Problem Z Eclipsem
dalnet
czesc,
Mam problem z Eclipsem w Fedora Core 3, podczas uruchamiania ./eclipse system podaje komunikat:
libgcj-java-placeholder.sh
This script is a placeholder for the /usr/bin/java
master link required by jpackage.org conventions. libgcj's
rmiregistry, rmic and jar tools are now slave symlinks to these
masters, and are managed by the alternatives(8) system.
This change was necessary because the rmiregistry, rmic and jar tools
installed by previous versions of libgcj conflicted with symlinks
installed by jpackage.org JVM packages.
System generuje rowiez loga, ktory jest jednak dla mnie malo czytelny
Mam prosbe, ktore spotkaly sie z tym problemem lub wiedza jak go rozwiazac o jakas rade i jak najszybsza pomoc, poniewaz sprawa jest dosc pilna
pozdr,
dalnet
czesc,Mam problem z Eclipsem w Fedora Core 3, podczas uruchamiania ./eclipse system podaje komunikat:
masters, and are managed by the alternatives(8) system.[ciach]
sam siedze na netbeans, ale widze ze sprawa jest dosc znana.. znalazlem cos takiego:
"I had the same problem. It seemed that my java and javac files in /usr/bin vere symbolic links which pointed to bogus scripts. I solved it by replacing them with symbolic links pointing to the real java and javac files. (in my case: /usr/java/jdk1.5.0_01/bin/[java,javac])"
jeszcze w razie co zerknij tu: forum
nie wiem czy dobrze zrozumialem,
plik z /usr/bin/java jest linkiem sybolicznym, zastapilem ten link symboliczny linkiem z wspisana sciezka na prawdziwe pliki javy
Poczatkowy plik: java
#!/bin/sh
echo "libgcj-java-placeholder.sh"
echo
echo "This script is a placeholder for the /usr/bin/java"
echo "master link required by jpackage.org conventions. libgcj's"
echo "rmiregistry, rmic and jar tools are now slave symlinks to these"
echo "masters, and are managed by the alternatives(8) system."
echo
echo "This change was necessary because the rmiregistry, rmic and jar tools"
echo "installed by previous versions of libgcj conflicted with symlinks"
echo "installed by jpackage.org JVM packages."
exec gij "$@"
zastąpilem linkiem w postaci
#!/bin/sh
/usr/java/jdk1.5.0_02/bin/java (tytaj rzeczywiscie ma pliki javy)
dalej nie wlącza sie
Co robic :/?
Gość
