Problem Z Kernel-em
lewy22
Hej , witam wszystkich!!!
Ostatnio skompilowalem sobie jadro linux-a 2.6.11-gentoo-r4 , po starcie systemu widze pare komunikatow kernela a pozniej czarny ekran z migajacym kursorem na dole .
/var/log/kernel/current pokazuje mi :
Apr 11 18:41:40 [kernel] mice: PS/2 mouse device common for all mice
Apr 11 18:41:40 [kernel] agpgart: Detected an Intel 865 Chipset.
Apr 11 18:41:41 [kernel] USB Universal Host Controller Interface driver v2.2
Apr 11 18:41:41 [kernel] uhci_hcd 0000:00:1d.0: Intel Corp. 82801EB/ER (ICH5/ICH5R) USB UHCI #1
Apr 11 18:41:41 [kernel] PCI: Setting latency timer of device 0000:00:1d.0 to 64
Apr 11 18:41:41 [kernel] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
Apr 11 18:41:41 [kernel] hub 1-0:1.0: USB hub found
Apr 11 18:41:41 [kernel] uhci_hcd 0000:00:1d.1: Intel Corp. 82801EB/ER (ICH5/ICH5R) USB UHCI #2
Apr 11 18:41:41 [kernel] PCI: Setting latency timer of device 0000:00:1d.1 to 64
Apr 11 18:41:41 [kernel] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
Apr 11 18:41:41 [kernel] hub 2-0:1.0: USB hub found
Apr 11 18:41:41 [kernel] uhci_hcd 0000:00:1d.2: Intel Corp. 82801EB/ER (ICH5/ICH5R) USB UHCI #3
Apr 11 18:41:41 [kernel] PCI: Setting latency timer of device 0000:00:1d.2 to 64
Apr 11 18:41:41 [kernel] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
Apr 11 18:41:41 [kernel] hub 3-0:1.0: USB hub found
Apr 11 18:41:41 [kernel] uhci_hcd 0000:00:1d.3: Intel Corp. 82801EB/ER (ICH5/ICH5R) USB UHCI #4
Apr 11 18:41:41 [kernel] PCI: Setting latency timer of device 0000:00:1d.3 to 64
Apr 11 18:41:41 [kernel] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
Apr 11 18:41:41 [kernel] hub 4-0:1.0: USB hub found
Apr 11 18:41:41 [kernel] ehci_hcd 0000:00:1d.7: Intel Corp. 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller
Apr 11 18:41:41 [kernel] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
Apr 11 18:41:41 [kernel] hub 5-0:1.0: USB hub found
Apr 11 18:41:42 [kernel] ICH5: IDE controller at PCI slot 0000:00:1f.1
Apr 11 18:41:42 [kernel] PCI: Setting latency timer of device 0000:00:1f.5 to 64
Apr 11 18:41:42 [kernel] AC'97 0 analog subsections not ready
Apr 11 18:41:42 [kernel] intel8x0_measure_ac97_clock: measured 49458 usecs
Apr 11 18:41:43 [kernel] radeonfb: Found Intel x86 BIOS ROM Image
Apr 11 18:41:43 [kernel] radeonfb: Monitor 1 type CRT found
Apr 11 18:41:43 [kernel] radeonfb (0000:01:00.0): ATI Radeon AD
Apr 11 18:41:44 [kernel] ohci_hcd: 2004 Nov 08 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
Apr 11 18:41:46 [kernel] eth0: link up, 10Mbps, half-duplex, lpa 0x0000
Apr 11 18:41:47 [kernel] devfs_mk_dev: could not append to parent for vcc/2
Apr 11 18:41:47 [kernel] devfs_mk_dev: could not append to parent for vcc/3
Apr 11 18:41:47 [kernel] devfs_mk_dev: could not append to parent for vcc/4
devfsd i udev mam zainstalowane , kompilowalem jajko : "make && make modules_install" , wczesniej mialem jajko przez genkernel i wszystko dzialalo.
Nie wiecie moze co z tym zrobic , kombinowalem juz na wiele sposobow ale mi nie wychodzi , pomocy , z gory dzieki za wszelkie wskazowki!
Pozdrowienia dla wszystkich!!!
