zamień to na
PATH=$PATH:$HOME/bin:/sbin
i będziesz mógł normalnie odpalać lsmod i inne.
Teraz niech Ci ktoś pomoże w Twoim głównym problemie. Powodzenia!
Dzięki wielkie!
POWTARZAM APEL:
Jak uruchomić porty USB 2.0, jeśli nie są w płycie głównej, a w karcie PCI? Producent: Acer Labs Inc.. Sterowników nigdzie się nie da znaleźć (chyba, że jam jest ślepy), a kudzu nie pokazuje niczego przy podłączeniu do tych portów.
