Isdn Fritz Pci Jak Sprawdzić Czy Działa 2
abyr
Witam
Wracam do sprawy związanej z połączeniem ISDN. Mam troche więcej danych ale połaczenia nie udało mi sie zrealizować. Może jak obejrzycie to wszystko poniżej moze coś wam to powie.
[root@Radek etc]# ifconfig
ippp0    Link encap:Point-to-Point Protocol
          UP POINTOPOINT RUNNING NOARP  MTU:1500  Metric:1
          collisions:0 txqueuelen:30
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:2890 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2890 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:3539618 (3.3 MiB)  TX bytes:3539618 (3.3 MiB)
[root@Radek default]# route
Kernel IP routing table
Destination    Gateway        Genmask        Flags Metric Ref    Use Iface
default      *              0.0.0.0        U    0      0        0 ippp0
/var/log/messages:
May 15 21:15:37 Radek ifup-ippp: isdnctrl addif ippp0
May 15 21:15:37 Radek ifup-ippp: isdnctrl addphone ippp0 out 420209559
May 15 21:15:37 Radek ifup-ippp: isdnctrl l2_prot ippp0 hdlc
May 15 21:15:37 Radek ifup-ippp: isdnctrl l3_prot ippp0 trans
May 15 21:15:37 Radek ifup-ippp: isdnctrl encap ippp0 syncppp
May 15 21:15:37 Radek ifup-ippp: isdnctrl dialmode ippp0 auto
May 15 21:15:37 Radek ifup-ippp: isdnctrl secure ippp0 off
May 15 21:15:37 Radek ifup-ippp: isdnctrl huptimeout ippp0 600
May 15 21:15:37 Radek ifup-ippp: isdnctrl callback ippp0 off
May 15 21:15:37 Radek ifup-ippp: isdnctrl pppbind ippp0
May 15 21:15:37 Radek ifup-ippp: ifconfig ippp0 0.0.0.0 pointopoint 0.0.0.0  up
May 15 21:15:37 Radek ifup-ippp: ipppd 0.0.0.0:0.0.0.0  defaultroute deldefaultroute file /etc/ppp/ioption-secret-ippp0 ipparam dialog ipcp-accept-local /dev/ippp0 ipcp-accept-remote -vj -vjccomp -ac -pc -bsdcomp -callback-cbcp noccp -pap ms-get-dns
May 15 21:15:37 Radek ipppd[4822]: Found 1 device:
May 15 21:15:37 Radek ipppd[4823]: ipppd i2.2.12 (isdn4linux version of pppd by MH) started
May 15 21:15:37 Radek ipppd[4823]: init_unit: 0
May 15 21:15:37 Radek ipppd[4823]: Connect[0]: /dev/ippp0, fd: 15
May 15 21:15:40 Radek ifup-ippp: isdnctrl addif ippp0
May 15 21:15:40 Radek ifup-ippp: isdnctrl addphone ippp0 out 420209559
May 15 21:15:40 Radek ifup-ippp: isdnctrl l2_prot ippp0 hdlc
May 15 21:15:40 Radek ifup-ippp: isdnctrl l3_prot ippp0 trans
May 15 21:15:40 Radek ifup-ippp: isdnctrl encap ippp0 syncppp
May 15 21:15:40 Radek ifup-ippp: isdnctrl dialmode ippp0 auto
May 15 21:15:40 Radek ifup-ippp: isdnctrl secure ippp0 off
May 15 21:15:40 Radek ifup-ippp: isdnctrl huptimeout ippp0 600
May 15 21:15:40 Radek ifup-ippp: isdnctrl callback ippp0 off
May 15 21:15:40 Radek ifup-ippp: isdnctrl pppbind ippp0
May 15 21:15:40 Radek ifup-ippp: ifconfig ippp0 0.0.0.0 pointopoint 0.0.0.0  up
May 15 21:15:40 Radek ifup-ippp: ipppd 0.0.0.0:0.0.0.0  defaultroute deldefaultroute file /etc/ppp/ioption-secret-ippp0 ipparam dialog ipcp-accept-local /dev/ippp0 ipcp-accept-remote -vj -vjccomp -ac -pc -bsdcomp -callback-cbcp noccp -pap ms-get-dns
May 15 21:15:41 Radek ipppd[4909]: Found 1 device:
May 15 21:15:41 Radek ipppd[4910]: ipppd i2.2.12 (isdn4linux version of pppd by MH) started
May 15 21:15:41 Radek ipppd[4910]: init_unit: 0
May 15 21:15:41 Radek ipppd[4910]: Connect[0]: /dev/ippp0, fd: 15
May 15 21:15:42 Radek wait_for_sysfs[4798]: either wait_for_sysfs (udev 039) needs an update to handle the device '/class/net/ippp0' properly (no device symlink) or the sysfs-support of your device's driver needs to be fixed, please report to <[email protected]>
May 15 21:15:43 Radek kernel: ippp0: dialing 1 420209559...
May 15 21:15:46 Radek wait_for_sysfs[4885]: either wait_for_sysfs (udev 039) needs an update to handle the device '/class/net/ippp0' properly (no device symlink) or the sysfs-support of your device's driver needs to be fixed, please report to <[email protected]>
May 15 21:15:51 Radek kernel: isdn_net: local hangup ippp0
May 15 21:15:51 Radek kernel: ippp0: Chargesum is 0
NO i na końcu tej całej zabawy jest komunikat
Dialing of ippp0 triggered
Może sie komuś uda coś wywnioskować - mnie juz brakuje pomysłów