OK z tym :
Zrobilem tak , odinstalowalem devfsd i zostawilem udev a w kernelu wylaczylem opcje "File system -> Pseudo Filesystem -> Automatically mount at boot " i zniknely te dziwne komunikaty .
ale teraz mam cos takiego :
Apr 12 03:12:05 [kernel] Linux version 2.6.11-gentoo-r4 (root@lewy) (gcc version 3.3.5 (Gentoo Linux 3.3.5-r1, ssp-3.3.2-3, pie-8.7.7.1)) #12 Tue Apr 12 03:10:13 CEST 2005
Apr 12 03:12:05 [kernel] agpgart: Detected an Intel 865 Chipset.
Apr 12 03:12:06 [kernel] USB Universal Host Controller Interface driver v2.2
Apr 12 03:12:06 [kernel] uhci_hcd 0000:00:1d.0: Intel Corp. 82801EB/ER (ICH5/ICH5R) USB UHCI #1
Apr 12 03:12:06 [kernel] PCI: Setting latency timer of device 0000:00:1d.0 to 64
Apr 12 03:12:06 [kernel] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
Apr 12 03:12:06 [kernel] hub 1-0:1.0: USB hub found
Apr 12 03:12:06 [kernel] uhci_hcd 0000:00:1d.1: Intel Corp. 82801EB/ER (ICH5/ICH5R) USB UHCI #2
Apr 12 03:12:06 [kernel] PCI: Setting latency timer of device 0000:00:1d.1 to 64
Apr 12 03:12:06 [kernel] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
Apr 12 03:12:06 [kernel] hub 2-0:1.0: USB hub found
Apr 12 03:12:06 [kernel] uhci_hcd 0000:00:1d.2: Intel Corp. 82801EB/ER (ICH5/ICH5R) USB UHCI #3
Apr 12 03:12:06 [kernel] PCI: Setting latency timer of device 0000:00:1d.2 to 64
Apr 12 03:12:06 [kernel] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
Apr 12 03:12:06 [kernel] hub 3-0:1.0: USB hub found
Apr 12 03:12:06 [kernel] uhci_hcd 0000:00:1d.3: Intel Corp. 82801EB/ER (ICH5/ICH5R) USB UHCI #4
Apr 12 03:12:06 [kernel] PCI: Setting latency timer of device 0000:00:1d.3 to 64
Apr 12 03:12:06 [kernel] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
Apr 12 03:12:06 [kernel] hub 4-0:1.0: USB hub found
Apr 12 03:12:06 [kernel] ehci_hcd 0000:00:1d.7: Intel Corp. 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller
Apr 12 03:12:06 [kernel] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
Apr 12 03:12:06 [kernel] hub 5-0:1.0: USB hub found
Apr 12 03:12:07 [kernel] ICH5: IDE controller at PCI slot 0000:00:1f.1
Apr 12 03:12:07 [kernel] PCI: Setting latency timer of device 0000:00:1f.5 to 64
Apr 12 03:12:07 [kernel] AC'97 0 analog subsections not ready
Apr 12 03:12:07 [kernel] intel8x0_measure_ac97_clock: measured 49455 usecs
Apr 12 03:12:08 [kernel] radeonfb: Found Intel x86 BIOS ROM Image
Apr 12 03:12:08 [kernel] radeonfb: Monitor 1 type CRT found
Apr 12 03:12:08 [kernel] radeonfb (0000:01:00.0): ATI Radeon AD
Apr 12 03:12:09 [kernel] 8139too Fast Ethernet driver 0.9.27
Apr 12 03:12:09 [kernel] eth0: RealTek RTL8139 at 0xd0916c00, 00:e0:7d:d5:5d:fa, IRQ 11
Apr 12 03:12:09 [kernel] ohci_hcd: 2004 Nov 08 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
Apr 12 03:12:09 [kernel] eth0: link up, 10Mbps, half-duplex, lpa 0x0000
i znow kernel idzie do pewniego momentu i czarny ekran z migajacym kursorem na dole , chyba cos z sieciowka jeszcze spierdzielilem...? dobrze mysle...? a moze to cos innego...? nie wiecie moze co...? Confused
Dzieki za wszelkie podpowiedzi!
