tysek Napisano Kwiecień 18, 2005 Zgłoszenie Share Napisano Kwiecień 18, 2005 ---==== JUZ NIE WIAŻNE ZROBIEŁEM PRZEZ SKASOWANIE KATALOGU .KDE w /HOME==-- Po dzisiejszym włączeniu kompa kompa zobaczyłem cos takiego zamiast paska u dolu ekranu -totala panika Using host libthread_db library "/lib/tls/libthread_db.so.1". [Thread debugging using libthread_db enabled] [New Thread -1210214720 (LWP 5453)] [KCrash handler] #4 0x004c67a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2 #5 0x00506955 in raise () from /lib/tls/libc.so.6 #6 0x00508319 in abort () from /lib/tls/libc.so.6 #7 0x0097b6eb in __gnu_cxx::__verbose_terminate_handler () from /usr/lib/libstdc++.so.6 #8 0x009793fd in __cxa_call_unexpected () from /usr/lib/libstdc++.so.6 #9 0x00979432 in std::terminate () from /usr/lib/libstdc++.so.6 #10 0x0097957b in __cxa_throw () from /usr/lib/libstdc++.so.6 #11 0x009799cc in operator new () from /usr/lib/libstdc++.so.6 #12 0x00979a69 in operator new[] () from /usr/lib/libstdc++.so.6 #13 0x077e507e in QString::setLength () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #14 0x077ed519 in operator>> () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #15 0xb77e4842 in kdemain () from /usr/lib/kde3/klipper_panelapplet.so #16 0xb77e555b in kdemain () from /usr/lib/kde3/klipper_panelapplet.so #17 0xb77e6e29 in kdemain () from /usr/lib/kde3/klipper_panelapplet.so #18 0xb77e0d2e in ?? () from /usr/lib/kde3/klipper_panelapplet.so #19 0x08240e70 in ?? () #20 0x08236508 in ?? () #21 0x08240fc0 in ?? () #22 0x00000001 in ?? () #23 0xb77f7776 in typeinfo name for KAboutApplication () from /usr/lib/kde3/klipper_panelapplet.so #24 0x00603800 in __malloc_initialize_hook () from /lib/tls/libc.so.6 #25 0x0000014c in ?? () #26 0x0099a2a0 in ?? () from /usr/lib/libstdc++.so.6 #27 0x0000014c in ?? () #28 0x08236508 in ?? () #29 0xbfffdce8 in ?? () #30 0x08240e70 in ?? () #31 0x08232868 in ?? () #32 0x08236508 in ?? () #33 0xbfffdce8 in ?? () #34 0x0754ceed in QWidget::setBackgroundMode () from /usr/lib/qt-3.3/lib/libqt-mt.so.3 #35 0xb77e0e2a in ?? () from /usr/lib/kde3/klipper_panelapplet.so #36 0x08240e70 in ?? () #37 0x08236508 in ?? () #38 0x00000000 in ?? () ---==== JUZ NIE WIAŻNE ZROBIEŁEM PRZEZ SKASOWANIE KATALOGU .KDE w /HOME==-- Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
