Problem Z Kismet-em
alienv
Mam taki problem z Kismetem
alien@localhost ~]$ kismet_server -p 2501
Will drop privs to alien (500) gid 500
Enabling channel hopping.
Enabling channel splitting.
Source 0 (prismsource): Enabling monitor mode for hostap source interface wlan0channel 6...
FATAL: Failed to set private ioctl 'monitor': Operation not permitted
z kolei jak probuje odpalic jako root pokazuje mi sie cos takiego
[root@localhost ~]# kismet_server -p 2501
Source 0 (prismsource): Opening hostap source interface wlan0...
Spawned channelc control process 4061
Dropped privs to alien (500) gid 500
Allowing clients to fetch WEP keys.
Logging networks to Kismet-Apr-28-2005-1.network
Logging networks in CSV format to Kismet-Apr-28-2005-1.csv
Logging networks in XML format to Kismet-Apr-28-2005-1.xml
Logging cryptographically weak packets to Kismet-Apr-28-2005-1.weak
Logging cisco product information to Kismet-Apr-28-2005-1.cisco
Logging gps coordinates to Kismet-Apr-28-2005-1.gps
Logging data to Kismet-Apr-28-2005-1.dump
Writing data files to disk every 300 seconds.
Mangling encrypted and fuzzy data packets.
Tracking probe responses and associating probe networks.
Reading AP manufacturer data and defaults from /usr/local/etc/ap_manuf
Reading client manufacturer data and defaults from /usr/local/etc/client_manuf
FATAL: Dump file error: Unable to open dump file Kismet-Apr-28-2005-1.dump (Permission denied)
Sending termination request to channel control child 4061...
Waiting for channel control child 4061 to exit...
WARNING: Sometimes cards don't always come out of monitor mode
        cleanly.  If your card is not fully working, you may need to
        restart or reconfigure it for normal operation.
Kismet exiting.
jako root odpalilem na probe, wole uzywac jako user zwykly
Sieciowka to Dlink 520 rev E (prism3) i najnowsze hostap
Miał ktoś podony problem ?
A stworzyles jakiegos użytkownika na prawach ktorego bedzie dzialal kismet ? Uruchamia sie go bedac rootem ale pozniej przechodzi on na prawa użytkownika takiego jakiego ustawiles w pliku konfiguracyjnym. Dodatkowo uruchamiajac go musisz byc w katalogu domowym tego użytkownika.
Gość
